Problem about Accelerated Decode with ffmpeg
您好!
我们公司现在在使用NVIDIA Jetson Xavier NX,
现在我们想在NVIDIA Jetson Xavier NX 上利用ffmpeg4.2支持NVIDIA硬件加速来实现编解码功能, 以便减少视频播放延时大的问题。
我们查了NVIDIA的官网,根据官网介绍(Accelerated Decode with ffmpeg — Jetson Linux<br/>Developer Guide 34.1 documentation):
Decode Functional Flow
This section describes the function flow of the ffmpeg decoding process:
Call nvv4l2dec_init_decoder() to create a new V4L2 Video Decoder object on the device node /dev/nvhost-nvdec.
Call subscribe_event() to subscribe to resolution change events.
Call set_output_plane_format() to set the format on the output plane.
Call capture_thread() to start a capture thread.
Call set_capture_plane_format() to set the format on the capture plane.
Call nvv4l2dec_decode() to read buffers from ffmpeg and start the decode process.
Call nvv4l2dec_decoder_get_frame() to get the hardware-accelerated decoded data and pass it to ffmpeg for dumping.
Call nvv4l2dec_decoder_close() to destroy the buffers and close the device.
我们从NVIDIA官网上下载了Video_Codec_SDK_10.0.26.zip源代码,但是该源代码中没有发现有上面介绍的这些接口函数。
ffmpeg4.2.8源代码中也没有发现有上面介绍的这些接口函数。
  1. 请问这些函数接口在哪个库中包含的?
  2. 可否给我们提供上面的这些接口函数的使用例子代码?
我们的项目很紧急,请尽快给我们答复。
谢谢!
Video Codec SDK is not supported on Jetson platforms. We have a package to enable hardware decoding with jetson_multimedia_api. Please check
Jetson TX2 and FFmpeg - Can't initialize nvrm channel - #5 by DaneLLL
Hardware accelerated video playback with L4T ffmpeg - #7 by DaneLLL
您好!
我按照您提供的Jetson TX2 and FFmpeg - Can’t initialize nvrm channel - #5 by DaneLLL
已经成功的编译好ffmpeg-4.2.7,make && make install
并且可以正常运行ffmpeg命令。
我运行 ./ffmpeg -decoders命令 时,打印信息如下:
root@nvidia-desktop:/home/nvidia/working-fu/ffmpeg-4.2.7-nvidia# ./ffmpeg -decoders | grep nvv4l2
ffmpeg version 4.2.7 Copyright (c) 2000-2022 the FFmpeg developers
built with gcc 7 (Ubuntu/Linaro 7.5.0-3ubuntu1~18.04)
configuration: --enable-nvv4l2dec --enable-libv4l2 --extra-libs=‘-L/usr/lib/aarch64-linux-gnu/tegra -lnvbuf_utils’ --extra-cflags=‘-I /usr/src/jetson_multimedia_api/include/’
libavutil 56. 31.100 / 56. 31.100
libavcodec 58. 54.100 / 58. 54.100
libavformat 58. 29.100 / 58. 29.100
libavdevice 58. 8.100 / 58. 8.100
libavfilter 7. 57.100 / 7. 57.100
libswscale 5. 5.100 / 5. 5.100
libswresample 3. 5.100 / 3. 5.100
V… h264_nvv4l2dec h264 (nvv4l2dec) (codec h264)
V… hevc_nvv4l2dec hevc (nvv4l2dec) (codec hevc)
V… mpeg2_nvv4l2dec mpeg2 (nvv4l2dec) (codec mpeg2video)
V… mpeg4_nvv4l2dec mpeg4 (nvv4l2dec) (codec mpeg4)
可以看到ffmpeg-4.2.7的解码器有:
但是我运行 ./ffmpeg -hwaccels命令时,打印信息如下:
root@nvidia-desktop:/home/nvidia/working-fu/ffmpeg-4.2.7-nvidia# ./ffmpeg -hwaccels
Hardware acceleration methods:
Hardware acceleration methods: 显示是空的,也就是说没有硬件加速的???
这样还可以实现ffmpeg硬件加速编解码视频图像吗?
Hardware decoding should be enabled. You may run this command:
ffmpeg-4.2.2$ ./ffmpeg -c:v h264_nvv4l2dec -i /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4 a.yuv
And execute sudo tegrastats to check if NVDEC is up and running.
您好!
