Problem with reduction
Hi everybody,
I am trying to do the 2_norm of each column of a Matrix and find which one is the minimum.
It looks like this:
__global__ void obtener_s_gpu (float *HT, int m, int n, float *c, int L, float *ss, int *ids, float *normaBloque)
	int i,j;
	int posib, div, resto;
	float mult;
	int thread;
	int nTotalThreads = blockDim.x;	// Total number of threads per block (512)
	int numBlocks = gridDim.x;	// Total number of block threads
	int idx=blockIdx.x*blockDim.x+threadIdx.x;
	// Declare arrays to be in shared memory.
	__shared__ float norma[3];
	posib=(int)pow((float)L,m);
	if (idx<posib)
		div = idx;
		//building s
		for (i=0; i<m; i++)
			resto=div%L;
			ss[i*posib+idx]=(-L+1.0)/2.0+resto;
			div=div/L;
		norma[threadIdx.x]=0.0;
		for (i=m-1; i>-1; i--)
			mult=0.0;
			for (j=m-1; j>i-1; j--)
				mult=mult+HT[j*n+i]*ss[j*posib+idx]; //mul=mul+R[i*m+j]*ss[j]
			mult=mult-c[i];
			norma[threadIdx.x] = norma[threadIdx.x] + mult*mult;
		norma[threadIdx.x]=sqrt(norma[threadIdx.x]);
	}else{
		norma[threadIdx.x]=INF;
	__syncthreads();
	thread=idx;
	//Encontrar la menor norma
	while(nTotalThreads > 1)
		int halfPoint = (nTotalThreads >> 1);	// divide by two
		// only the first half of the threads will be active.
		if (threadIdx.x < halfPoint)
			// Get the shared value stored by another thread
			float temp = norma[threadIdx.x + halfPoint];
			if (temp < norma[threadIdx.x])
				norma[threadIdx.x] = temp;
				thread=thread+halfPoint;
		__syncthreads();
		nTotalThreads = (nTotalThreads >> 1);	// divide by two.
	__syncthreads();
	if(threadIdx.x==0)
		normaBloque[numBlocks] = norma[0];
		ids[numBlocks] = thread;
	__syncthreads();
Everything seems to work fine, but when I add the line " ids[blockIdx.x] = thread; " something happens.
Exit without that line:
6 threads en total. Se necesitan 2 bloques
posibles vectores de s: 4
Matriz ss:
-0.500000 0.500000 -0.500000 0.500000
-0.500000 -0.500000 0.500000 0.500000
ids_0: 1094378115
normaBloque_0: 6.114271
ids_1: 1063137839
normaBloque_1: 8.192823
Adding the line:
Matriz ss:
0.000000 0.000000 0.000000 0.000000
ids_0: 0
normaBloque_0: 0.000000
ids_1: 0
normaBloque_1: 0.000000
How can it happen??, any idea??.
I declared ids like normaBloque, and the last one looks fine, so I don’t think that’s the problem.
cudaMalloc ((void **) &normaBloque_d, gridSize*sizeof(float));
cudaMalloc ((void **) &ids_d, gridSize*sizeof(int));
I give it to the kernel and then copy it to host with :
cudaMemcpy(normaBloque, normaBloque_d, gridSize*sizeof(float), cudaMemcpyDeviceToHost);
cudaMemcpy(ids, ids_d, gridSize*sizeof(int), cudaMemcpyDeviceToHost);
I am lost…
Edited: Here is the full Kernel code, maybe now it’s clearer… or maybe not. First I build the vector, then calculate the 2_norm, and then find the minimum.
Everything works but the ids vector. Also, when I execute the screen flashes a little. Why am I doing wrong???.
I found the problem. I was giving the ids vector to the kernel, instead of ids_d…
Silly mistake, so sorry.
