I got this error message when I tried to do “make i386=1 x86_64=0”:
ld: warning: in ../../lib/libcutil_i386.a, file is not of required architecture
make -C src/alignedTypes/
Undefined symbols:
"_cutCheckCmdLineFlag", referenced from:
_main in alignedTypes.cu.o
"_cutGetCmdLineArgumenti", referenced from:
"_cutStartTimer", referenced from:
void runTest<RGBA32>(int, int)in alignedTypes.cu.o
void runTest<RGBA32_2>(int, int)in alignedTypes.cu.o
void runTest<unsigned char>(int, int)in alignedTypes.cu.o
void runTest<RGB32>(int, int)in alignedTypes.cu.o
void runTest<LA32>(int, int)in alignedTypes.cu.o
void runTest<unsigned int>(int, int)in alignedTypes.cu.o
void runTest<RGBA8>(int, int)in alignedTypes.cu.o
void runTest<RGBA32_misaligned>(int, int)in alignedTypes.cu.o
void runTest<RGB32_misaligned>(int, int)in alignedTypes.cu.o
void runTest<LA32_misaligned>(int, int)in alignedTypes.cu.o
void runTest<RGBA8_misaligned>(int, int)in alignedTypes.cu.o
void runTest<unsigned short>(int, int)in alignedTypes.cu.o
"_cutCreateTimer", referenced from:
"_cutGetTimerValue", referenced from:
"_cutDeleteTimer", referenced from:
"_cutStopTimer", referenced from:
"_cutResetTimer", referenced from:
ld: symbol(s) not found
collect2: ld returned 1 exit status
make[1]: *** [../../bin/darwin/release/alignedTypes] Error 1
make: *** [src/alignedTypes/Makefile.ph_build] Error 2
I have Snow Leopard 10.6.2, tried to use gcc 4.2 and gcc 4.0 (by changing common.mk), computer: MBR with 9400m
