I want to use tensorrt5 to do inference. Using the sample in samples/sampleUffSSD with command:
convert-to-uff ssd_inception_v2_coco_2017_11_17/frozen_inference_graph.pb -p config.py
I got the following warning:
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_conf as custom op: FlattenConcat_TRT
Warning: No conversion function registered for layer: GridAnchor_TRT yet.
Converting GridAnchor as custom op: GridAnchor_TRT
Converting concat_box_loc as custom op: FlattenConcat_TRT
No. nodes: 563
UFF Output written to ssd_inception_v2_coco_2017_11_17/frozen_inference_graph.uff
the full message:
Loading ssd_inception_v2_coco_2017_11_17/frozen_inference_graph.pb
WARNING: To create TensorRT plugin nodes, please use the `create_plugin_node` function instead.
UFF Version 0.5.5
=== Automatically deduced input nodes ===
[name: "Input"
op: "Placeholder"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
=== Automatically deduced output nodes ===
[name: "NMS"
op: "NMS_TRT"
input: "concat_box_loc"
input: "concat_priorbox"
input: "concat_box_conf"
attr {
key: "backgroundLabelId_u_int"
value {
i: 0
attr {
key: "confSigmoid_u_int"
value {
i: 1
attr {
key: "confidenceThreshold_u_float"
value {
f: 9.99999993923e-09
attr {
key: "inputOrder_u_ilist"
value {
list {
i: 0
i: 2
i: 1
attr {
key: "isNormalized_u_int"
value {
i: 1
attr {
key: "keepTopK_u_int"
value {
i: 100
attr {
key: "nmsThreshold_u_float"
value {
f: 0.600000023842
attr {
key: "numClasses_u_int"
value {
i: 91
attr {
key: "scoreConverter_u_str"
value {
s: "SIGMOID"
attr {
key: "shareLocation_u_int"
value {
i: 1
attr {
key: "topK_u_int"
value {
i: 100
attr {
key: "varianceEncodedInTarget_u_int"
value {
i: 0
No. nodes: 563
