Hello!
JetPack 4.5.1. When trying to run the Gstreamer pipeline with nveglglessink output, the image does not display:
gst-launch-1.0 --gst-debug-level=3 videotestsrc ! video/x-raw,width=640,height=480 ! videoconvert ! nveglglessink -e
Error log:
Using winsys: x11
0:00:00.203409843 7788 0x5583e76e00 ERROR egladaption gstegladaptation_egl.c:155:gst_egl_adaptation_init_display:<eglglessink0> Could not get EGL display connection
0:00:00.203464166 7788 0x5583e76e00 ERROR egladaption gstegladaptation_egl.c:196:gst_egl_adaptation_init_display:<eglglessink0> Couldn't setup window/surface from handle
0:00:00.203490521 7788 0x5583e76e00 ERROR nveglglessink gsteglglessink.c:566:egl_init:<eglglessink0> Couldn't init EGL display
0:00:00.203512500 7788 0x5583e76e00 ERROR nveglglessink gsteglglessink.c:592:egl_init:<eglglessink0> Failed to perform EGL init
The xvimagesink method works good:
gst-launch-1.0 --gst-debug-level=3 videotestsrc ! video/x-raw,width=640,height=480 ! videoconvert ! xvimagesink
The nvoverlaysink method works, but with the same error in the log:
gst-launch-1.0 --gst-debug-level=3 videotestsrc ! video/x-raw,width=640,height=480 ! videoconvert ! nvoverlaysink
nvbuf_utils: Could not get EGL display connection
nvbuf_utils: ERROR getting proc addr of eglCreateImageKHR
nvbuf_utils: ERROR getting proc addr of eglDestroyImageKHR
0:00:00.066278693 9091 0x557cbfcf00 WARN omx gstomx.c:2826:plugin_init: Failed to load configuration file: Valid key file could not be found in search dirs (searched in: /home/cnvs/.config:/etc/xdg/xdg-unity:/etc/xdg as per GST_OMX_CONFIG_DIR environment variable, the xdg user config directory (or XDG_CONFIG_HOME) and the system config directory (or XDG_CONFIG_DIRS)
What I tried to do:
- export DISPLAY=:0 (export DISPLAY=:1, unset DISPLAY)
- Disabled SSH X11Forwarding in /etc/ssh/sshd_config
- Disabled X11VNC server (run Gstreamer using the keyboard)
- Added a section in /etc/X11/xorg.conf
Section "Screen"
Identifier "Screen0"
Monitor "Monitor0"
SubSection "Display"
Viewport 0 0
Modes "1024x600"
Depth 24
Virtual 1024 600
EndSubSection
EndSection
String from var/log/Xorg.0.log:
[ 19.152] (II) NVIDIA(0): Setting mode "HDMI-0: nvidia-auto-select @1024x600 +0+0 {ViewPortIn=1024x600, ViewPortOut=1024x600+0+0}"
- How can I fix this problem?
- Which works faster on Jetson Nano - nveglglessink or xvimagesink?
