How to run DeepStream6.2 people tracking sample?
"I want to execute tracking as shown in the blog link below using NVIDIA DeepStream 6.2 sample. Can you tell me how?
Blog Link: https://developer.nvidia.com/blog/state-of-the-art-real-time-multi-object-trackers-with-nvidia-deepstream-sdk-6-2/
My setup environment is as follows:
  1. OS: Ubuntu 20.04
  2. CUDA: 12.2
  3. Driver Version: 535.86.10
  4. Using Docker
I followed the README and utilized the files under “/opt/nvidia/deepstream/deepstream/samples/configs/deepstream-app” subdirectory.
I executed the command below from this location. However, I encountered an error.
Command:
deepstream-app -c source30_1080p_dec_infer-resnet_tiled_display_int8.txt --gst-debug-level=3
The error message is as follows:
0:00:00.058576017 1486 0x5603dd6cc030 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:160:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Could not...
0:00:00.058601065 1486 0x5603dd6cc030 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:183:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> EGL call...
0:00:00.058604251 1486 0x5603dd6cc030 ERROR egladaption ext/eglgles/gstegladaptation_egl.c:185:gst_egl_adaptation_init_display:<sink_sub_bin_sink1> Couldn't...
0:00:00.058606515 1486 0x5603dd6cc030 ERROR nveglglessink ext/eglgles/gsteglglessink.c:537:egl_init:<sink_sub_bin_sink1> Couldn't init EGL display...
0:00:00.058608790 1486 0x5603dd6cc030 ERROR nveglglessink ext/eglgles/gsteglglessink.c:563:egl_init:<sink_sub_bin_sink1> Failed to perform EGL init...
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
nvstreammux: Successfully handled EOS for source_id=0
App run failed."
How can I run DeepStream6.2 sample???
How do you run the docker ? Can you share command line ?
If you want display in Docker, Maybe you can refer this link
xhost +
docker run --gpus all -it --rm --net=host --privileged -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /opt/nvidia/deepstream/deepstream-6.2  yourdockerimage
There is no update from you for a period, assuming this is not an issue anymore
Hence we are closing this topic. If need further support, please open a new one. Thanks
