Hi everyone. I want to modify sampleUffSSD to run inference on video and the model I want to use is ssd_mobilenet_v1.
I download ssd_mobilenet_v1_coco_2018_01_28. And run this command.
python3 /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py --input-file frozen_inference_graph.pb -O NMS -p config.py
But there is error
Loading frozen_inference_graph.pb
WARNING:tensorflow:From /usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py:185: FastGFile.__init__ (from tensorflow.python.platform.gfile) is deprecated and will be removed in a future version.
Instructions for updating:
Use tf.gfile.GFile.
WARNING: To create TensorRT plugin nodes, please use the `create_plugin_node` function instead.
UFF Version 0.5.5
=== Automatically deduced input nodes ===
[name: "Input"
op: "Placeholder"
input: "image_tensor:0"
attr {
key: "dtype"
value {
type: DT_FLOAT
attr {
key: "shape"
value {
shape {
dim {
dim {
dim {
dim {
Using output node NMS
Converting to UFF graph
Warning: No conversion function registered for layer: NMS_TRT yet.
Converting NMS as custom op: NMS_TRT
Warning: No conversion function registered for layer: FlattenConcat_TRT yet.
Converting concat_box_conf as custom op: FlattenConcat_TRT
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 93, in <module>
main()
File "/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py", line 89, in main
debug_mode=args.debug
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 187, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 157, in from_tensorflow
debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/lib/python3.6/dist-packages/uff/converters/tensorflow/converter.py", line 72, in convert_tf2uff_node
inp_node = tf_nodes[inp_name]
KeyError: 'image_tensor'
I’m using TensorRT 5.0.6, jetpack 4.2.0.
I saw a post https://devtalk.nvidia.com/default/topic/1025246/jetson-tx2/where-is-convert-to-uff/1
But I also don’t know how to download latest model.
Is there any solution?
Thanks in advance.
