My aim is to power the TX2 using a battery for 24 hours, to record some datasets. After reading the forums, the power requirements of the TX2 seem to be 12V and roughly 1A, though the adapter that comes with the developer kit supplies a 19V 4.75A current.
You may need to add a large capacitor close to the barrel connector. 12V should work fine, but I think Jetsons are a bit sensitive to the initial current draw.
I have used 12V to power the Jetson (even a 11.1V LiPo battery) and it’s worked fine.
I did find that one of the 5.5mm barrel connectors I had did not have a good fit on the interior pin, so that’s worth checking.
However, if the red LED comes on, that should indicate contact.
Also, the 1A draw depends a lot on what the Jetson is doing. If running full tilt with all CPUs and GPU, and all of the peripherals on the motherboard working, then you can see > 1A. If you’re mainly sitting idle with a load of 0.1 and not much going on, it will draw much less.
These are all “of course I did that” things, but it bears checking again:
Is the 12V battery actually charged?
Are you using sufficiently low-gauge wires? (20 Gauge should be enough; thin stuff like 28 or 32 probably won’t be.)
Did you actually push the right power-on button?
Did you hold it down enough and wait long enough for power-on?
Is the Jetson module properly seated onto the motherboard?
Has your motherboard or Jetson module been in contact with any kind of metal, that could have caused a short and burned some part?
Good luck on the project, and please let us know whatever you find!
A large capacitor near the connector is for no other reason than to provide a momentary current source for power spikes at the moment of turning on the Jetson. This is something a few people have noticed helps when using other power sources as increasing reliability. I don’t think normal operation is as sensitive to power requirements as is the moment of turning on the Jetson.
I have noticed the Jetson not being happy with large swings in input voltage. It’s OK with a wide variety of input voltages, as long as the voltage only changes slowly.
With 25 gauge wire, it’s possible (not super likely, but not impossible) that the inrush current when turning it on would cause enough voltage drop that it wouldn’t run.
The “6A” rating for 25 gauge wire depends on a lot of assumptions related to amperage, cooling, environment, and so forth. It also depends on how long the wire is.
However, I don’t get where you get the 6A value from. Standar ratings for copper wire at 25 gauge says 2.7A chassis wiring, 0.5A transmission wiring. Resistance will be 0.11 Ohms per meter. If inrush current is 20 A (just momentarily) and you use a meter of wire, then you will drop 2V during the turn-on event, which might be enough to cause it to refuse to turn on.
This is all speculation, though – please let us know what you find, because I’m curious :-)
