Hello. I followed this page to install Cuda on Kali Linux 2022 Live! on my 32GB bootable pendrive:
[Install NVIDIA GPU Drivers | Kali Linux Documentation]
I have some problems after the installation. Cuda and other stuff don’t work properly:
┌──(root㉿kali)-[~]
└─# lspci | grep -i vga
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce 410M] (rev a1)
──(root㉿kali)-[~]
└─# lspci -s 01:00.0 -v
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce 410M] (rev a1) (prog-if 00 [VGA controller])
Subsystem: Sony Corporation GF119M [GeForce 410M]
Flags: bus master, fast devsel, latency 0, IRQ 28
Memory at d2000000 (32-bit, non-prefetchable) [size=16M]
Memory at c0000000 (64-bit, prefetchable) [size=256M]
Memory at d0000000 (64-bit, prefetchable) [size=32M]
I/O ports at 4000 [size=128]
Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Endpoint, MSI 00
Capabilities: [b4] Vendor Specific Information: Len=14 <?>
Capabilities: [100] Virtual Channel
Capabilities: [128] Power Budgeting <?>
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Kernel driver in use: nouveau
Kernel modules: nouveau, nvidia_current_drm, nvidia_current
┌──(root㉿kali)-[~]
└─# nvidia-detect
Detected NVIDIA GPUs:
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation GF119M [GeForce 410M] [10de:1055] (rev a1)
Checking card: NVIDIA Corporation GF119M [GeForce 410M] (rev a1)
Uh oh. Failed to identify your Debian suite.
┌──(root㉿kali)-[~]
└─# nvidia-smi
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver.
Make sure that the latest NVIDIA driver is installed and running.
┌──(root㉿kali)-[~]
└─# hashcat -I
hashcat (v6.2.5) starting in backend information mode
cuInit(): no CUDA-capable device is detected
OpenCL Info:
OpenCL Platform ID #1
Vendor..: The pocl project
Name....: Portable Computing Language
Version.: OpenCL 3.0 PoCL 3.0+debian Linux, None+Asserts, RELOC, LLVM 13.0.1, SLEEF, DISTRO, POCL_DEBUG
Backend Device ID #1
Type...........: CPU
Vendor.ID......: 128
Vendor.........: GenuineIntel
Name...........: pthread-Intel(R) Core(TM) i5-2450M CPU @ 2.50GHz
Version........: OpenCL 1.2 PoCL HSTR: pthread-x86_64-pc-linux-gnu-sandybridge
Processor(s)...: 4
Clock..........: 3100
Memory.Total...: 5888 MB (limited to 1024 MB allocatable in one block)
Memory.Free....: 2912 MB
OpenCL.Version.: OpenCL C 1.2 PoCL
Driver.Version.: 3.0+debian
System is updated and fully upgraded.
Can anybody help me and describe step by step what to do?
