The plugin is the same as from the samplePlugin(caffe), i was just trying to use .uff instead of a caffe model. Now I have moved to TensorRT 4GA as without using graph surgeon, the plugin is never called.But, I am getting an assertion failure at nbWeights, which according to the documentation should be 2(Kernel, bias), but for my uff model it is 1. I am using “fc2/add” which should be equivalent to “ip2”
Please remember to update the custom layer name with the UFF operation name.
Yes, I did. I used the collapse namespace function from graph surgeon to do so. I am still getting wrong output.
import graphsurgeon as gs
import tensorflow as tf
fc2 = gs.create_node("fc2")
namespace_plugin_map = {
"fc2/Relu":fc2,
"fc2/add":fc2,
"fc2/MatMul":fc2
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
# dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
Sorry that we don’t have an example to demonstrate UFF plugin currently.
Please check the source of NvUffParser.h.
Try to parse the operation argument which is described with FieldMap.
I am looking at TRT 4GA, and it does have a UFF sample(sampleUFFSSD), can you help me point out what is causing the wrong output with FC layer plugin based on the code I shared above. I have followed the exact workflow from the sample.
The sampleUFFSSD is a C++ based sample while your program shared in comment#23 is python.
Could you share the complete source you modified for us checking?
See #19 for C++ part, and #23 for Python
Suppose you should pass some layer information inside gs.create_node.
For example,
PriorBox = gs.create_node("PriorBox",
numLayers=6,
minScale=0.2,
maxScale=0.95,
aspectRatios=[1.0, 2.0, 0.5, 3.0, 0.33],
layerVariances=[0.1,0.1,0.2,0.2],
featureMapShapes=[19, 10, 5, 3, 2, 1])
Could you check if there is anything missing in your config.py?
I don’t believe so(but that’s why I posted the question), the original SSD sample is trying to convert the whole “Postprocessor” block into a single NMS node, that’s why it needs intermediate attributes during create_node. In my example, it’s just an FC layer
Hi.
Sorry for the late reply.
Which mode do you use?
If you are using the INT8 mode, re-calibration is required for a custom model.
Yes, I know, I have been using TRT since 3.0.4, this is not int8 as it is not defined in the code. Also, this is just replacing the relevant lines of code from sampleUFF that used .caffemodel(TRT 3) by the .uff usage from sampleUFFSSD(4GA), everything else is the same.
How many fully-connected layers inside your model?
Please remember that you need to create multiple mPlugin since the weighs is different.
It is the exact same model as the one in samplePlugin as I mentioned in #21, the only difference is it is a tensorflow model, not caffe. It has 2 FC layers, and I make “fc2” as the unsupported layer as I mentioned in #23. I do not understand why I need to create multiple mPlugin, as I am only replacing fc2 with a custom plugin? Also, how would one achieve something like this?
Model: model.uff - Google Drive
We try to run your program in comment #19, but found the implementation is not compatible with our TensorRT package.
[Application]
registerInput(const char*&, nvinfer1::DimsCHW)
[Expected]
registerInput(const char* inputName, nvinfer1::Dims inputDims, UffInputOrder inputOrder)
Could you share which TensorRT version do you use with us?
As I mentioned before in #25, #31, I am working with TRT 4GA(4.0.1.6). With regards to the line of code you mentioned, I did have this in one my iterations of code, I am still getting the wrong output.
Following is the latest iteration of code.
