problem with option -tp in pgf77 and pgf90 6.0
We are running PGI workstation on Debian Sarge on a Dual Opteron system either in 32- or 64-Bit mode (dual boot). Since version 6.0 compilation fails whenever we try to specify a target architecture with the “-tp” command line switch. Everything works perfeclty as long as we compile natively for the host machine, i.e. without “-tp”. The error message is the following (example for “pgf90 -tp px” compilation):
pgf90-Error–tp px not supported in this installation
We have re-installed the PGI Worlstation package several times but the error is persistent. This happens with 6.0-5 as well as 6.0-8, but not with 5.2-4 on the exact same machine. We urgently need to resolve this problem as we also have Dual Athlon-MP nodes for which we need to be able to compile our programs whith “-tp athlonxp”.
Hi scheurer,
Does this happen on both the 32-bit and the 64-bit OS? If it’s only the 64-bit, most likely the 32-bit compilers were not installed or the driver can’t find them. When you use an architecture flag, “-tp”, or the version flag “-V5.2”, the driver automatically restarts using the correct driver. In other words, if your use a 32-bit architecture flag with the 64-bit driver, the driver will call the 32-bit driver. In order to do this, the 32-bit compilers and drivers must be installed and be located in $PGI/linux86/6.0/bin/pgcc (or pgf90, pgf77, pghpf, pgCC). Since Debian isn’t supported, the installer may not be installing the 32-bit compilers since it can’t find the necessary 32-bit compatibilty libraries.
Actually, this error can occur even with a 64-bit architecture flag if you’ve installed somewhere other than $PGI/linux86-64/REL#/bin since the driver will restart even if it’s calling itself.
The good news is that you can work around this problem if the 32-bit compilers are installed. By default, even on an SSE2 enabled system the compilers do not generate SSE2 code. Only when the flags “-Mscalarsse” or “-fastsse” are used, does SSE2 code get generated. This means so long as you point your PATH to the 32-bit compiler directory and don’t use “-Mscalarsse” or “-fastsse”, you will generate code that can be run on an Athlon XP. Note that this will change in the upcoming 6.1 release where SSE2 instructions will be used by default on SSE2 enabled systems. However, the flag “-Mnoscalarsse” disables SSE2 code generation.
Hope this helps,
Mat
Hi mkcolg,
It also happens on the 32-bit OS and all compiler components are correctly installed in
$PGI/linux86//bin/pg* for 5.2 as well as 6.0. We usually use sym-links to map the pg* compilers into /usr/local/bin and up to version 5.2 this mapping worked without a problem.
I checked that everything works also with 6.0 if I explicitly call
$PGI/linux86/6.0/bin/pgf90 -V6.0 -tp athlonxp source.f
or
$PGI/linux86/6.0/bin/pgf90 -V5.2 -tp athlonxp source.f
but NOT if I go through the sym-link which maps
/usr/local/bin/pgf90 → $PGI/linux86/6.0/bin/pgf90
If I use the sym-link and just call (with /usr/local/bin in my $PATH):
I get the following error:
pgf90-Fatal-Could not find alternate compiler: /usr/6.0/bin/pgf90
which indicates that the frontend completely ignores the value of $PGI (since:
‘echo $PGI’ gives the correct answer /usr/local/share/pgi )
Is that an expected “feature”?
Regards,
Christoph
Christoph: Thanks for your post. I have tried to reproduce the behavior you are seeing, and I was unable to do so. I tried the following:
ln -s /usr/pgi/linux86-64/6.0/bin/pgf90 tempdir/pgf90
set path = ( tempdir/pgf90 $path )
rehash #I’m using tcsh
which pgf90 # make sure I’m getting the right pgf90
pgf90 a.f
pgf90 -V5.2 a.f
pgf90 -tp k8-32 a.f
pgf90 -tp k8-64 a.f
All of these worked for me, so I’m a bit at a loss. As you note, the driver does in fact ignore the value of $PGI when looking for the compiler; it finds the command from the path, and if it is a symbolic link, follows that link until it finds the install directory. For the -Vversion and -tp target switches, it uses relative directory paths from that install directory.
