Loading models/ssd_mobilenet_v2/frozen_inference_graph.pb
NOTE: UFF has been tested with TensorFlow 1.12.0. Other versions are not guaranteed to work
WARNING: The version of TensorFlow installed on this system is not guaranteed to work with UFF.
WARNING: To create TensorRT plugin nodes, please use the create_plugin_node function instead.
UFF Version 0.6.3
=== Automatically deduced input nodes ===
[name: “Input”
op: “Placeholder”
input: “Cast”
attr {
key: “dtype”
value {
type: DT_FLOAT
attr {
key: “shape”
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_loc as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: Cast yet.
Converting Cast as custom op: Cast
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Converting concat_box_conf as custom op: FlattenConcat_TRT
No. nodes: 571
UFF Output written to models/ssd_mobilenet_v2/frozen_inference_graph.uff
I got this error when converting ssd mobilenet v2 to tensorrt uff format.
Any help would be appreciated !!!