#include <assert.h>
#include <chrono>
#include <fstream>
#include <sstream>
#include <iostream>
#include <cmath>
#include <sys/stat.h>
#include <cmath>
#include <time.h>
#include <cudnn.h>
#include <cublas_v2.h>
#include <memory>
#include <string.h>
#include "NvInfer.h"
#include "NvUffParser.h"
#include "common.h"
#include "fp16.h"
using namespace nvuffparser;
using namespace nvinfer1;
// stuff we know about the network and the caffe input/output blobs
static const int INPUT_H = 28;
static const int INPUT_W = 28;
static const int OUTPUT_SIZE = 10;
static Logger gLogger;
#define MAX_WORKSPACE (1 << 30)
#define RETURN_AND_LOG(ret, severity, message) \
do \
std::string error_message = "sample_uff_ssd: " + std::string(message); \
gLogger.log(ILogger::Severity::k##severity, error_message.c_str()); \
return (ret); \
} while (0)
const char* INPUT_BLOB_NAME = "Input/input"; // Refer graphsurgeon conf script
const char* OUTPUT_BLOB_NAME = "fc2";
std::string locateFile(const std::string& input)
std::vector<std::string> dirs{"data/samples/mnist/", "data/mnist/"};
return locateFile(input, dirs);
// simple PGM (portable greyscale map) reader
void readPGMFile(const std::string& filename, uint8_t buffer[INPUT_H*INPUT_W])
readPGMFile(locateFile(filename), buffer, INPUT_H, INPUT_W);
std::vector<std::pair<int64_t, DataType>>
calculateBindingBufferSizes(const ICudaEngine& engine, int nbBindings, int batchSize) // Unchanged
std::vector<std::pair<int64_t, DataType>> sizes;
for (int i = 0; i < nbBindings; ++i)
Dims dims = engine.getBindingDimensions(i);
DataType dtype = engine.getBindingDataType(i);
int64_t eltCount = samples_common::volume(dims) * batchSize;
sizes.push_back(std::make_pair(eltCount, dtype));
return sizes;
ICudaEngine* UFFtoGIEModel(const char* uffFile,
int maxBatchSize,IUffParser* parser,
nvuffparser::IPluginFactory* pluginFactory,
IHostMemory *&gieModelStream)
IBuilder* builder = createInferBuilder(gLogger);
INetworkDefinition* network = builder->createNetwork();
parser->setPluginFactory(pluginFactory);
std::cout << "Begin parsing model..." << std::endl;
if (!parser->parse(uffFile, *network, nvinfer1::DataType::kFLOAT))
RETURN_AND_LOG(nullptr, ERROR, "Fail to parse");
std::cout << "End parsing model..." << std::endl;
// specify which tensors are outputs
/* we create the engine */
builder->setMaxBatchSize(maxBatchSize);
builder->setMaxWorkspaceSize(1 << 20);
builder->setHalf2Mode(false);
std::cout << "Begin building engine..." << std::endl;
ICudaEngine* engine = builder->buildCudaEngine(*network);
if (!engine)
RETURN_AND_LOG(nullptr, ERROR, "Unable to create engine");
std::cout << "End building engine..." << std::endl;
// serialize the engine, then close everything down
network->destroy();
parser->destroy();
gieModelStream = engine->serialize();
builder->destroy();
shutdownProtobufLibrary();
return engine;
void doInference(IExecutionContext& context, float* input, float* output, int batchSize)
const ICudaEngine& engine = context.getEngine();
// input and output buffer pointers that we pass to the engine - the engine requires exactly IEngine::getNbBindings(),
// of these, but in this case we know that there is exactly one input and one output.
assert(engine.getNbBindings() == 2);
void* buffers[2];
// In order to bind the buffers, we need to know the names of the input and output tensors.
// note that indices are guaranteed to be less than IEngine::getNbBindings()
int inputIndex = engine.getBindingIndex(INPUT_BLOB_NAME),
outputIndex = engine.getBindingIndex(OUTPUT_BLOB_NAME);
// // create GPU buffers and a stream
CHECK(cudaMalloc(&buffers[inputIndex], batchSize * INPUT_H * INPUT_W * sizeof(float)));