So, can you please do the following for me and send me the output:
ls -l /usr/local/bin/pg* # so I can see how the links are set up
pgf90 -dryrun a.f # shows the compile steps
pgf90 -dryrun -tp k8-32 a.f # shows what it’s trying to do
cat $PGI/linux86-64/6.0/bin/localrc # shows the installed local ‘rc’ file
cat $PGI/linux86/6.0/bin/localrc # shows installed local ‘rc’ file for 32-bit
You can post these here, that might help me find the problem.
Hi mwolfe,
thanks for looking into the problem. Your test with a simple symbolic link also worked for me. Our situation is a little more complex. We install the PGI compilers to:
/usr/local/stow/PGI/share/pgi
and use ‘stow’ to manage the mapping into /usr/local, i.e. everything under
/usr/local/stow/PGI is mapped to the corresponding location under /usr/local
and we set PGI=/usr/local/share/pgi . Our full setup is therefore:
ls -l /usr/local/stow/PGI
lrwxrwxrwx 1 root root 25 Nov 24 15:05 bin → share/pgi/linux86/6.0/bin
drwxr-xr-x 2 root root 4096 Nov 24 15:06 doc
drwxr-xr-x 2 root root 4096 Nov 24 15:06 include
lrwxrwxrwx 1 root root 25 Nov 24 15:05 lib → share/pgi/linux86/6.0/lib
lrwxrwxrwx 1 root root 25 Nov 24 15:05 man → share/pgi/linux86/6.0/man
drwxr-xr-x 5 root root 4096 Nov 24 15:08 share
ls -l /usr/local/stow/PGI/include
lrwxrwxrwx 1 root root 32 Nov 24 15:06 pgi → ../share/pgi/linux86/6.0/include
That way the most recent binaries, libraries, etc. are mapped into the standard locations underneath /usr/local , e.g.
ls -l /usr/local/bin/pgf90
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgf90 → ../stow/PGI/bin/pgf90
Here is the additional information you requested:
lrwxrwxrwx 1 root root 20 Nov 24 15:09 /usr/local/bin/pgCC → ../stow/PGI/bin/pgCC
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgappend → ../stow/PGI/bin/pgappend
lrwxrwxrwx 1 root root 19 Nov 24 15:09 /usr/local/bin/pgc → ../stow/PGI/bin/pgc
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgc_ex → ../stow/PGI/bin/pgc_ex
lrwxrwxrwx 1 root root 20 Nov 24 15:09 /usr/local/bin/pgcc → ../stow/PGI/bin/pgcc
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgcpp1 → ../stow/PGI/bin/pgcpp1
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgcpp2 → ../stow/PGI/bin/pgcpp2
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgcpp2ex → ../stow/PGI/bin/pgcpp2ex
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgdbg → ../stow/PGI/bin/pgdbg
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgdbg1 → ../stow/PGI/bin/pgdbg1
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgdebug → ../stow/PGI/bin/pgdebug
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgdecode → ../stow/PGI/bin/pgdecode
lrwxrwxrwx 1 root root 25 Nov 24 15:09 /usr/local/bin/pgextract → ../stow/PGI/bin/pgextract
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgf77 → ../stow/PGI/bin/pgf77
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgf77rc → ../stow/PGI/bin/pgf77rc
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgf901 → ../stow/PGI/bin/pgf901
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgf902 → ../stow/PGI/bin/pgf902
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgf90_ex → ../stow/PGI/bin/pgf90_ex
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgf90rc → ../stow/PGI/bin/pgf90rc
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgf95 → ../stow/PGI/bin/pgf95
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgftn → ../stow/PGI/bin/pgftn
