Jetson Nano
• DeepStream Version
6.0
JetPack SDK version: # R32 (release), REVISION: 7.4, GCID: 33514132, BOARD: t210ref, EABI: aarch64, DATE: Fri Jun 9 04:25:08 UTC 2023
I’m having an inference.py, which runs fine. Whenever I start the script and stop it via CTRL_C, everything works as expected.
Now I wanted to add a little API for start/stop. While I’m able to start the pipeline once and also being able to stop it once, every attempt to issue a subsequent “start” ends in a segmentation fault.
My start sequence in the log, input is /dev/video0:
Using winsys: x11
gstnvtracker: Loading low-level lib at /opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so
gstnvtracker: Batch processing is ON
gstnvtracker: Past frame output is ON
[NvMultiObjectTracker] Initialized
Deserialize yoloLayer plugin: yolo
0:00:11.644781964 22195 0x7f9853e230 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1900> [UID = 1]: deserialized trt engine from :/home/ubuntu/vx-ai/jetson-inference/models/primary-detector-nano/yolov7-tiny/model_b3_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT data 3x416x416
1 OUTPUT kFLOAT num_detections 1
2 OUTPUT kFLOAT detection_boxes 10647x4
3 OUTPUT kFLOAT detection_scores 10647
4 OUTPUT kFLOAT detection_classes 10647
0:00:11.646134594 22195 0x7f9853e230 INFO nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2004> [UID = 1]: Use deserialized engine model: /home/ubuntu/vx-ai/jetson-inference/models/primary-detector-nano/yolov7-tiny/model_b3_gpu0_fp16.engine
0:00:12.036657142 22195 0x7f9853e230 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:/tmp/tmpgh8zzwyw sucessfully
0:00:12.037355176 22195 0x7f98536b20 FIXME videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out:<jpegdec0> Sub-class should implement drain()
2024-03-29 12:12:28,228 inference.py INFO : [eglglessink0] State changed from NULL to READY.
2024-03-29 12:12:28,229 inference.py INFO : [nvegltransform0] State changed from NULL to READY.
2024-03-29 12:12:28,229 inference.py INFO : [nvdsosd0] State changed from NULL to READY.
2024-03-29 12:12:28,229 inference.py INFO : [nvvideoconvert1] State changed from NULL to READY.
2024-03-29 12:12:28,230 inference.py INFO : [nvmultistreamtiler0] State changed from NULL to READY.
2024-03-29 12:12:28,230 inference.py INFO : [nvtracker0] State changed from NULL to READY.
2024-03-29 12:12:28,230 inference.py INFO : [nvinfer0] State changed from NULL to READY.
2024-03-29 12:12:28,231 inference.py INFO : [nvstreammux0] State changed from NULL to READY.
2024-03-29 12:12:28,231 inference.py INFO : [capsfilter1] State changed from NULL to READY.
2024-03-29 12:12:28,231 inference.py INFO : [nvvideoconvert0] State changed from NULL to READY.
2024-03-29 12:12:28,232 inference.py INFO : [videoflip0] State changed from NULL to READY.
2024-03-29 12:12:28,232 inference.py INFO : [jpegdec0] State changed from NULL to READY.
2024-03-29 12:12:28,232 inference.py INFO : [capsfilter0] State changed from NULL to READY.
2024-03-29 12:12:28,233 inference.py INFO : [v4l2src0] State changed from NULL to READY.
2024-03-29 12:12:28,233 inference.py INFO : [source-bin-0] State changed from NULL to READY.
2024-03-29 12:12:28,233 inference.py INFO : [pipeline0] State changed from NULL to READY.
2024-03-29 12:12:28,233 inference.py INFO : [nvegltransform0] State changed from READY to PAUSED.
2024-03-29 12:12:28,234 inference.py INFO : [nvdsosd0] State changed from READY to PAUSED.
2024-03-29 12:12:28,234 inference.py INFO : [nvvideoconvert1] State changed from READY to PAUSED.
2024-03-29 12:12:28,234 inference.py INFO : [nvmultistreamtiler0] State changed from READY to PAUSED.
2024-03-29 12:12:28,235 inference.py INFO : [nvtracker0] State changed from READY to PAUSED.