CHECK(cudaMalloc(&buffers[outputIndex], batchSize * OUTPUT_SIZE * sizeof(float)));
cudaStream_t stream;
CHECK(cudaStreamCreate(&stream));
// DMA the input to the GPU, execute the batch asynchronously, and DMA it back:
CHECK(cudaMemcpyAsync(buffers[inputIndex], input, batchSize * INPUT_H * INPUT_W * sizeof(float), cudaMemcpyHostToDevice, stream));
context.enqueue(batchSize, buffers, stream, nullptr);
CHECK(cudaMemcpyAsync(output, buffers[outputIndex], batchSize * OUTPUT_SIZE*sizeof(float), cudaMemcpyDeviceToHost, stream));
cudaStreamSynchronize(stream);
// release the stream and the buffers
cudaStreamDestroy(stream);
CHECK(cudaFree(buffers[inputIndex]));
CHECK(cudaFree(buffers[outputIndex]));
class FCPlugin: public IPluginExt
public:
FCPlugin(const Weights *weights, int nbWeights, int nbOutputChannels): mNbOutputChannels(nbOutputChannels)
{ std::cout << "nbweightsout " << weights[0].count << std::endl; //DBG
assert(nbWeights == 2);
mKernelWeights = weights[0];
assert(mKernelWeights.type == DataType::kFLOAT || mKernelWeights.type == DataType::kHALF);
mBiasWeights = weights[1];
std::cout << "mBiasWeights: " << mBiasWeights.count << " nbOutputChannels: " << nbOutputChannels << " mKernelWeights: " << mKernelWeights.count << std::endl; //DBG
assert(mBiasWeights.count == 0 || mBiasWeights.count == nbOutputChannels);
assert(mBiasWeights.type == DataType::kFLOAT || mBiasWeights.type == DataType::kHALF);
mKernelWeights.values = malloc(mKernelWeights.count*type2size(mKernelWeights.type));
memcpy(const_cast<void*>(mKernelWeights.values), weights[0].values, mKernelWeights.count*type2size(mKernelWeights.type));
mBiasWeights.values = malloc(mBiasWeights.count*type2size(mBiasWeights.type));
memcpy(const_cast<void*>(mBiasWeights.values), weights[1].values, mBiasWeights.count*type2size(mBiasWeights.type));
mNbInputChannels = int(weights[0].count / nbOutputChannels);
// create the plugin at runtime from a byte stream
FCPlugin(const void* data, size_t length)
const char* d = static_cast<const char*>(data), *a = d;
read(d, mNbInputChannels);
read(d, mNbOutputChannels);
mKernelWeights.count = mNbInputChannels * mNbOutputChannels;
mKernelWeights.values = nullptr;
read(d, mBiasWeights.count);
mBiasWeights.values = nullptr;
read(d, mDataType);
deserializeToDevice(d, mDeviceKernel, mKernelWeights.count*type2size(mDataType));
deserializeToDevice(d, mDeviceBias, mBiasWeights.count*type2size(mDataType));
assert(d == a + length);
~FCPlugin()
if (mKernelWeights.values)
free(const_cast<void*>(mKernelWeights.values));
if (mBiasWeights.values)
free(const_cast<void*>(mBiasWeights.values));
int getNbOutputs() const override
return 1;
Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override
assert(index == 0 && nbInputDims == 1 && inputs[0].nbDims == 3);
assert(mNbInputChannels == inputs[0].d[0] * inputs[0].d[1] * inputs[0].d[2]);
return Dims3(mNbOutputChannels, 1, 1);
bool supportsFormat(DataType type, PluginFormat format) const override { return (type == DataType::kFLOAT || type == DataType::kHALF) && format == PluginFormat::kNCHW; }
void configureWithFormat(const Dims* inputDims, int nbInputs, const Dims* outputDims, int nbOutputs, DataType type, PluginFormat format, int maxBatchSize) override
assert((type == DataType::kFLOAT || type == DataType::kHALF) && format == PluginFormat::kNCHW);
mDataType = type;
int initialize() override
CHECK(cudnnCreate(&mCudnn));// initialize cudnn and cublas
CHECK(cublasCreate(&mCublas));
CHECK(cudnnCreateTensorDescriptor(&mSrcDescriptor));// create cudnn tensor descriptors we need for bias addition
CHECK(cudnnCreateTensorDescriptor(&mDstDescriptor));
convertAndCopyToDevice(mDeviceKernel, mKernelWeights);
