I am trying to run the Pose demo ( Pose Demo for Jetson/L4T | NVIDIA NGC)
but I get the below error log
Can you kinly let me know what I am missing?
I am on Jetson NX with jetpack 4.4 L4T 32.4.3 .
Thank you!
sudo docker run --runtime nvidia -it --rm --network host -e DISPLAY=$DISPLAY -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/jetson-pose:r32.4.2 python3 run_pose_pipeline.py /videos/pose_video.mp4 --loop
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_caps_is_empty: assertion ‘GST_IS_CAPS (caps)’ failed
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_caps_truncate: assertion ‘GST_IS_CAPS (caps)’ failed
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_caps_fixate: assertion ‘GST_IS_CAPS (caps)’ failed
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_caps_get_structure: assertion ‘GST_IS_CAPS (caps)’ failed
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_structure_get_string: assertion ‘structure != NULL’ failed
(python3:1): GStreamer-CRITICAL **: 12:18:00.483: gst_mini_object_unref: assertion ‘mini_object != NULL’ failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 960x544 (x 11), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 960, nFrameHeight = 540
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (896) open OpenCV | GStreamer warning: unable to query duration of stream
[ WARN:0] global /home/nvidia/host/build_opencv/nv_opencv/modules/videoio/src/cap_gstreamer.cpp (933) open OpenCV | GStreamer warning: Cannot query video position: status=1, value=5, duration=-1Using winsys: x11
[TensorRT] ERROR: coreReadArchive.cpp (38) - Serialization Error in verifyHeader: 0 (Version tag does not match)
[TensorRT] ERROR: INVALID_STATE: std::exception
[TensorRT] ERROR: INVALID_CONFIG: Deserialize the cuda engine failed.
File “run_pose_pipeline.py”, line 37, in
engine = PoseEngine(ENGINE_PATH)
File “/pose/pose.py”, line 86, in init
self.module.load_state_dict(torch.load(path))
File “/usr/local/lib/python3.6/dist-packages/torch/nn/modules/module.py”, line 830, in load_state_dict
load(self)
File “/usr/local/lib/python3.6/dist-packages/torch/nn/modules/module.py”, line 825, in load
state_dict, prefix, local_metadata, True, missing_keys, unexpected_keys, error_msgs)
File “/usr/local/lib/python3.6/dist-packages/torch2trt/torch2trt.py”, line 309, in _load_from_state_dict
self.context = self.engine.create_execution_context()
AttributeError: ‘NoneType’ object has no attribute ‘create_execution_context’
