x86 • DeepStream Version
6.4 • JetPack Version (valid for Jetson only)
none • TensorRT Version
8.6 • NVIDIA GPU Driver Version (valid for GPU only)
544 • Issue Type( questions, new requirements, bugs)
requirements • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing)
the official demo is here.
that is good,but it does NOT print the secondary model output info.
In the demo,there 4 “nvinfer” instances:
pgie:4-classes detector,in the demo(python script),it can print the object details,it’s good.
sgie1:classifier for vehicle maker,there’s no output info,it’s NOT good.
sgie2:classifier for vehicle type,there’s no output info,it’s NOT good.
sgie3:classifier for vehicle color,there’s no output info,it’s NOT good.
Could you please provide a sample code ,which can print all the secondary classifiers’ infor?
I have fixed it.thanks.
the key is secondary infer needs "classifier-async-mode=0“
while l_frame is not None:
try:
# Note that l_frame.data needs a cast to pyds.NvDsFrameMeta
# The casting is done by pyds.NvDsFrameMeta.cast()
# The casting also keeps ownership of the underlying memory
# in the C code, so the Python garbage collector will leave
# it alone.
except StopIteration:
break
frame_number = frame_meta.frame_num
num_rects = frame_meta.num_obj_meta
l_obj = frame_meta.obj_meta_list
while l_obj is not None:
try:
# Casting l_obj.data to pyds.NvDsObjectMeta
obj_meta = pyds.NvDsObjectMeta.cast(l_obj.data)
break
#### iter classifier info
print("==== obj_label ",obj_meta.obj_label,
"unique_component_id ",obj_meta.unique_component_id ,
"class_id ",obj_meta.class_id ,
l_classifier = obj_meta.classifier_meta_list
l_user = obj_meta.obj_user_meta_list
print("==== l_classifier ",l_classifier)
print("==== l_user ",l_user)
print("==== misc_obj_info ",obj_meta.misc_obj_info)
if obj_meta.class_id>-1:
obj_counter[obj_meta.class_id] += 1
try:
l_obj = l_obj.next
break
while l_classifier is not None:
try:
print("===== cvt classifier_meta ", l_classifier)
classifier_meta = pyds.NvDsClassifierMeta.cast(l_classifier.data)
print("===== num_labels ", classifier_meta.num_labels)
l_label = classifier_meta.label_info_list
while l_label is not None:
try:
label_meta = pyds.NvDsLabelInfo.cast(l_label.data)
print("======= label num_classes", label_meta.num_classes)
print("======= label result_label", label_meta.result_label)
print("======= label result_class_id", label_meta.result_class_id)
print("======= label label_id", label_meta.label_id)
print("======= label result_prob", label_meta.result_prob)
break
try:
l_label = l_label.next
break
break
try:
l_classifier = l_classifier.next
break
# Acquiring a display meta object. The memory ownership remains in
# the C code so downstream plugins can still access it. Otherwise
# the garbage collector will claim it when this probe function exits.
display_meta = pyds.nvds_acquire_display_meta_from_pool(batch_meta)
display_meta.num_labels = 1
py_nvosd_text_params = display_meta.text_params[0]
# Setting display text to be shown on screen
# Note that the pyds module allocates a buffer for the string, and the
# memory will not be claimed by the garbage collector.
# Reading the display_text field here will return the C address of the
# allocated string. Use pyds.get_string() to get the string content.
py_nvosd_text_params.display_text = "Frame Number={} Number of Objects={} Vehicle_count={} Person_count={}".format(
frame_number,
num_rects,
obj_counter[PGIE_CLASS_ID_VEHICLE],
obj_counter[PGIE_CLASS_ID_PERSON])
# Now set the offsets where the string should appear
py_nvosd_text_params.x_offset = 10
py_nvosd_text_params.y_offset = 12
# Font , font-color and font-size
py_nvosd_text_params.font_params.font_name = "Serif"
py_nvosd_text_params.font_params.font_size = 10
# set(red, green, blue, alpha); set to White
py_nvosd_text_params.font_params.font_color.set(1.0, 1.0, 1.0, 1.0)
# Text background color
py_nvosd_text_params.set_bg_clr = 1
# set(red, green, blue, alpha); set to Black
py_nvosd_text_params.text_bg_clr.set(0.0, 0.0, 0.0, 1.0)
# Using pyds.get_string() to get display_text as string
print(pyds.get_string(py_nvosd_text_params.display_text))
pyds.nvds_add_display_meta_to_frame(frame_meta, display_meta)
try:
l_frame = l_frame.next
break
one more thing,in my scenario,there are 9 vehicle are detected,but
only one vehicle is procressed with the sceondary ‘infer’ instance (vehicle make classifier).
