I am trying to convert frozen graph of ssd_resnet50_fpn_coco from Tensorflow detection model zoo to UFF.
In process of conversion, I changed my config.py as follows:
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node("Input",
op="Placeholder",
dtype=tf.float32,
shape=[1, 3, 640, 640])
PriorBox = gs.create_node("PriorBox",
#numLayers=6,
#minScale=0.2,
#maxScale=0.95,
min_level= 3,
max_level = 7,
anchor_scale = 4.0,
aspectRatios=[1.0, 2.0, 0.5],
layerVariances=[0.1,0.1,0.2,0.2],
featureMapShapes=[80, 40, 20, 10, 5])
NMS = gs.create_node("NMS",
scoreThreshold=0.3,
iouThreshold=0.6,
maxDetectionsPerClass=100,
maxTotalDetections=100,
numClasses=91,
scoreConverter="SIGMOID")
concat_priorbox = gs.create_node("concat_priorbox", dtype=tf.float32, axis=2)
concat_box_loc = gs.create_node("concat_box_loc")
concat_box_conf = gs.create_node("concat_box_conf")
namespace_plugin_map = {
"Postprocessor": NMS,
"MultiscaleGridAnchorGenerator": PriorBox,
"Preprocessor": Input,
# "ToFloat": Input,
# "image_tensor": Input,
#"Postprocessor/BatchMultiClassNonMaxSuppression/map/while/MultiClassNonMaxSuppression/Concatenate": concat_priorbox,
"concat": concat_box_loc,
"concat_1": concat_box_conf,
namespace_remove = {
"ToFloat",
"image_tensor",
"Preprocessor/map/TensorArrayStack_1/TensorArrayGatherV3",
def preprocess(dynamic_graph):
# remove the unrelated or error layers
dynamic_graph.remove(dynamic_graph.find_nodes_by_path(namespace_remove), remove_exclusive_dependencies=False)
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
# Remove the Squeeze to avoid "Assertion `isPlugin(layerName)' failed"
# Squeeze = dynamic_graph.find_node_inputs_by_name(dynamic_graph.graph_outputs[0], 'Squeeze')
# dynamic_graph.forward_inputs(Squeeze)
After running the command:
python convert_to_uff.py tensorflow --input-file ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03/frozen_inference_graph.pb -O NMS -p config_ssd2018_resnet.py
The output log is as follows:
Loading ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03/frozen_inference_graph.pb
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS yet.
Converting as custom op NMS NMS
op: "NMS"
input: "concat_box_loc"
input: "concat_box_conf"
input: "concat_priorbox"
attr {
key: "iouThreshold_u_float"
value {
f: 0.600000023842
attr {
key: "maxDetectionsPerClass_u_int"
value {
i: 100
attr {
key: "maxTotalDetections_u_int"
value {
i: 100
attr {
key: "numClasses_u_int"
value {
i: 91
attr {
key: "scoreConverter_u_str"
value {
s: "SIGMOID"
attr {
key: "scoreThreshold_u_float"
value {
f: 0.300000011921
Warning: No conversion function registered for layer: concat_priorbox yet.
Converting as custom op concat_priorbox concat_priorbox
op: "concat_priorbox"
input: "NMS"
attr {
key: "axis_u_int"
value {
i: 2
attr {
key: "dtype"
value {
type: DT_FLOAT
Warning: No conversion function registered for layer: concat_box_conf yet.
Converting as custom op concat_box_conf concat_box_conf
op: "concat_box_conf"
input: "WeightSharedConvolutionalBoxPredictor/Reshape_1"
input: "WeightSharedConvolutionalBoxPredictor_1/Reshape_1"
input: "WeightSharedConvolutionalBoxPredictor_2/Reshape_1"
input: "WeightSharedConvolutionalBoxPredictor_3/Reshape_1"
input: "WeightSharedConvolutionalBoxPredictor_4/Reshape_1"
Warning: No conversion function registered for layer: concat_box_loc yet.
Converting as custom op concat_box_loc concat_box_loc
op: "concat_box_loc"
input: "WeightSharedConvolutionalBoxPredictor/Reshape"
input: "WeightSharedConvolutionalBoxPredictor_1/Reshape"
input: "WeightSharedConvolutionalBoxPredictor_2/Reshape"
input: "WeightSharedConvolutionalBoxPredictor_3/Reshape"
input: "WeightSharedConvolutionalBoxPredictor_4/Reshape"
No. nodes: 877
UFF Output written to ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03/frozen_inference_graph.pb.uff
From the above log, It is evident that “MultiscaleGridAnchorGenerator”: PriorBox isn’t parsed. Does TensorRT support FPN(Feature Pyramid Network) based object detection models? If yes, How do I modify config.py such that it generates UFF for the frozen graph of ssd_resnet50_v1_fpn_shared_box_predictor_640x640_coco14_sync_2018_07_03 model?
