Please reopen "[Errno 2] No such file or directory:when ‘tao classification train’ is run" again, it is still not solved
Hi there.
  1. I am retraining the NGC Resnet_50.hdf5
  2. I already completed the tao_voc pascal VCC exercise to familiarise myself with the process
  3. I opened the “[Errno 2] No such file or directory:when ‘tao classification train’ is run” thread when I was trying to use BYOM (mistake)
  4. At that point your advice was
    " MorganhModerator
Aug 16
Refer to TAO Toolkit Launcher — TAO Toolkit 3.22.05 documentation.
For ease, I suggest you to set “source” and “destination” to the same.
5. At that point, your advice fixed the immediate problem.
6. I am now working on the correct model with the correct Jupyter notebook and I have screenshots from the successful pascal VCC exercise to refer to .
7. I have noticed that when I reach this point:
it rewrites my tao_mounts.json, which was as follows before running the cell:
But was rewritten after running the cell. I noted that I could prevent this by changing permissions but I also noticed that in my screenshot from pascal VCC it showed:
“destination”: “/workspace/tao-experiments”, so I carried on.
8. When I reached “tao classification train” it throws:
when I prevent it from rewriting tao_mounts.json it stops the container earlier with an Errno 13 permissions issue
9. There are just 2 changes to the pascal VCC screenshots that I can see: first I have substituted my file called “training_spec.cfg” for the “classification_spec.cfg” in the cell; second I am using “cv_samples_v1.4.1”, whereas the earlier pascal VCC was in “cv_samples_v1.4.0”
Please advise