2024-03-29 12:12:28,235 inference.py INFO : [nvinfer0] State changed from READY to PAUSED.
2024-03-29 12:12:28,235 inference.py INFO : [nvstreammux0] State changed from READY to PAUSED.
2024-03-29 12:12:28,236 inference.py INFO : [capsfilter1] State changed from READY to PAUSED.
2024-03-29 12:12:28,236 inference.py INFO : [nvvideoconvert0] State changed from READY to PAUSED.
2024-03-29 12:12:28,236 inference.py INFO : [videoflip0] State changed from READY to PAUSED.
2024-03-29 12:12:28,237 inference.py INFO : [jpegdec0] State changed from READY to PAUSED.
2024-03-29 12:12:28,237 inference.py INFO : [capsfilter0] State changed from READY to PAUSED.
2024-03-29 12:12:28,237 inference.py INFO : [v4l2src0] State changed from READY to PAUSED.
2024-03-29 12:12:28,237 inference.py INFO : [source-bin-0] State changed from READY to PAUSED.
2024-03-29 12:12:28,238 inference.py INFO : [pipeline0] State changed from READY to PAUSED.
2024-03-29 12:12:28,238 inference.py INFO : [nvegltransform0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,238 inference.py INFO : [nvdsosd0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,239 inference.py INFO : [nvvideoconvert1] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,239 inference.py INFO : [nvmultistreamtiler0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,239 inference.py INFO : [nvtracker0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,240 inference.py INFO : [nvinfer0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,240 inference.py INFO : [nvstreammux0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,240 inference.py INFO : [capsfilter1] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,241 inference.py INFO : [nvvideoconvert0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,241 inference.py INFO : [videoflip0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,242 inference.py INFO : [jpegdec0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,242 inference.py INFO : [capsfilter0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,243 inference.py INFO : [v4l2src0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:28,243 inference.py INFO : [source-bin-0] State changed from PAUSED to PLAYING.
0:00:12.074213203 22195 0x7f98536b20 WARN v4l2bufferpool gstv4l2bufferpool.c:790:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:13.024417113 22195 0x7f98536b20 FIXME videodecoder gstvideodecoder.c:933:gst_video_decoder_drain_out:<jpegdec0> Sub-class should implement drain()
0:00:13.211542403 22195 0x7f98536b20 WARN v4l2src gstv4l2src.c:976:gst_v4l2src_create:<v4l2src0> lost frames detected: count = 1 - ts: 0:00:01.122992461
2024-03-29 12:12:31,076 inference.py INFO : [Stream 0] detection fps: 0.00 (0.00)
2024-03-29 12:12:31,140 inference.py INFO : [eglglessink0] State changed from READY to PAUSED.
2024-03-29 12:12:31,141 inference.py INFO : [eglglessink0] State changed from PAUSED to PLAYING.
2024-03-29 12:12:31,142 inference.py INFO : [pipeline0] State changed from PAUSED to PLAYING.
I’m stopping this by self.pipeline.set_state(Gst.State.NULL) followed by a self.loop.quit()(self.loop is GLib.MainLoop())
This is acked by:
2024-03-29 12:12:33,939 inference.py INFO : [nvegltransform0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,939 inference.py INFO : [nvdsosd0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,940 inference.py INFO : [nvvideoconvert1] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,940 inference.py INFO : [nvmultistreamtiler0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,941 inference.py INFO : [nvtracker0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,941 inference.py INFO : [nvinfer0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,942 inference.py INFO : [nvstreammux0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,943 inference.py INFO : [capsfilter1] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,943 inference.py INFO : [nvvideoconvert0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,944 inference.py INFO : [videoflip0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,944 inference.py INFO : [jpegdec0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,945 inference.py INFO : [capsfilter0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,945 inference.py INFO : [v4l2src0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,946 inference.py INFO : [source-bin-0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,947 inference.py INFO : [pipeline0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,947 inference.py INFO : [eglglessink0] State changed from PLAYING to PAUSED.
2024-03-29 12:12:33,948 inference.py INFO : [eglglessink0] State changed from PLAYING to READY.
2024-03-29 12:12:33,951 inference.py INFO : [nvegltransform0] State changed from PAUSED to READY.
