Placa RTX 3060 Mobile
@generix
echo 100 > brightness - > this works. do less brightness
isso vai resolver o problema ?
@Abaabaiohjl Please check if setting the kernel parameter
nvidia.NVreg_EnableBacklightHandler=0
helps. Please post the output of
ls -l /sys/class/backlight
afterwards.
@generix
I keep the pci=realloc, right?
GRUB_CMDLINE_LINUX_DEFAULT=“quiet splash pci=realloc nvidia.NVreg_EnableBacklightHandler=0”
yes.
@generix
Freeze in loading first page after grub menu. Linux mint
Deu certo, muito obrigado
I rebooted twice and back to open but doesn’t work the brightness. And created the file grub.prime-backup
@generix
I’ve been in this situation for days 😭
Does changing brightness work when using the slider in Mint desktop?
here? not works.
@generix
@generix I did “dmseg” and appears this errors:
ACPI BIOS Error (bug): Could not resolve symbol [_SB.PCI0], AE_NOT_FOUND (20210331/dswload2-162)
ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210331/psobject-220)
DPC: RP PIO log size 0 is invalid
@generix I tried kernel 5.15.
but It is worst. the driver doesnt load.
with nvidia-settings the opttions open but appear this:
(nvidia-settings:4569): GLib-GObject-CRITICAL **: 19:41:07.667: g_object_unref: assertion 'G_IS_OBJECT
** Message: 19:41:07.710: PRIME: Requires offloading
** Message: 19:41:07.710: PRIME: is it supported? yes
** Message: 19:41:07.736: PRIME: Usage: /usr/bin/prime-select nvidia|intel|on-demand|query
** Message: 19:41:07.737: PRIME: on-demand mode: “1”
** Message: 19:41:07.737: PRIME: is “on-demand” mode supported? yes
I did too lightdm test mode because the boot is freezing some times in the logo linux mint theme screen. I have to turn off the button and turn it on again to enter the login screen
I think is cinnamon problem. I selected another desktop evironment and works. I tried with ubuntu with wayland. And driver load and brightness works. but i dont like this desktop evironment. lol
but But now that I saw that the card doesn’t work. If I use it to accelerate it crashes in wayland. back to ground zero.
dmesg | grep nvidia
[ 4.344188] nvidia: loading out-of-tree module taints kernel.
[ 4.345359] nvidia: module license ‘NVIDIA’ taints kernel.
[ 4.360107] nvidia-nvlink: Nvlink Core is being initialized, major device number 509
[ 4.361979] nvidia 0000:01:00.0: enabling device (0006 → 0007)
[ 4.365094] nvidia 0000:01:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[ 4.429138] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 510.47.03 Mon Jan 24 22:51:43 UTC 2022
[ 4.622833] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 4.717412] audit: type=1400 audit(1644762986.352:5): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe” pid=749 comm=“apparmor_parser”
[ 4.717415] audit: type=1400 audit(1644762986.352:6): apparmor=“STATUS” operation=“profile_load” profile=“unconfined” name=“nvidia_modprobe//kmod” pid=749 comm=“apparmor_parser”
[ 5.630469] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-4
[ 5.641165] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-4
[ 5.642929] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[ 5.826938] nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
[ 5.829726] nvidia-uvm: Loaded the UVM driver, major device number 506.
SOLVEDDD!!!
purge all in the recovery mode. and put the kernel parameter: acpi_backlight=video
nvidia driver loaded and backlight works!!
ty generix! you are the guy