convertAndCopyToDevice(mDeviceBias, mBiasWeights);
return 0;
virtual void terminate() override
CHECK(cudnnDestroyTensorDescriptor(mSrcDescriptor));
CHECK(cudnnDestroyTensorDescriptor(mDstDescriptor));
CHECK(cublasDestroy(mCublas));
CHECK(cudnnDestroy(mCudnn));
if (mDeviceKernel)
cudaFree(mDeviceKernel);
mDeviceKernel = nullptr;
if (mDeviceBias)
cudaFree(mDeviceBias);
mDeviceBias = nullptr;
virtual size_t getWorkspaceSize(int maxBatchSize) const override
return 0;
virtual int enqueue(int batchSize, const void*const * inputs, void** outputs, void* workspace, cudaStream_t stream) override
float onef{1.0f}, zerof{0.0f};
__half oneh = fp16::__float2half(1.0f), zeroh = fp16::__float2half(0.0f);
cublasSetStream(mCublas, stream);
cudnnSetStream(mCudnn, stream);
if (mDataType == DataType::kFLOAT)
CHECK(cublasSgemm(mCublas, CUBLAS_OP_T, CUBLAS_OP_N, mNbOutputChannels, batchSize, mNbInputChannels, &onef, //alpha = 1
reinterpret_cast<const float*>(mDeviceKernel), mNbInputChannels,
reinterpret_cast<const float*>(inputs[0]), mNbInputChannels, &zerof,
reinterpret_cast<float*>(outputs[0]), mNbOutputChannels));
else
CHECK(cublasHgemm(mCublas, CUBLAS_OP_T, CUBLAS_OP_N, mNbOutputChannels, batchSize, mNbInputChannels, &oneh,
reinterpret_cast<const __half*>(mDeviceKernel), mNbInputChannels,
reinterpret_cast<const __half*>(inputs[0]), mNbInputChannels, &zeroh,
reinterpret_cast<__half*>(outputs[0]), mNbOutputChannels));
if (mBiasWeights.count)
cudnnDataType_t cudnnDT = mDataType == DataType::kFLOAT ? CUDNN_DATA_FLOAT : CUDNN_DATA_HALF;
CHECK(cudnnSetTensor4dDescriptor(mSrcDescriptor, CUDNN_TENSOR_NCHW, cudnnDT, 1, mNbOutputChannels, 1, 1));
CHECK(cudnnSetTensor4dDescriptor(mDstDescriptor, CUDNN_TENSOR_NCHW, cudnnDT, batchSize, mNbOutputChannels, 1, 1));
CHECK(cudnnAddTensor(mCudnn, &onef, mSrcDescriptor, mDeviceBias, &onef, mDstDescriptor, outputs[0]));
return 0;
virtual size_t getSerializationSize() override
return sizeof(mNbInputChannels) + sizeof(mNbOutputChannels) + sizeof(mBiasWeights.count) + sizeof(mDataType) +
(mKernelWeights.count + mBiasWeights.count) * type2size(mDataType);
virtual void serialize(void* buffer) override
char* d = static_cast<char*>(buffer), *a = d;
write(d, mNbInputChannels);
write(d, mNbOutputChannels);
write(d, mBiasWeights.count);
write(d, mDataType);
convertAndCopyToBuffer(d, mKernelWeights);
convertAndCopyToBuffer(d, mBiasWeights);
assert(d == a + getSerializationSize());
private:
size_t type2size(DataType type) { return type == DataType::kFLOAT ? sizeof(float) : sizeof(__half); }
template<typename T> void write(char*& buffer, const T& val)
*reinterpret_cast<T*>(buffer) = val;
buffer += sizeof(T);
template<typename T> void read(const char*& buffer, T& val)
val = *reinterpret_cast<const T*>(buffer);
void* copyToDevice(const void* data, size_t count)
void* deviceData;
CHECK(cudaMalloc(&deviceData, count));
CHECK(cudaMemcpy(deviceData, data, count, cudaMemcpyHostToDevice));
return deviceData;
void convertAndCopyToDevice(void*& deviceWeights, const Weights& weights)
if (weights.type != mDataType) // Weights are converted in host memory first, if the type does not match
size_t size = weights.count*(mDataType == DataType::kFLOAT ? sizeof(float) : sizeof(__half));
void* buffer = malloc(size);
for (int64_t v = 0; v < weights.count; ++v)
static_cast<float*>(buffer)[v] = fp16::__half2float(static_cast<const __half*>(weights.values)[v]);
else
static_cast<__half*>(buffer)[v] = fp16::__float2half(static_cast<const float*>(weights.values)[v]);
deviceWeights = copyToDevice(buffer, size);
free(buffer);
else
deviceWeights = copyToDevice(weights.values, weights.count * type2size(mDataType));