2024-03-29 12:12:33,953 inference.py INFO : [nvdsosd0] State changed from PAUSED to READY.
2024-03-29 12:12:33,953 inference.py INFO : [nvvideoconvert1] State changed from PAUSED to READY.
2024-03-29 12:12:33,954 inference.py INFO : [nvmultistreamtiler0] State changed from PAUSED to READY.
[NvMultiObjectTracker] De-initialized
2024-03-29 12:12:33,965 inference.py INFO : [nvtracker0] State changed from PAUSED to READY.
2024-03-29 12:12:34,028 inference.py INFO : [nvinfer0] State changed from PAUSED to READY.
2024-03-29 12:12:34,031 inference.py INFO : [nvstreammux0] State changed from PAUSED to READY.
2024-03-29 12:12:34,032 inference.py INFO : [capsfilter1] State changed from PAUSED to READY.
2024-03-29 12:12:34,032 inference.py INFO : [nvvideoconvert0] State changed from PAUSED to READY.
2024-03-29 12:12:34,033 inference.py INFO : [videoflip0] State changed from PAUSED to READY.
2024-03-29 12:12:34,034 inference.py INFO : [jpegdec0] State changed from PAUSED to READY.
2024-03-29 12:12:34,034 inference.py INFO : [capsfilter0] State changed from PAUSED to READY.
2024-03-29 12:12:34,055 inference.py INFO : [v4l2src0] State changed from PAUSED to READY.
2024-03-29 12:12:34,056 inference.py INFO : [source-bin-0] State changed from PAUSED to READY.
2024-03-29 12:12:34,056 inference.py INFO : [pipeline0] State changed from PAUSED to READY.
2024-03-29 12:12:34,092 inference.py INFO : [eglglessink0] State changed from READY to NULL.
2024-03-29 12:12:34,093 inference.py INFO : [nvegltransform0] State changed from READY to NULL.
A subsequent start shows this:
Using winsys: x11
2024-03-29 12:12:40,566 inference.py INFO : [eglglessink1] State changed from NULL to READY.
2024-03-29 12:12:40,567 inference.py INFO : [nvegltransform1] State changed from NULL to READY.
2024-03-29 12:12:40,567 inference.py INFO : [nvdsosd1] State changed from NULL to READY.
2024-03-29 12:12:40,568 inference.py INFO : [nvvideoconvert3] State changed from NULL to READY.
2024-03-29 12:12:40,568 inference.py INFO : [nvmultistreamtiler1] State changed from NULL to READY.
2024-03-29 12:12:40,568 inference.py INFO : [nvtracker1] State changed from NULL to READY.
2024-03-29 12:12:40,568 inference.py INFO : [nvinfer1] State changed from NULL to READY.
2024-03-29 12:12:40,569 inference.py INFO : [nvstreammux1] State changed from NULL to READY.
2024-03-29 12:12:40,569 inference.py INFO : [capsfilter3] State changed from NULL to READY.
2024-03-29 12:12:40,569 inference.py INFO : [nvvideoconvert2] State changed from NULL to READY.
2024-03-29 12:12:40,570 inference.py INFO : [videoflip1] State changed from NULL to READY.
2024-03-29 12:12:40,570 inference.py INFO : [jpegdec1] State changed from NULL to READY.
2024-03-29 12:12:40,570 inference.py INFO : [capsfilter2] State changed from NULL to READY.
2024-03-29 12:12:40,635 inference.py INFO : [v4l2src1] State changed from NULL to READY.
2024-03-29 12:12:40,635 inference.py INFO : [source-bin-0] State changed from NULL to READY.
2024-03-29 12:12:40,636 inference.py INFO : [pipeline1] State changed from NULL to READY.
2024-03-29 12:12:40,636 inference.py INFO : [nvegltransform1] State changed from READY to PAUSED.
2024-03-29 12:12:40,639 inference.py INFO : [nvdsosd1] State changed from READY to PAUSED.
2024-03-29 12:12:40,644 inference.py INFO : [nvvideoconvert3] State changed from READY to PAUSED.
2024-03-29 12:12:40,645 inference.py INFO : [nvmultistreamtiler1] State changed from READY to PAUSED.
What can I do to narrow down the issue?
TIA
