Seems you are using the IP camera. Does the camera’s bandwidth support 10 streams on the same port?
Have you follow the instruction in DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums to set the nvstreammux parameters?
What is your GPU? Can you measure the GPU performance by “nvidia-smi dmon” command when you run the 20 streams case?