void convertAndCopyToBuffer(char*& buffer, const Weights& weights)
reinterpret_cast<float*>(buffer)[v] = fp16::__half2float(static_cast<const __half*>(weights.values)[v]);
else
reinterpret_cast<__half*>(buffer)[v] = fp16::__float2half(static_cast<const float*>(weights.values)[v]);
else
memcpy(buffer, weights.values, weights.count * type2size(mDataType));
buffer += weights.count * type2size(mDataType);
void deserializeToDevice(const char*& hostBuffer, void*& deviceWeights, size_t size)
deviceWeights = copyToDevice(hostBuffer, size);
hostBuffer += size;
int mNbOutputChannels, mNbInputChannels;
Weights mKernelWeights, mBiasWeights;
DataType mDataType{DataType::kFLOAT};
void* mDeviceKernel{nullptr};
void* mDeviceBias{nullptr};
cudnnHandle_t mCudnn;
cublasHandle_t mCublas;
cudnnTensorDescriptor_t mSrcDescriptor, mDstDescriptor;
// integration for serialization
class PluginFactory : public nvinfer1::IPluginFactory, public nvuffparser::IPluginFactoryExt
public:
// caffe parser plugin implementation
bool isPlugin(const char* name) override
return isPluginExt(name);
bool isPluginExt(const char* name) override
return !strcmp(name, "_fc2");
virtual nvinfer1::IPlugin* createPlugin(const char* layerName, const nvinfer1::Weights* weights, int nbWeights, const nvuffparser::FieldCollection fc) override
// there's no way to pass parameters through from the model definition, so we have to define it here explicitly
assert(isPlugin(layerName));
const nvuffparser::FieldMap* fields = fc.fields;
int nbFields = fc.nbFields;
std::cout << "Layer Name: " << layerName << std::endl; //DBG
std::cout << "fc.fields: " << fc.fields << std::endl ; //DBG
std::cout << "fc.nbFields: " << fc.nbFields << std::endl; //DBG
std::cout << "nbWeights: " << nbWeights << std::endl; //DBG
static const int NB_OUTPUT_CHANNELS = 10;
assert(isPlugin(layerName));// && nbWeights == 2 && weights[0].type == DataType::kFLOAT && weights[1].type == DataType::kFLOAT);
if(!strcmp(layerName, "_fc2")){
assert(mPlugin.get() == nullptr);
mPlugin = std::unique_ptr<FCPlugin>(new FCPlugin(weights, nbWeights, NB_OUTPUT_CHANNELS));
return mPlugin.get();
else{
assert(0);
return nullptr;
// deserialization plugin implementation
IPlugin* createPlugin(const char* layerName, const void* serialData, size_t serialLength) override
mPlugin = std::unique_ptr<FCPlugin>(new FCPlugin(serialData, serialLength));
else{
assert(0);
return nullptr;
// the application has to destroy the plugin when it knows it's safe to do so
void destroyPlugin()
mPlugin.release();
std::unique_ptr<FCPlugin> mPlugin{ nullptr };
int main(int argc, char** argv)
auto fileName = locateFile("model.pb.uff");
std::cout << fileName << std::endl;
// int maxBatchSize = 1;
auto parser = createUffParser();
parser->registerInput(INPUT_BLOB_NAME, DimsCHW(1, 28, 28), UffInputOrder::kNCHW);
parser->registerOutput(OUTPUT_BLOB_NAME);
// create a GIE model from the caffe model and serialize it to a stream
IHostMemory *gieModelStream{ nullptr };
PluginFactory pluginFactorySerialize;
// caffeToGIEModel("mnist.prototxt", "mnist.caffemodel", std::vector < std::string > { OUTPUT_BLOB_NAME }, 1, &pluginFactory, gieModelStream);
ICudaEngine* tmpEngine = UFFtoGIEModel(fileName.c_str(), 1, parser, &pluginFactorySerialize, gieModelStream);
assert(tmpEngine != nullptr);
assert(gieModelStream != nullptr);
tmpEngine->destroy();
pluginFactorySerialize.destroyPlugin();
// read a random digit file
srand(unsigned(time(nullptr)));
uint8_t fileData[INPUT_H*INPUT_W];
int num{rand()%10};
std::cout << "Input file num: " << num << std::endl; //DBG
readPGMFile(std::to_string(num) + ".pgm", fileData);
// Deserialize the engine.