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgftn_ex → ../stow/PGI/bin/pgftn_ex
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgftnrc → ../stow/PGI/bin/pgftnrc
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pghostid → ../stow/PGI/bin/pghostid
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pghpf → ../stow/PGI/bin/pghpf
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pghpf1 → ../stow/PGI/bin/pghpf1
lrwxrwxrwx 1 root root 25 Nov 24 15:09 /usr/local/bin/pghpf1_ex → ../stow/PGI/bin/pghpf1_ex
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pghpf2 → ../stow/PGI/bin/pghpf2
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pghpfrc → ../stow/PGI/bin/pghpfrc
lrwxrwxrwx 1 root root 21 Nov 24 15:09 /usr/local/bin/pgipa → ../stow/PGI/bin/pgipa
lrwxrwxrwx 1 root root 25 Nov 24 15:09 /usr/local/bin/pglicinfo → ../stow/PGI/bin/pglicinfo
lrwxrwxrwx 1 root root 24 Nov 24 15:09 /usr/local/bin/pgprepro → ../stow/PGI/bin/pgprepro
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgprof → ../stow/PGI/bin/pgprof
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgroupd → ../stow/PGI/bin/pgroupd
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgserv → ../stow/PGI/bin/pgserv
lrwxrwxrwx 1 root root 22 Nov 24 15:09 /usr/local/bin/pgsize → ../stow/PGI/bin/pgsize
lrwxrwxrwx 1 root root 23 Nov 24 15:09 /usr/local/bin/pgsmart → ../stow/PGI/bin/pgsmart
pgf90 -dryrun a.f
Reading rcfile /usr/local/bin/.pgf90rc
Reading rcfile /usr/local/bin/nativerc
Reading rcfile /usr/local/bin/fnativerc
Reading rcfile /usr/local/bin/x86rc
Reading rcfile /usr/local/bin/x8664rc
Reading rcfile /usr/local/bin/lin86rc
Reading rcfile /usr/local/bin/lin8664rc
Reading rcfile /usr/local/bin/iparc
Reading rcfile /usr/local/bin/pgf90rc
Reading rcfile /usr/local/bin/pgftnrc
Reading rcfile /usr/local/bin/localrc
Skipping siterc (not found)
Skipping .mypgf90rc (not found)
/usr/local/bin/pgf901 a.f -opt 1 -terse 1 -inform warn -nohpf -nostatic -x 19 0400000 -quad -x 59 4 -x 15 2 -x 49 0x400004 -x 51 0x20 -x 57 0x4c -x 58 0x10000-x 124 0x1000 -x 57 0xfb0000 -x 58 0x78031040 -x 48 4608 -x 49 0x100 -x 120 0x20 -stdinc /usr/local/include:/usr/local/include:/usr/lib/gcc-lib/x86_64-linux/33.5/include:/usr/lib/gcc-lib/x86_64-linux/3.3.5/include:/usr/include -def unix def __unix -def unix -def linux -def __linux -def linux -def inline -def NO_INLINE -def __NO_MATH_INLINES -def x86_64 -def LONG_MAX=923372036854775807L -def ‘SIZE_TYPE=unsigned long int’ -def ‘__PTRDIFF_TYPE__long int’ -def __THROW= -def amd64 -nofreeform -vect 48 -output /scratch/sceurer/pgf90aaaaaFoiaj.ilm
/usr/local/bin/pgf902 /scratch/scheurer/pgf90aaaaaFoiaj.ilm -fn a.f -opt 1 -tere 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 122 0x40 -x 123 0x1000 -x 127 4 x 19 0x400000 -quad -x 120 0x80000000 -x 59 4 -y 80 0x1000 -x 80 0x10800000 -x 24 0x1400 -y 15 2 -y 80 0x1000 -x 80 0x10800000 -x 57 0x3b0000 -x 58 0x48000000-x 49 0x100 -x 120 0x200 -astype 0 -x 124 1 -asm /scratch/scheurer/pgf90baaaaFoaj.s
/usr/bin/as /scratch/scheurer/pgf90baaaaFoiaj.s -o /scratch/scheurer/pgf90caaaaoiaj.o
/usr/bin/ld /usr/lib64/crt1.o /usr/lib64/crti.o /usr/lib/gcc-lib/x86_64-linux/33.5/crtbegin.o /usr/local/lib/f90main.o -m elf_x86_64 -dynamic-linker /lib64/ldlinux-x86-64.so.2 /scratch/scheurer/pgf90caaaaFoiaj.o -L/usr/local/lib -L/usr/lb64 -L/usr/lib/gcc-lib/x86_64-linux/3.3.5 -rpath /usr/local/lib -lpgf90 -lpgf90rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lc -lnspgc -lpgc -lm -lgcc -lc -lgcc /usr/ib/gcc-lib/x86_64-linux/3.3.5/crtend.o /usr/lib64/crtn.o
