What follows is a bit of code extracted from my larger application, therefore I will not explain the context, so unless its invalid code, which I don’t think it is, please don’t ask “why” as its probably a distraction from the problem. Thank you.
The following code fragment compiles successfully in gcc-5 but not with nvcc, which, as far as I understand invokes gcc-5 in order to compile non-device code. Why?
template<typename T>
struct Wrapper;
template<typename ...Args>
struct Wrapper<void(Args...)>
void test( int )
extern template struct Wrapper<decltype(test<float>)>;
int main()
nvcc -ccbin g++-5 -std=c++11 -g -std=c++11 -m64 -gencode arch=compute_30,code=sm_30 -o Test Test.cu
yields the error
Test.cu: error: explicit instantiation of ‘struct Wrapper<void (&)(int)>’ before definition of template
Whereas compiling with gcc thusly (note the contents of Test.cpp are identical to Test.cu)
g++-5 -std=c++11 Test.cpp
succeeds.
What’s going on here? Does nvcc attempt to parse or compile C++ code?