Could you help to fix it?
the log is
ssh://root@localhost:4422/usr/bin/python3 -u /root/host_dir/Documents/workbench__/deepstream_python_apps/apps/deepstream-test2/deepstream_test_1_primary_secondary_infer_1image.py /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Creating EGLSink
Playing file /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg
Adding elements to Pipeline
Linking elements in the Pipeline
/root/host_dir/Documents/workbench__/deepstream_python_apps/apps/deepstream-test2/deepstream_test_1_primary_secondary_infer_1image.py:350: DeprecationWarning: Gst.Element.get_request_pad is deprecated
sinkpad = streammux.get_request_pad("sink_0")
Starting pipeline
Running in WSL
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage and speed up TensorRT initialization. See "Lazy Loading" section of CUDA documentation https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#lazy-loading
0:00:09.383436249 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 2]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input_1 3x224x224
1 OUTPUT kFLOAT predictions/Softmax 20x1x1
0:00:09.568054995 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary1-nvinference-engine> NvDsInferContext[UID 2]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 2]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/models/Secondary_VehicleMake/resnet18_vehiclemakenet.etlt_b16_gpu0_int8.engine
0:00:09.597006703 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary1-nvinference-engine> [UID 2]: Load new model:mod_dstest2_sgie1_config.txt sucessfully
0:00:09.598867604 2705 0x556d2ee2df80 WARN nvinfer gstnvinfer.cpp:679:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1243> [UID = 1]: Warning, OpenCV has been deprecated. Using NMS for clustering instead of cv::groupRectangles with topK = 20 and NMS Threshold = 0.5
0:00:16.180235580 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x544x960
1 OUTPUT kFLOAT output_bbox/BiasAdd 16x34x60
2 OUTPUT kFLOAT output_cov/Sigmoid 4x34x60
0:00:16.363474287 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<primary-inference> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-6.4/samples/models/Primary_Detector/resnet18_trafficcamnet.etlt_b30_gpu0_int8.engine
0:00:16.411858766 2705 0x556d2ee2df80 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary-inference> [UID 1]: Load new model:mod_dstest2_pgie_config.txt sucessfully
BUS: type <flags GST_MESSAGE_STATE_CHANGED of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_STREAM_STATUS of type Gst.MessageType>
nvstreammux: Successfully handled EOS for source_id=0
==== obj_label person unique_component_id 1 class_id 2
==== l_classifier None
==== l_user None
==== misc_obj_info [0 0 0 0]
==== l_user None
==== l_user None
==== l_user None
==== l_user None
==== obj_label car unique_component_id 1 class_id 0
==== l_user None
==== l_user None
==== l_classifier <pyds.GList object at 0x7f9eb9938cf0>
==== l_user None
===== cvt classifier_meta <pyds.GList object at 0x7f9eb9938cf0>
===== num_labels 1
======= label num_classes 0
======= label result_label ford
======= label result_class_id 6
======= label label_id 0
======= label result_prob 0.7562492489814758
==== l_user None
==== l_user None
==== l_user None
==== l_user None
==== l_user None
==== l_user None
Frame Number=0 Number of Objects=14 Vehicle_count=9 Person_count=5
batch_user_meta_list %s None
BUS: type <flags GST_MESSAGE_STREAM_START of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_TAG of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_ASYNC_DONE of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_LATENCY of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_NEW_CLOCK of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_ELEMENT of type Gst.MessageType>
BUS: type <flags GST_MESSAGE_EOS of type Gst.MessageType>
End-of-stream
End-of-stream
Process finished with exit code 0