Unlinking /scratch/scheurer/pgf90aaaaaFoiaj.ilm
Unlinking /scratch/scheurer/pgf90aaaaaFoiaj.dbg
Unlinking /scratch/scheurer/pgf90baaaaFoiaj.s
Unlinking /scratch/scheurer/pgf90caaaaFoiaj.o
pgf90-Error–tp k8-32 not supported in this installation
set LFC=-lg2c;
set LDSO=/lib64/ld-linux-x86-64.so.2;
set GCCDIR=/usr/lib/gcc-lib/x86_64-linux/3.3.5;
set GCCINC=/usr/lib/gcc-lib/x86_64-linux/3.3.5/include;
set G77DIR=/usr/lib/gcc-lib/x86_64-linux/3.3.5;
set THROW=__THROW=;
makelocalrc executed by root Fri Oct 14 19:55:11
set LFC=-lg2c;
set LDSO=/lib/ld-linux.so.2;
set GCCDIR=/usr/lib/gcc-lib/x86_64-linux/3.3.5/32;
set G77DIR=/usr/lib/gcc-lib/x86_64-linux/3.3.5/32;
set THROW=__THROW=;
set DEFLIBDIR=/usr/lib;
set DEFSTDOBJDIR=/usr/lib;
set EXTRAASARGS=–32;
For comparison, this is the output if I specify the path explicitly:
$PGI/linux86-64/6.0/bin/pgf90 -dryrun -tp k8-32 a.f
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/.pgf90rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/nativerc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/fnativerc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/x86rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/x8664rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/lin86rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/lin8664rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/iparc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/pgf90rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/pgftnrc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86-64/6.0/bin/localrc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/.pgf90rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/nativerc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/fnativerc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/x86rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/x8632rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/lin86rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/lin8632rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/iparc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/pgf90rc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/pgftnrc
Reading rcfile /usr/local/stow/PGI/share/pgi/linux86/6.0/bin/localrc
/usr/local/stow/PGI/share/pgi/linux86/6.0/bin/pgf901 a.f -opt 1 -terse 1 -inform warn -nohpf -nostatic -x 119 0x100000 -x 19 0x400000 -x 59 4 -x 15 2 -x 49 0x400004 -x 51 0x20 -x 57 0x4c -x 58 0x10000 -x 124 0x1000 -x 57 0xfb0000 -x 58 0x78031040 -x 48 3328 -stdinc /usr/local/stow/PGI/share/pgi/linux86/6.0/include:/usr/local/include:/usr/lib/gcc-lib/x86_64-linux/3.3.5/include:/usr/lib/gcc-lib/x86_64-linux/3.3.5/32/include:/usr/include -def unix -def __unix -def unix -def linux -def __linux -def linux -def inline= -def i386 -def __i386 -def i386 -def __NO_MATH_INLINES -def linux86 -def __THROW= -nofreeform -vect 48 -output /scratch/scheurer/pgf90aaaaanpiaA.ilm
/usr/local/stow/PGI/share/pgi/linux86/6.0/bin/pgf902 /scratch/scheurer/pgf90aaaaanpiaA.ilm -fn a.f -opt 1 -terse 1 -inform warn -x 51 0x20 -x 119 0xa10000 -x 119 0x100000 -x 122 0x40 -x 123 0x1000 -x 127 4 -x 119 0x40000000 -x 19 0x400000 -x 59 4 -x 124 0x1400 -y 15 2 -x 57 0x3b0000 -x 58 0x48000000 -astype 0 -x 124 1 -x 80 0x08000000 -y 80 0x1000 -asm /scratch/scheurer/pgf90baaaanpiaA.s
