Pre trained model for RT-DETR
RT-DETR is now available in TAO 6.0 and I’ve started to play with the training. In the config file you can specify a pre-trained model path.
Is NVIDIA planning to release any pre trained models on NGC? At the moment there is none?
Thank you
You can refer to tao_pytorch_backend/nvidia_tao_pytorch/cv/rtdetr/model/backbone at main · NVIDIA/tao_pytorch_backend · GitHub for the supported backbones.
For example, pretrained models of ConvNextV2 are in Pretrained ConvNeXtV2 | NVIDIA NGC ,
pretrained models of C-RADIOv2 are in https://catalog.ngc.nvidia.com/orgs/nvidia/teams/tao/models/cradiov2/files
Thanks. I know about the available backbones, I have been doing some experiment with Resnet50.
What I was asking for is about the full pertained RT-DETR model. For example pre-trained on COCO.
Also that link doesn’t work:
And there are no C-RADIOv2 models available on NGC.
This kind of pretrained model is not available.
Please select an org to check again. Currently, you are still on the “welcome Guest” stage according to the top right corner.
