Description
Conversion to uff fails due to unsupported ops. These ops not in custom plugin list of TRT.
How to resolve this?
Environment
TensorRT Version : 7.0.0.11
GPU Type : Tesla K80
Nvidia Driver Version : 440.64.00
CUDA Version : CUDA Version: 10.2
CUDNN Version : 7.6
Operating System + Version : Ubuntu x86_64
Python Version (if applicable) : 3.6
TensorFlow Version (if applicable) : 1.15.2
PyTorch Version (if applicable) :
Baremetal or Container (if container which image + tag) : barematel
Relevant Files
Steps To Reproduce
(base) ubuntu@usva-asd-ml-ear1:~/notebook/head-pose-estimation$ convert-to-uff frozen_graph.pb
Loading frozen_graph_optimized.pb
WARNING: Logging before flag parsing goes to stderr.
W0529 23:11:49.203099 139740564793152 module_wrapper.py:139] From /home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/conversion_helpers.py:227: The name tf.gfile.GFile is deprecated. Please use tf.io.gfile.GFile instead.
NOTE: UFF has been tested with TensorFlow 1.14.0.
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
UFF Version 0.6.5
=== Automatically deduced input nodes ===
[name: “image_tensor”
op: “Placeholder”
attr {
key: “_output_shapes”
value {
list {
shape {
dim {
dim {
dim {
dim {
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
=== Automatically deduced output nodes ===
[name: “layer6/final_dense”
op: “Identity”
input: “layer6/logits/BiasAdd”
attr {
key: “T”
value {
type: DT_FLOAT
attr {
value {
list {
shape {
dim {
dim {
Using output node layer6/final_dense
Converting to UFF graph
DEBUG: convert reshape to flatten node
Warning: No conversion function registered for layer: TensorArrayGatherV3 yet.
Converting map/TensorArrayStack/TensorArrayGatherV3 as custom op: TensorArrayGatherV3
W0529 23:11:49.407045 139740564793152 module_wrapper.py:139] From /home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py:179: The name tf.AttrValue is deprecated. Please use tf.compat.v1.AttrValue instead.
Warning: No conversion function registered for layer: Exit yet.
Converting map/while/Exit_2 as custom op: Exit
Warning: No conversion function registered for layer: Switch yet.
Converting map/while/Switch_2 as custom op: Switch
Warning: No conversion function registered for layer: LoopCond yet.
Converting map/while/LoopCond as custom op: LoopCond
Warning: No conversion function registered for layer: LogicalAnd yet.
Converting map/while/LogicalAnd as custom op: LogicalAnd
Warning: No conversion function registered for layer: Less yet.
Converting map/while/Less_1 as custom op: Less
Warning: No conversion function registered for layer: Enter yet.
Converting map/while/Less/Enter as custom op: Enter
Warning: No conversion function registered for layer: Merge yet.
Converting map/while/Merge_1 as custom op: Merge
Warning: No conversion function registered for layer: NextIteration yet.
Converting map/while/NextIteration_1 as custom op: NextIteration
Converting map/while/Switch as custom op: Switch
Converting map/while/Merge as custom op: Merge
Converting map/while/NextIteration as custom op: NextIteration
Converting map/while/Enter as custom op: Enter
Converting map/while/Switch_1 as custom op: Switch
Converting map/while/Enter_1 as custom op: Enter
Converting map/while/Less as custom op: Less
Converting map/while/Merge_2 as custom op: Merge
Converting map/while/NextIteration_2 as custom op: NextIteration
Warning: No conversion function registered for layer: TensorArrayWriteV3 yet.
Converting map/while/TensorArrayWrite/TensorArrayWriteV3 as custom op: TensorArrayWriteV3
Warning: No conversion function registered for layer: ResizeBilinear yet.
Converting map/while/resize/ResizeBilinear as custom op: ResizeBilinear
Warning: No conversion function registered for layer: TensorArrayReadV3 yet.
Converting map/while/TensorArrayReadV3 as custom op: TensorArrayReadV3
Converting map/while/TensorArrayReadV3/Enter_1 as custom op: Enter
Warning: No conversion function registered for layer: TensorArrayScatterV3 yet.
Converting map/TensorArrayUnstack/TensorArrayScatter/TensorArrayScatterV3 as custom op: TensorArrayScatterV3
Warning: No conversion function registered for layer: TensorArrayV3 yet.
Converting map/TensorArray as custom op: TensorArrayV3
Warning: No conversion function registered for layer: Range yet.
Converting map/TensorArrayUnstack/range as custom op: Range
Converting map/while/TensorArrayReadV3/Enter as custom op: Enter
File “/home/ubuntu/anaconda3/bin/convert-to-uff”, line 10, in
sys.exit(main())
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/bin/convert_to_uff.py”, line 92, in main
debug_mode=args.debug
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/conversion_helpers.py”, line 229, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/conversion_helpers.py”, line 178, in from_tensorflow
debug_mode=debug_mode)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 41, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 222, in parse_tf_attrs
return {key: cls.parse_tf_attr_value(val) for key, val in attrs.items() if val is not None and val.WhichOneof(‘value’) is not None}
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 218, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 190, in convert_tf2uff_field
return TensorFlowToUFFConverter.convert_tf2numpy_dtype(val)
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/uff/converters/tensorflow/converter.py”, line 103, in convert_tf2numpy_dtype
return tf.as_dtype(dtype).as_numpy_dtype
File “/home/ubuntu/anaconda3/lib/python3.6/site-packages/tensorflow_core/python/framework/dtypes.py”, line 126, in as_numpy_dtype
return _TF_TO_NP[self._type_enum]
KeyError: 20
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