/usr/bin/as /scratch/scheurer/pgf90baaaanpiaA.s --32 -o /scratch/scheurer/pgf90caaaanpiaA.o
/usr/bin/ld /usr/lib/crt1.o /usr/lib/crti.o /usr/lib/gcc-lib/x86_64-linux/3.3.5/32/crtbegin.o /usr/local/stow/PGI/share/pgi/linux86/6.0/lib/f90main.o -m elf_i386 -dynamic-linker /lib/ld-linux.so.2 /scratch/scheurer/pgf90caaaanpiaA.o -L/usr/local/stow/PGI/share/pgi/linux86/6.0/lib -L/usr/lib -L/usr/lib/gcc-lib/x86_64-linux/3.3.5/32 -rpath /usr/local/stow/PGI/share/pgi/linux86/6.0/lib -lpgf90 -lpgf90_rpm1 -lpgf902 -lpgf90rtl -lpgftnrtl -lpgsse1 -lpgsse2 -lc -lnspgc -lpgc -lm -lgcc -lc -lgcc /usr/lib/gcc-lib/x86_64-linux/3.3.5/32/crtend.o /usr/lib/crtn.o
Unlinking /scratch/scheurer/pgf90aaaaanpiaA.ilm
Unlinking /scratch/scheurer/pgf90aaaaanpiaA.dbg
Unlinking /scratch/scheurer/pgf90baaaanpiaA.s
Unlinking /scratch/scheurer/pgf90caaaanpiaA.o
To be honest, I think it is flawed logic not to look into the installation directory pointed to by the environment variable $PGI to find the installation directory but instead to rely on completely and recursively walking along all possible sym-links to find it. If I set the environment variable, then that is for a good reason and should be more reliable. At least as a last resort the frontend should search there instead of just giving up.
As a workaround (since I can’t look at the inner logic of the compiler), would it be sufficient to remove all but the pgf90, pgf77, pgCC, and pgcc frontends from /usr/local/bin to have the frontend “realize” that /usr/local/bin is NOT the installation directory. Since to me it seems that this is what causes the problem.
Regards,
Christoph
Hi again. Actually, you’ve found the solution already, but I’ll explain anyway. I was able this time to reproduce the problem you’ve found, and tested the solution, as described here.
When the driver looks for the install directory, it follows symbolic links until it finds the main ‘rc’ file; for linux, this would be .pgccrc, .pgf90rc, .pgCCr, .pgf95rc, etc., depending on the compiler. When it finds those, it assumes it’s found the install directory. If you remove these links from /usr/local/bin, the compilers should work as expected. You will also find that the other links in /usr/local/bin, such as the actual compilers (pgc, pgc_ex, pgf901, pgf902, pgftn, etc.) will never get used, as well as the other rcfiles in that directory, so they could be removed as well.
Years ago, the compiler driver depended on the setting of the $PGI environment variable to find the installation directory. As you might imagine, we had no end of problems from users who either did not set the variable, or set it to one value, then changed their path, expecting to get the compiler from the new path (but instead it used the old PGI variable setting), or used a full path to a version of the compiler. We chose to use the path instead, to require fewer changes to a user’s settings.
  • Michael Wolfe
Hi mwolfe,
Thank you for your response. I see your point, but how about adding a lookup in $PGI AFTER trying to find the install directory from the path fails? Or the other way around, if nothing is found under $PGI, then try to figure it out by the path. Btw. what is the environment variable really used for currently?
Anyway, I removed the additional files and just left the few compiler frontends in “bin”. It is just simpler to renew one link to the whole “bin” directory after an upgrade than to do that for each frontend individually.
Regards,
Christoph
