i think i’m doing something wrong, but i can’t figure what.
Here is a very basic use of cufft.
I’m reading a raw data image, then FFT and inverse FFT, and I write the result back in another raw data file. (which is supposed to be the same … except it’s not !)
int main( void )
#define NX 400
#define NY 300
cufftHandle plan;
cufftComplex *devPtr, *devPtrOut;
float
*data,
*h_ResultGPU;
data = (float*)malloc(NX*NY * sizeof(float));
h_ResultGPU = (float *)malloc(NX*NY * sizeof(float));
FILE* Fichier_image;
Fichier_image = check_filename("bridge_petit.raw","rb");
int ni = 0;
for (ni = 0; ni< NX*NY; ni++)
fread( &data[ni], 1, 1, Fichier_image);
/* GPU memory allocation */
cudaMalloc((void**)&devPtr, sizeof(cufftComplex)*NX*NY);
cudaMalloc((void**)&devPtrOut, sizeof(cufftComplex)*NX*NY);
/* transfer to GPU memory */
cudaMemcpy(devPtr, data, sizeof(cufftComplex)*NX*NY, cudaMemcpyHostToDevice);
/* creates 2D FFT plan */
cufftPlan2d(&plan, NX, NY, CUFFT_C2C);
/* executes FFT processes */
cufftExecC2C(plan, devPtr, devPtrOut, CUFFT_FORWARD);
/* executes FFT processes (inverse transformation) */
cufftExecC2C(plan, devPtrOut, devPtrOut, CUFFT_INVERSE);
/* transfer results from GPU memory */
cudaMemcpy(data, devPtrOut, sizeof(cufftComplex)*NX*NY, cudaMemcpyDeviceToHost);
/* deletes CUFFT plan */
cufftDestroy(plan);
/* frees GPU memory */
cudaFree(devPtr);
cudaFree(devPtrOut);
FILE* Fichier_image2;
Fichier_image2 = check_filename("bridge5.raw","wb");
ni = 0;
fwrite( &h_ResultGPU[ni], 1, 1, Fichier_image2);
return 0;
(and if i try with NX=NY=512 for another image, i’ve got “First-chance exception : access violation reading location 0X…” for the line “cufftPlan2d(&plan, NX, NY, CUFFT_C2C);”. I tried with cufftSafeCall but I still got an error.)
