Problème windows 10
bonjour je voudrai savoir si nvidia geforce 6150se nfora 430 si il est compatible avec windows 10 merci d’avance de votre réponse
yes but please edit your ? because there is no geforce 430 6150se its a nvidia chipset called Nforce430 with onbaord gpu geforce6150se
so you need to navigate to the nforce drivers not gforce
it will probably be nview 15.xxx
