• Hardware Platform (Jetson / GPU) RTX3090
• DeepStream Version 7.0
• TensorRT Version DEEPSTERAM 7.0 ISNTALLAITON
• NVIDIA GPU Driver Version (valid for GPU only) 535
**• Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
i wanna know more about async and som other thing in deepstream:
1- does secondary and primary always which can be detection or classification model have a same frame_num? even if we use async mode or nvinfer interval property
2- what will hapend to kafkabroker if i use async mode? will it wait until get result and then send the whole frame or not**
3- in this code in deepstream gst-nvinfer source code:
if (nvinfer->classifier_async_mode) {
/\* Asynchronous mode. Push the buffer immediately instead of waiting for \* the results. \*/
nvtxDomainRangeEnd(nvinfer->nvtx_domain, buf_process_range);
nvds_set_output_system_timestamp(inbuf, GST_ELEMENT_NAME(nvinfer));
GstFlowReturn flow_ret = gst_pad_push (GST_BASE_TRANSFORM_SRC_PAD (nvinfer), inbuf);
if (nvinfer->last_flow_ret != flow_ret) {
switch (flow_ret) {
/\\\* Signal the application for pad push errors by posting a error message \\\* on the pipeline bus. \\\*/case GST_FLOW_ERROR:
case GST_FLOW_NOT_LINKED:
case GST_FLOW_NOT_NEGOTIATED:
GST_ELEMENT_ERROR (nvinfer, STREAM, FAILED,
("Internal data stream error."), ("streaming stopped, reason %s (%d)", gst_flow_get_name (flow_ret), flow_ret));break;
default:
break;
nvinfer->last_flow_ret = flow_ret;
return flow_ret;
} else {
/\* Queue a push buffer batch. This batch is not inferred. This batch is to \* signal the input-queue and output thread that there are no more batches \* belonging to this input buffer and this GstBuffer can be pushed to \* downstream element once all the previous processing is done. \*/ buf_push_batch = new GstNvInferBatch;
buf_push_batch->inbuf = inbuf;
buf_push_batch->push_buffer = TRUE;
buf_push_batch->nvtx_complete_buf_range = buf_process_range;
g_mutex_lock (&nvinfer->process_lock);
if (nvinfer->input_queue_thread)
g_queue_push_tail (nvinfer->input_queue, buf_push_batch);
else
g_queue_push_tail (nvinfer->process_queue, buf_push_batch);
g_cond_broadcast (&nvinfer->process_cond);
g_mutex_unlock (&nvinfer->process_lock);
what will happend if inference didn’t compelete before nvdsosd and nvmsgbroker?
