nvcc (CUDA 4 RC2) fails to compile the following
piece of C++ code, whereas it does with the CUDA 3.2
framework:
template <typename E>
struct base
template <typename E, unsigned I>
struct A : public base<A<E, I> >
template <typename T>
struct A<T, 0> : public base<A<T, 0> >
typedef A<T, 0> self;
int main()
I am using the CUDA 4 RC2 32 bits framework on windows 7.
Edit: Problem solved, This workaround seems to bypass this bug:
struct base
struct id
typedef T ret;
struct A<T, 0> :
public base<A<typename id<T>::ret, 0> >
int main()