我成功编译ffmpeg-4.2.7后,是可以正常运行fffmpeg命令来实现解码的。
fffmpeg命令实现解码运行后的打印信息如下:
ffmpeg-4.2.7-nvidia# ./ffmpeg -c:v h264_nvv4l2dec -i /home/working-video/video-decenc-test/test_cut.h264 -r 30 -y /home/working-video/video-decenc-test/video-dec%03d.jpg
Input #0, h264, from ‘/home/working-video/video-decenc-test/test_cut.h264’:
Duration: N/A, bitrate: N/A
Stream #0:0: Video: h264 (Constrained Baseline), yuv420p(progressive), 1920x1080, 25 fps, 25 tbr, 1200k tbn, 50 tbc
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Stream mapping:
Stream #0:0 → #0:0 (h264 (h264_nvv4l2dec) → mjpeg (native))
Press [q] to stop, [?] for help
[swscaler @ 0x557f4fbc60] deprecated pixel format used, make sure you did set range correctly
Output #0, image2, to ‘/home/working-video/video-decenc-test/video-dec%03d.jpg’:
Metadata:
encoder : Lavf58.29.100
Stream #0:0: Video: mjpeg, yuvj420p(pc), 1920x1080, q=2-31, 200 kb/s, 25 fps, 25 tbn, 25 tbc
Metadata:
encoder : Lavc58.54.100 mjpeg
Side data:
cpb: bitrate max/min/avg: 0/0/200000 buffer size: 0 vbv_delay: -1
frame= 75 fps= 15 q=24.8 Lsize=N/A time=00:00:03.00 bitrate=N/A dup=11 drop=10 speed=0.61x
但是我修改./configure, 在原来基础上增加了–enable-nvdec --enable-nvenc --enable-cuda --enable-cuvid, 结果./configure 报错误。
接着我继续修改./configure, 在原来基础上只增加了–enable-nvdec --enable-nvenc, 结果./configure 还是报错误。
难道NVIDIA Jetson Xavier NX不支持enable-cuda 和 enable-cuvid???
也不支持enable-nvdec 和enable-nvenc???
我们的项目很紧急,请尽快给我们答复。
谢谢!
您好!
我编译好ffmpeg-4.2.7后,是可以正常运行./ffmpeg -c:v h264_nvv4l2dec -i /opt/nvidia/deepstream/deepstream-5.0/samples/streams/sample_720p.mp4 a.yuv命令来解码的。
但是我修改./configure,在原来基础./configure --enable-nvv4l2dec --enable-libv4l2 --extra-libs=“-L/usr/lib/aarch64-linux-gnu/tegra -lnvbuf_utils” --extra-cflags=“-I /usr/src/jetson_multimedia_api/include/”
上增加了 --enable-nvdec --enable-nvenc --enable-cuda --enable-cuvid,./configure报错误,
后来我修改./configure,在原来基础上只增加–enable-nvdec --enable-nvenc,./configure还是报错误
请问:NVIDIA Jetson Xavier NX不支持enable-cuda 和 enable-cuvid???
也不支持enable-nvdec 和enable-nvenc ???
我们的项目很紧急,请尽快给我们答复。
谢谢!
您好!
我下载、编译、安装好了NVIDIA的ffmpeg,然后运行基于 NVDEC的硬件加速解码的ffmpeg命令,输出信息如下:
ffmpeg-4.2.7-nvidia/bin# ./ffmpeg -c:v h264_nvv4l2dec -i /home/working-video/700818_023723.h264 -r 30 -y /home/working-video/video-harddec-test/video-dec%03d.jpg
configuration: --enable-nvv4l2dec --enable-libv4l2 --enable-shared --optflags=-O3 --extra-libs=‘-L/usr/lib/aarch64-linux-gnu/tegra -lnvbuf_utils’ --extra-cflags=‘-I /usr/src/jetson_multimedia_api/include/’ --enable-rpath --prefix=/opt/nvidia/ffmpeg-4.2.7-nvidia
Stream mapping:
Output #0, image2, to ‘/home/working-video/working-video-dec/video-harddec-test/video-dec%03d.jpg’:
Metadata:
Stream #0:0: Video: mjpeg, yuvj420p(pc), 1920x1080, q=2-31, 200 kb/s, 30 fps, 30 tbn, 30 tbc
Metadata:
Side data:
frame= 3879 fps= 18 q=24.8 Lsize=N/A time=00:02:09.30 bitrate=N/A dup=658 drop=11 speed=0.609x
硬件解码速度:speed=0.609x
我运行sudo tegrastats,显示信息中出现了 NVDEC 665 NVDEC1 665 。说明NVDEC已经在运行了。
该命令显示信息如下:
nvidia-desktop:/home/nvidia# sudo tegrastats
RAM 11128/15822MB (lfb 800x4MB) SWAP 0/7911MB (cached 0MB) CPU [55%:1420,0%:1420,45%:1420,0%:1420,5%:1420,0%:1420] EMC_FREQ 2%:1866 GR3D_FREQ 0%:114 NVDEC 665 NVDEC1 665 VIC_FREQ 0%:115 APE 150 MTS fg 0% bg 1% AO:43.5C GPU:43C PMIC:50C AUX:43C CPU:44.5C
但是我接着运行ffmpeg的软解码命令,命令如下:
nvidia-desktop:/usr/local/bin# ffmpeg -i /home/working-video/700818_023723.h264 -r 30 -y /home/working-video/video-softdec-test/video-dec%03d.jpg
Stream mapping:
Stream #0:0 → #0:0 (h264 (native) → mjpeg (native))
Output #0, image2, to ‘/home/working-video/working-video-dec/video-softdec-test/video-dec%03d.jpg’:
Metadata:
Metadata:
Side data:
frame= 3879 fps= 18 q=24.8 Lsize=N/A time=00:02:09.30 bitrate=N/A dup=646 drop=0 speed=0.615x
软件解码速度:speed=0.615x 大于 硬件解码速度:speed=0.609x
请问 这个问题是怎么解析???
Please refer to explanation in
Question in NVDEC Accelerated Decode with ffmpeg - #3 by DaneLLL
