bb_vb
#1
The following code compiles fine using g++ (4.1.2 20080704 (Red Hat 4.1.2-44)), but does not compile using nvcc (2.3 or 3.0):
[codebox]template<int DIM, class T>
void get(const T& x) {
x.get<DIM>();
struct A {
template<int DIM>
void get() const {}
int main()
A a;
get<3>(a);
}[/codebox]
The error given by nvcc is:
[codebox]In function ‘void get(const T&) [with int DIM = 3, T = A]’:
instantiated from here
error: no matching function for call to ‘A::get() const’[/codebox]
Referring to the 3rd line of code.
Any ideas why this might be? Compiler bug?
Cheers,
Ben
I think you mean the following, right?
[codebox]
struct A {
template<int DIM>
void get() const {}
int main()
A a;
a.get<3>();
[/codebox]
This code seems to compile with a recent nightly compiler:
[codebox]
jhoberock@jhoberock-dt:~$ cat get.cu ; nvcc get.cu ; echo ; nvcc --version
struct A {
template<int DIM>
void get() const {}
int main()
A a;
a.get<3>();
nvcc: NVIDIA ® Cuda compiler driver
Copyright © 2005-2010 NVIDIA Corporation
Built on Fri_May_28_21:28:40_CDT_2010
Cuda compilation tools, release 3.1, V0.2.1221
[/codebox]
Have you tried nvcc 3.1b?
Whoops, you’re right – I copied your code wrong. I can reproduce this. I’ll file a bug.
Just noticed something about the definition of void get(const T&):
x.get<DIM>();
But the calling line in main is
get<3>(a);
Shouldn’t there be two parameters in the template?
get<3, A>(a);
The compiler can figure out the what the 2nd parameter should be from the context.
