TensorRT uff_to_trt_engine fails
I am trying to create an engine from frozen tensorflow graph with the following code:
uff_model = uff.from_tensorflow_frozen_model("models/graph.pb", output_layers, output_filename="graph.uff")
parser = uffparser.create_uff_parser()
parser.register_input(input_layers, (1, 416, 416), 0)
parser.register_output(output_layers)
engine = trt.utils.uff_to_trt_engine(G_LOGGER, uff_model, parser, 1, 1 << 20)
But it keeps giving error in the engine generation part. The output of the console is following:
Using output node detector/yolo-v3/Reshape
Using output node detector/yolo-v3/Reshape_5
Using output node detector/yolo-v3/Reshape_10
Converting to UFF graph
Warning: No conversion function registered for layer: ResizeNearestNeighbor yet.
Converting as custom op ResizeNearestNeighbor detector/yolo-v3/ResizeNearestNeighbor_1
op: "ResizeNearestNeighbor"
input: "detector/yolo-v3/transpose_4"
input: "detector/yolo-v3/ResizeNearestNeighbor_1/size"
attr {
  key: "T"
  value {
    type: DT_FLOAT
attr {
  key: "align_corners"
  value {
    b: false
input: "detector/yolo-v3/transpose_1"
input: "detector/yolo-v3/ResizeNearestNeighbor/size"
attr {
  key: "T"
  value {
    type: DT_FLOAT
attr {
  value {
    b: false
No. nodes: 778
UFF Output written to masa2.uff
/usr/lib/python2.7/dist-packages/tensorrt/utils/_utils.py:237: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
  if datatype == infer.DataType.HALF and not builder.platform_has_fast_fp16():
  File "/home/user/PycharmProjects/TensorOptimize/optimize_yolo.py", line 54, in <module>
    generate_engine(output_layers=["detector/yolo-v3/Reshape", "detector/yolo-v3/Reshape_5", "detector/yolo-v3/Reshape_10"], input_layers=["Placeholder"])
  File "/home/user/PycharmProjects/TensorOptimize/optimize_yolo.py", line 31, in generate_engine
    engine = trt.utils.uff_to_trt_engine(G_LOGGER, uff_model, parser, 1, 1 << 20,datatype=trt.infer.DataType.HALF)
  File "/usr/lib/python2.7/dist-packages/tensorrt/utils/_utils.py", line 237, in uff_to_trt_engine
TypeError: Failed to decode Unicode string
Is there anybody with a solution to this ? Thanks
Hello, can you provide details on the platforms you are using?
Linux distro and version
GPU type
nvidia driver version
CUDA version
CUDNN version
Python version [if using python]
Tensorflow version
TensorRT version
Thanks for the answer @NVES. Here are the details:
Linux Distro: Ubuntu 18.04
GPU: GT940MX
Driver Version: 390.77
CUDA Version: 9.0.176
CUDNN Version: 7.2.1
Python: 2.7
Tensorflow-gpu: 1.10
TensorRT: 4.0.1.6
hello,
can you provide the pb/uff ?
Sure, here is a link to the pb file:
https://drive.google.com/file/d/1bQhodrIRkUi3CJPZ-ikDWRhY-HdsNsmv/view?usp=sharing
We convert the pb and get it to the parser; see output like this:
Warning: No conversion function registered for layer: Range yet.
Converting as custom op Range detector/yolo-v3/range
op: “Range”
input: “detector/yolo-v3/range/start”
input: “detector/yolo-v3/range/limit”
input: “detector/yolo-v3/range/delta”
attr {
key: “Tidx”
value {
type: DT_FLOAT
No. nodes: 939
[TensorRT] ERROR: UFFParser: Validator error: detector/yolo-v3/Tile_4: Unsupported operation _Tile
[TensorRT] ERROR: Network must have at least one output
which is expected.
There are several unsupported operations in the network (ex: ResizeNearestNeighbor), so, unfortunately, it will not work.
Can you give me a list of ops you are using? It will help us with future version feature planning.
I see. Here is the list of operations if I am not missing anything:
conv2d
concat
pad
split
reshape
meshgrid
transpose
tile
exp
sigmoid
identity
image.resize_nearest_neighbor
I am using the code in GitHub - mystic123/tensorflow-yolo-v3: Implementation of YOLO v3 object detector in Tensorflow (TF-Slim) so you can check the yolo_v3.py in the repo if I am mistaken with the list. Is there anything I can do about unsupported operations or should I wait for an update ?
Please reference the TensorRT Development Guide for a list of supported operations: https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#support_op
We are always welcome community/customer feedback and improve future versions.
