Failed to parse UFF
Hi there,
Please find the process and error below and any assistance offered will greatly benefit on my progress.
THE TERMINAL INPUT I GAVE:
nvidia@tegra-ubuntu:~/build/tf_to_trt_image_classification/scripts$ python convert_plan.py frozen_model.pb frozen_model.plan input 224 224 final_result 1 0 float
THE OUTPUT:
=== Automatically deduced input nodes ===
[name: “Placeholder”
op: “Placeholder”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
Using output node final_result
Converting to UFF graph
Warning: No conversion function registered for layer: PlaceholderWithDefault yet.
Converting as custom op PlaceholderWithDefault input/BottleneckInputPlaceholder
op: “PlaceholderWithDefault”
input: “module_apply_default/hub_output/feature_vector/SpatialSqueeze”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
Warning: keepdims is ignored by the UFF Parser and defaults to True
No. nodes: 794
UFF Output written to data/tmp.uff
UFFParser: Validator error: input/BottleneckInputPlaceholder: Unsupported operation _PlaceholderWithDefault
Failed to parse UFF
Kind regards
Sri
it looks like _PlaceholderWithDefault is a unsupported TRT operation.
For a list of supported ops: https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#support_op
For any unsupported layers/operations plugins can be used.
Custom layers can be added to TensorRT network in Python using plugin nodes. https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#add_custom_layer_python.
Checkout
/workspace/tensorrt/samples/python/uff_custom_plugin [python]
/workspace/tensorrt/samples/samplePlugin [c]
in your TRT installation/container for examples on howto work with the Plugin API.
