Deepstream 6.3 python
• Hardware Platform (Jetson / GPU) : NVIDIA GeForce RTX 3090
• DeepStream Version: 6.3
• TensorRT Version : 12.2
• NVIDIA GPU Driver Version (valid for GPU only) : 535.104.05
run deepstream docker container using below line
sudo docker run --name deepstream-app-6.3-x -it --rm --net=host --gpus all -e DISPLAY=$DISPLAY --device /dev/snd -v /tmp/.X11-unix/:/tmp/.X11-unix nvcr.io/nvidia/deepstream:6.3-samples
then inside container run deepstreamtest1 app
GST_DEBUG=3 python3 deepstream_test_1.py /opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_720p.h264
Output:
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream-6.3/samples/streams/sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
Starting pipeline
MoTTY X11 proxy: Unsupported authorisation protocol
0:00:02.062647747 4197 0x19df920 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display: Could not init EGL display connection
0:00:02.062680278 4197 0x19df920 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display: EGL call returned error 3000
0:00:02.062691018 4197 0x19df920 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display: Couldn’t setup window/surface from handle
0:00:02.062695078 4197 0x19df920 ERROR nveglglessink ext/eglgles/gsteglglessink.c:536:egl_init: Couldn’t init EGL display
0:00:02.062698738 4197 0x19df920 ERROR nveglglessink ext/eglgles/gsteglglessink.c:562:egl_init: Failed to perform EGL init
Appreciate your help to fix this issue
I guess when you start the docker image, xhost + is not executed.
Allow external applications to connect to the host’s X display:
xhost +
I executed xhost + and facing same issue
Are you running the command in ssh? Deepstream does not support x11-forwarding.
when you run the following command line, can you get output ?
echo $DISPLAY
output from echo $DISPLAY
localhost:11.0
Please disable local x11-server .
After these, If you have plugged a display on your server, try export DISPLAY=:0 in your ssh.
If you don’t have a monitor, try modify nveglglessink to fakesink
when I setted DISPLAY=0
then run xhost +
it gives error as below
xhost: unable to open display “0”
What is the output of xrandr ?
Just set the value of DISPLAY to the screen index of xrandr output.
It’s 0/1 usually.
it didn’t work, so I changed pipeline to support filesink instead of display
Ok,Filesink or Fakesink will also work well in the pipeline.
If need further support,please open a new topic, Thanks.
