Possible memory leak in the sample apps
• DeepStream Version 6.0
I made an app with yolov5 in deepstream on a jetson agx. We put the agx in the production site and ideally want to run it indefinitely. However the app stops after a few hours.
My question is if it is even possible to expect a deepstream app to run indefinitely on an RTSP input or would it need periodic restarts ?. Currently we restart the app after every two hours and we would like to avoid this.
To reproduce this issue you could just let a deepstream app run till it crashes. It should crash with the time for how long it ran based on the model. The heavier the earlier I think
This is not the correct behavior, can you describe your pipeline in details?
Please also provide complete information as applicable to your setup.
• TensorRT Version
• The pipeline being used
Did your app support rtsp reconnect? if not, when network unavailable, the pipeline will stop running. you can refer to deepstream_source_bin.c for rtsp reconnect.
You also can monitor the memory usage if the issue caused by mem leak. please refer to DeepStream SDK FAQ - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums, the script is for Jetson, but you can just have your attention on software memory usage if you are on dGPU. for dGPU, hardware memory usage, you can check nvidia-smi -l 1
