Thanks for the sharing! what is SMI tool? how did you start the application? are you using nvinfer or nvinferserver?
- could help to narrow down this issue? for example, simplifying the code, using fakesink or “nvinfer + fakesink” to find which NV plugin has memory leak.
- please refer to this topic. can you provide more logs by nvmemstat ? it can save the memory usage at intervals. can you provide more valgrind logs by this method vagrid ? it can give memory leak details.
