Converting sampleUffSSD for different tensorflow models
Hello I’ve been trying to convert my object_detection ssd model from tensorflow 1.8,
I’ve converted the layers using the following python script. All the parameters are carefully matched to the tensorflow model.
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node(
	"Input",
	op="Placeholder",
	dtype=tf.float32,
	shape=[1, 3, 1600, 1600])
PriorBox = gs.create_node(
	"PriorBox",
	numLayers=6,
	minScale=0.1,
	maxScale=0.2,
	aspectRatios=[1.0, 2.0, 0.5],
	layerVariances=[0.1, 0.1, 0.2, 0.2],
	featureMapShapes=[200, 100, 50, 25, 13, 6])
NMS = gs.create_node(
	"NMS",
	numClasses=13,
	iouThreshold=0.6,
	scoreThreshold=1e-8,
	maxDetectionsPerClass=100,
	maxTotalDetections=100,
	scoreConverter="SIGMOID")
concat_box_loc = gs.create_node("concat_box_loc")
concat_box_conf = gs.create_node("concat_box_conf")
concat_priorbox = gs.create_node("concat_priorbox", dtype=tf.float32, axis=2)
namespace_plugin_map = {
    "Postprocessor": NMS,
    "Preprocessor": Input,
    "concat": concat_box_loc,
    "concat_1": concat_box_conf,
	"Concatenate/concat": concat_priorbox,
	"MultipleGridAnchorGenerator": PriorBox,
namespace_remove = {
    "ToFloat",
    "image_tensor",
    "Preprocessor/map/TensorArrayStack_1/TensorArrayGatherV3",
def preprocess(dynamic_graph):
    # remove the unrelated or error layers
    dynamic_graph.remove(
		dynamic_graph.find_nodes_by_path(namespace_remove),
		remove_exclusive_dependencies=False)
    # Now create a new graph by collapsing namespaces
    dynamic_graph.collapse_namespaces(namespace_plugin_map)
    # Remove the outputs, so we just have a single output node (NMS).
    dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
    # Remove the Squeeze to avoid "Assertion `isPlugin(layerName)' failed"
    Squeeze = dynamic_graph.find_node_inputs_by_name(dynamic_graph.graph_outputs[0], 'Squeeze')
    dynamic_graph.forward_inputs(Squeeze)
which gives me the following result
Loading resnet_w_frozen_inference_graph.pb
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS yet.
Converting as custom op NMS NMS
op: "NMS"
input: "concat_box_loc"
input: "concat_priorbox"
input: "concat_box_conf"
attr {
  key: "iouThreshold_u_float"
  value {
    f: 0.6000000238418579
attr {
  key: "maxDetectionsPerClass_u_int"
  value {
    i: 100
attr {
  key: "maxTotalDetections_u_int"
  value {
    i: 100
attr {
  key: "numClasses_u_int"
  value {
    i: 13
attr {
  key: "scoreConverter_u_str"
  value {
    s: "SIGMOID"
attr {
  key: "scoreThreshold_u_float"
  value {
    f: 9.99999993922529e-09
Warning: No conversion function registered for layer: concat_box_conf yet.
Converting as custom op concat_box_conf concat_box_conf
op: "concat_box_conf"
input: "BoxPredictor_0/Reshape_1"
input: "BoxPredictor_1/Reshape_1"
input: "BoxPredictor_2/Reshape_1"
input: "BoxPredictor_3/Reshape_1"
input: "BoxPredictor_4/Reshape_1"
input: "BoxPredictor_5/Reshape_1"
Warning: No conversion function registered for layer: concat_priorbox yet.
Converting as custom op concat_priorbox concat_priorbox
op: "concat_priorbox"
input: "PriorBox"
attr {
  key: "axis_u_int"
  value {
    i: 2
attr {
  key: "dtype"
  value {
    type: DT_FLOAT
Warning: No conversion function registered for layer: PriorBox yet.
Converting as custom op PriorBox PriorBox
op: "PriorBox"
input: "Const"
attr {
  key: "aspectRatios_u_flist"
  value {
    list {
      f: 1.0
      f: 2.0
      f: 0.5
attr {
  key: "featureMapShapes_u_ilist"
  value {
    list {
      i: 200
      i: 100
      i: 50
      i: 25
      i: 13
      i: 6
attr {
  key: "layerVariances_u_flist"
  value {
    list {
      f: 0.10000000149011612
      f: 0.20000000298023224
attr {
  key: "maxScale_u_float"
  value {
attr {
  key: "minScale_u_float"
  value {
attr {
  key: "numLayers_u_int"
  value {
    i: 6
Warning: No conversion function registered for layer: concat_box_loc yet.
