Test settings
System: Host: - Kernel: 5.11.0-25-generic x86_64 bits: 64 compiler: gcc v: 10.2.1 Desktop: GNOME 3.38.4
tk: GTK 3.24.25 wm: gnome-shell dm: GDM3 Distro: Ubuntu 21.04 (Hirsute Hippo)
CPU: Info: 6-Core model: Intel Core i7-8750H bits: 64 type: MT MCP arch: Kaby Lake note: check rev: A L2 cache: 9 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 52799
Speed: 2800 MHz min/max: 800/4100 MHz Core speeds (MHz): 1: 2800 2: 2800 3: 2800 4: 2130 5: 2800 6: 2642 7: 2742
8: 2761 9: 2782 10: 2628 11: 2691 12: 2710
Graphics: Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3e9b
Device-2: NVIDIA GP107M [GeForce GTX 1050 Ti Mobile] vendor: ASUSTeK driver: nvidia v: 470.57.02 bus ID: 01:00.0
chip ID: 10de:1c8c
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus ID: 1-7:3 chip ID: 13d3:5666
Display: x11 server: X.Org 1.20.11 compositor: gnome-shell driver: loaded: modesetting,nvidia
unloaded: fbdev,nouveau,vesa resolution: 1: 1920x1080~120Hz 2: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Description
The following code containing an array affectation before a ternary operator seems to return a wrong result.
#version 450
layout(local_size_x = 1, local_size_y = 1, local_size_z = 1) in;
layout(std430, binding = 0) buffer buffer_0 {
int ext_0[2]; // 0 1
void main()
bvec2 var_0[2] = bvec2[2](bvec2(true), bvec2(true));
var_0 = bvec2[2](bvec2(true, false), bvec2(false, true));
ext_0[0] = var_0[ext_0[1]].r ? 1 : 2;
NVIDIA output:
buffer_0 1 1
Expected output:
buffer_0 2 1
Thinking process:
ext_0[1]=1sovar_0[1]is examinedvar_0[1].r = falseso 2 is returned
Code link
For the related code in the shadertrap test format, see: shader22.shadertrap (729 Bytes)
Shadertrap is a testing framework. To use the shadetrap code,
- Get or build Shadertrap:
- A build version of Shadertrap for linux can be found on Shadertrap release repository.
- To build from source, please refer to Shadertrap repository
- Ge the shader file
- Execute the Shadertrap command
bin/shadertrap shader22.shadertrap
- Collect the results, one file per buffer
