I am trying out the cufft library. As a test, I wanted to compute the 2d forward and inverse FFT of the array
0, 1, 2,
3, 4, 5,
6, 7, 8.
Problem is, I am getting back the array
0, 9, 2,
3, 4, 5,
6, 7, 8.
I can’t find the problem. Here is the code, any help is appreciated.
[checkCudaErrors() is the macro from helper_cuda.h]
void test_fft()
int input_width = 3;
int input_height = 3;
float input_f[9] = {
0, 1, 2,
3, 4, 5,
6, 7, 8
// Allocate fft input buffer on device
float *d_data;
size_t d_data_size = input_height * input_width * sizeof(float);
checkCudaErrors(cudaMalloc((void**) &d_data, d_data_size));
// Allocate fft output buffer on device
cufftComplex *d_fft_output;
size_t d_fft_output_size = input_height * (input_width / 2 + 1) * sizeof(cufftComplex);
checkCudaErrors(cudaMalloc((void**) &d_fft_output, d_fft_output_size));
// Make forward and inverse plans
cufftHandle fft_plan_forward, fft_plan_inverse;
checkCudaErrors(cufftPlan2d(&fft_plan_forward, input_height, input_width, CUFFT_R2C));
checkCudaErrors(cufftPlan2d(&fft_plan_inverse, input_height, input_width, CUFFT_C2R));
// Copy input data on device
checkCudaErrors(cudaMemcpy(d_data, input_f, d_data_size, cudaMemcpyHostToDevice));
// Compute forward FFT
checkCudaErrors(cufftExecR2C(fft_plan_forward, d_data, d_fft_output));
checkCudaErrors(cudaDeviceSynchronize());
// Allocate fft output buffer on host
float *h_fft_output;
size_t h_fft_output_size = input_height * input_width * sizeof(float);
h_fft_output = (float*) malloc(h_fft_output_size);
// Copy fft output data to host
checkCudaErrors(cudaMemcpy(h_fft_output, d_fft_output, h_fft_output_size, cudaMemcpyDeviceToHost));
// Compute inverse FFT
checkCudaErrors(cufftExecC2R(fft_plan_inverse, d_fft_output, d_data));
// Copy inverse fft output data to host
checkCudaErrors(cudaMemcpy(input_f, d_data, input_height * input_width, cudaMemcpyDeviceToHost));
cout << endl << "forward fft real: " << endl;
for (int i = 0; i < h_fft_output_size / sizeof(float); i++) {
cout << h_fft_output[2 * i] << " ";
cout << endl << "forward fft imaginary: " << endl;
cout << h_fft_output[2 * i + 1] << " ";
cout << endl << "inverse fft: " << endl;
for (int i = 0; i < input_height; i++) {
for (int j = 0; j < input_width; j++)
cout << input_f[i * input_width + j] << " ";
cout << endl;