Converting as custom op concat_box_loc concat_box_loc
op: "concat_box_loc"
input: "BoxPredictor_0/Reshape"
input: "BoxPredictor_1/Reshape"
input: "BoxPredictor_2/Reshape"
input: "BoxPredictor_3/Reshape"
input: "BoxPredictor_4/Reshape"
input: "BoxPredictor_5/Reshape"
No. nodes: 292
UFF Output written to resnet_w_frozen_inference_graph.pb.uff
As you can see I’m interested in bigger images 1600x1600, i’ve changed the code to handle that and even started the optimization process, I’m however stuck at this point
INFO: Formats and tactics selection completed in 11.507 seconds.
INFO: After reformat layers: 57 layers
INFO: Block size 1073741824
INFO: Block size 81920000
INFO: Block size 30835456
INFO: Block size 5546240
INFO: Block size 5120000
INFO: Block size 2720000
INFO: Block size 2080000
INFO: Block size 680192
INFO: Block size 640000
INFO: Block size 170240
INFO: Block size 160000
INFO: Block size 46080
INFO: Block size 40192
INFO: Block size 9984
INFO: Total Activation Memory: 1203714816
sample_uff_ssd: NvPluginSSD.cu:795: virtual void nvinfer1::plugin::DetectionOutput::configure(const nvinfer1::Dims*, int, const nvinfer1::Dims*, int, int): Assertion `numPriors*numLocClasses*4 == inputDims[param.inputOrder[0]].d[0]' failed.
and i would like to see what’s under the hood to fix my problem.
I have a good understanding of the code but I can’t find a way to print any useful message from the detection plugin.
Any suggestions on how to solve this, Is there any way to check the dimensions passed ?
It should be caused by your feature map size. would you mind to share your config file in tensorflow and in tensorrt.
My tensorrt config is on the first post,
my tensorflow config is as follows
model {
  ssd {
    num_classes: 12
    image_resizer {
      fixed_shape_resizer {
        height: 1600
        width: 1600
        resize_method: AREA
    feature_extractor {
      type: "ssd_resnet_w_v1"
      depth_multiplier: 1.0
      min_depth: 0
      conv_hyperparams {
        regularizer {
          l2_regularizer {
            weight: 0.000500000023749
        initializer {
          truncated_normal_initializer {
            mean: 0.0
            stddev: 0.0299999993294
        activation: NONE
    box_coder {
      faster_rcnn_box_coder {
        y_scale: 10.0
        x_scale: 10.0
        height_scale: 5.0
        width_scale: 5.0
    matcher {
      argmax_matcher {
        matched_threshold: 0.5
        unmatched_threshold: 0.5
        ignore_thresholds: false
        negatives_lower_than_unmatched: true
        force_match_for_each_row: true
    similarity_calculator {
      iou_similarity {
    box_predictor {
      convolutional_box_predictor {
        conv_hyperparams {
          regularizer {
            l2_regularizer {
          initializer {
              mean: 0.0
          activation: NONE
        min_depth: 40
        max_depth: 40
        num_layers_before_predictor: 1
        use_dropout: false
        dropout_keep_probability: 0.800000011921
        kernel_size: 3
        box_code_size: 4
        apply_sigmoid_to_scores: false
    anchor_generator {
      ssd_anchor_generator {
        num_layers: 6
        min_scale: 0.0196299999952
        max_scale: 0.17745000124
        aspect_ratios: 1.0
        aspect_ratios: 2.0
        aspect_ratios: 0.5
        reduce_boxes_in_lowest_layer: false
        height_stride: 8
        height_stride: 16
        height_stride: 32
        height_stride: 64
        height_stride: 128
        height_stride: 256
        width_stride: 8
        width_stride: 16
        width_stride: 32
        width_stride: 64
        width_stride: 128
        width_stride: 256
    post_processing {
      batch_non_max_suppression {
        score_threshold: 0.10000000149
        iou_threshold: 0.40000000596
        max_detections_per_class: 100
        max_total_detections: 400
      score_converter: SOFTMAX
    normalize_loss_by_num_matches: true
    loss {
      localization_loss {
        weighted_smooth_l1 {
          anchorwise_output: true
      classification_loss {
        weighted_softmax {
      hard_example_miner {
        num_hard_examples: 300
        iou_threshold: 0.699999988079
        loss_type: CLASSIFICATION
        max_negatives_per_positive: 3
        min_negatives_per_image: 0
      classification_weight: 1.0
      localization_weight: 1.0
eval_config {
  num_visualizations: 50
  num_examples: 60000
  max_evals: 0
  use_moving_averages: false
eval_input_reader {
  label_map_path: "/media/nikolas/Data1/tf_converted/label_map.pbtxt"
  shuffle: false
  num_epochs: 1
  num_readers: 1
  tf_record_input_reader {
    input_path: "/media/nikolas/Data1/tf_converted/test.record"
I’ve converted my model to a serialized engine.
When i run the inception_v2 model i get some results
when i run mine i get all zeros.
I know the model works since i evaluated it in tensorflow, the question is, is there any utility to check out the weights and/or the convertion ?
the feature maps should be:
featureMapShapes=[100,50,25,13,7,4])
