I need to combine pose estimation and yolo on the deepstream now. I already ref the article, and I can use yolo or pose estimation Individually.
Nevertheless, I still don’t understand how to combine them.
Whether to use primary_gie and secondary-gie0 for solving the problem?
Because I add pose estimation to [primary-gie] config, and yolo to [secondary-gie0] config, but secondary-gie0 don’t run successfully.
Or can I use two primary_gie for solving the problem?
Can I ref which problem or article? I can’t understand the using methods of [primary-gie] between [secondary-gie0].
In terms of “combine”, you mean cascading two GIEs, one for yolo and the other for pose-estimation and not retrieving yolo’s bbox info for the pose-estimation? Because this is the case I did.
In this scenario, you can use either GIEs for yolo or pose-estimation and get meta data by adding two probes on relevant src-pad.
Maybe you forgot to enable “output-tensor-meta” for the pose-estimation GIE?
In terms of “combine”, you mean cascading two GIEs, one for yolo and the other for pose-estimation.
====>Yes, this my meaning.
=====>I understand I can add them to test1~5.app example.
I already ref your article code, but it’s deepstream.app.I don’t understand how to add them to where.
You can set this property in “deepstream_primerary(or secondary)_gie_bin.c” file or you can set it in deepstream-app config file.
===> Sorry, I can’t understand your meaning, how to set it in deepstream-app config file?
I already ref /opt/nvidia/deepstream/deepstream-5.0/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
But I still can’t use yolo and pose estimation together. The following is my config, please check it , thank you.
Actually, I don’t understand how to enable “output-tensor-meta” for the pose-estimation GIE on deepstream-app config file. If you agree, would you mind to share your config and code about “output-tensor-meta”.
The following image is correct? But I still only primary_gie output, can’t see secondary_gie. I sure I aready update to .o file.