std::cout << "*** deserializing" << std::endl;
IRuntime* runtime = createInferRuntime(gLogger);
assert(runtime != nullptr);
PluginFactory pluginFactory;
ICudaEngine* engine = runtime->deserializeCudaEngine(gieModelStream->data(), gieModelStream->size(), &pluginFactory);
assert(engine != nullptr);
gieModelStream->destroy();
IExecutionContext* context = engine->createExecutionContext();
assert(context != nullptr);
// run inference
float prob[OUTPUT_SIZE];
doInference(*context, (float*)fileData, prob, 1);
std::vector<double> probs;
int maxIdx = 0;
for (int i = 0; i < 10; ++i){
// std::cout << "Prob:" << i<< ": "<<prob[i] << std::endl; //DBG
probs.push_back(prob[i]);
if (prob[i] > prob[maxIdx]){
maxIdx = i;
std::cout << "maxIdx: " << maxIdx << std::endl;
// destroy the engine
context->destroy();
engine->destroy();
runtime->destroy();
pluginFactory.destroyPlugin();
// print a histogram of the output distribution
bool pass{false};
for (int i = 0; i < 10; i++)
int res = std::floor(prob[i] * 10 + 0.5);
// std::cout << prob[i] <<std::endl;
// // std::cout << "Res: " << res << std::endl;
// std::cout << "i: " <<i << std::endl;
if (res == 10 && i == num) {pass = true;
std::cout << i << ": " << std::string(res, '*') << "\n";}
std::cout << std::endl;
return pass ? EXIT_SUCCESS : EXIT_FAILURE;
convert-to-uff tensorflow --input-file model.pb
-O fc2/Relu -p config.py
Loading model.pb
File "/home/dhingratul/.virtualenvs/trt4/bin/convert-to-uff", line 11, in <module>
sys.exit(main())
File "/home/dhingratul/.virtualenvs/trt4/local/lib/python2.7/site-packages/uff/bin/convert_to_uff.py", line 105, in main
output_filename=args.output
File "/home/dhingratul/.virtualenvs/trt4/local/lib/python2.7/site-packages/uff/converters/tensorflow/conversion_helpers.py", line 149, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/home/dhingratul/.virtualenvs/trt4/local/lib/python2.7/site-packages/uff/converters/tensorflow/conversion_helpers.py", line 55, in from_tensorflow
pre = importlib.import_module(preprocessor.replace(".py", ""))
File "/usr/lib/python2.7/importlib/__init__.py", line 37, in import_module
__import__(name)
File "tensorrt_samples/samples/samplePlugin_tf/config.py", line 8, in <module>
"fc2/Relu":fc2_relu,
NameError: name 'fc2_relu' is not defined
Sorry that my previous comment is incorrect.
We are trying to write a sample to demonstrate TensorFlow(MNIST) plugin(fc2).
Will share information here once we have done.
Thanks and sorry for any inconvenience we bring to you.
You may collapse the ReLU node since the plugin doesn’t perform a ReLU op on the output. It only handles MatMul and BiasAdd.
Our internal team has tested this issue without the plugin and it works correctly.
So either the plugin or preprocessing script is incorrect.
However, we couldn’t find the exact reason as to why the given plugin implementation isn’t working.
The inputs and weights to the plugin are correct and match what is seen by the TensorRT engine when the same layer is run as a FC layer.
So there is no bug in TensorRT, but looks like some issue with the plugin implementation.
We would recommend to use native TensorRT FC layer rather than implementing a plugin for it.
For demonstration of how to use plugins with TensorFlow/UFF, please use TRT 5.0 GA.
It will have both c++ and python samples demonstrating the same.
I didn’t write a single line of code for this one, even the plugin is from one of the samples from TensorRT 4RC. I just wanted to check the usage, therefore converted the 4RC sample to 4GA. This was also a test for backward compatibility between versions. As most of my models have more than one custom operation, I want to make sure that upgrading to a new version doesn’t break my code. Also, the latest version I see is TRT 4GA, can you give me the link for 5GA. Also, can you help me with this as well:
https://devtalk.nvidia.com/default/topic/1036974/
