Primary PCI-E 16x : 9800gx2 card1
Second PCI-E 16x : 9800gx2 card2
Motherboard: No SLI support and no overclocking.
PowerSupply: Antec Quattro 850W (certified to work in Quad SLI mode).
I am able to boot the PC with only one of the 9800gx2.
If I give the power supply to both the 9800gx2 then the PC does not boot
and the usual blue light in the geforce 9800gx2 card is absent.
Can you suggest if I am overlooking something in this process ?
Which motherboard you are using? Which chipset? How many PCIe 2.0 16x slots your motherboard has? Are all of them at 16x speed?
As I know, GX2 cards (from gigabyte) have LED indicators around SLI connectors and you will see those LEDs light red if their power is a problem. So power is probably ok.
Check documentation of your motherboard for all PCIe slots. I’am not sure does GX2 work in non 16x slot.
If I am reading this correctly you are trying to run Quad SLI on an Intel mobo ?
Thats not possible because its an ATI Crossfire board & altho you can have SLI with GX2
it only works with one of them so you cannot have two seperate cards working in unison
unless they are ATI
9800GX2 contains two cards fitted together inside it’s case with a SLi bridge
If you look upstairs, these are the CUDA forums. CUDA sees each device as a separate device, and you need to address each device separately. This is not about gaming ;)
One of problems could be,
as you said you are not using SLI. But how do you know that? You think it is enough to leave SLI adapter disconnected and cards are not in SLI mode?
That is true only if you are using cards with single GPU. But GX2 has two GPUs and has some kind of adjustable built in integrated SLI adapter (off course it has an external SLI connector too allows it to connect to other cards). Adjustable means you can manage SLI connection through software (turning it on/off) between those two GPUs on single GX2 card. Offcourse it is adjustable when you start nvidia driver installation under windows but until that, during PC powers on, BIOS should properly interpret it. But it seems BIOS doesn’t do that on right way.
As you probably know, nvidia reserves all rights for multi GPUs platform working in SLI with more than 2 GPUs. It means three or more GPUs in SLI mode could run only on motherboards with nvidia chipsets. Off course you plan to work on CUDA in only possible non SLI mode (if you want all GPUs are visible to CUDA) but maybe BIOS doesn’t see that as you do.
Contact ASUS support center. BIOS update could solve problem.
Also, I’m curious, did you buy all components together or you already had motherboard? If components are new I would replace motherboard (or smash it on dealer head because he didn’t warn you about possible problems) For an extra cache on your board price you can buy PCIe 2.0 motherboard with nvidia chipset and get full performance from your GX2 cards. If you are not using water cooling system then increase that extra cache for a price of an extra case fan. (Just trying to save you go twice in the store)
Problem being that inserting a GX2 introduces Sli regardless of whether you want it or not hence the failure of his mobo to fire up with more than one inserted.
SLi is also a hardware thing, the Intel mobo can’t accept the four cards inserted in two slots ,thats why he can boot with one inserted but not with both, or indeed with any other second card by the looks of it
I think EDR is right, it does smell like a BIOS issue.
But one explicit test first. Have you tried booting with each card seperately?
you say “I am able to boot the PC with only one of the 9800gx2” but that may not be enough tests to rule out a card problem. If card 1 is in slot 1 and card 2 is in slot 2, can you boot the machine successfully with JUST card 1 in slot 1? And if so, as a second test, can you boot the machine properly with JUST card 2 in slot 2?
Power is always a likely problem, but your PSU seems beefy enough AND you tested with a low-end card+GX2 (which also failed).
Which leaves BIOS. you may try even older BIOS revisions just to check if it was something the motherboard engineers broke recently. And clearly press them hard in email.
