I am trying to learn CUDA and reading one of the recommended book “CUDA by Example” by Sanders and Kandrot. In chapter 5, there is a vector addition example. Basiclly, the program takes in two vectors of certain length and finds the summation of the two.
The example by itself works fine but if I increase the number of elements in the vector, the program crashes.
The following works fine:
#define NUMBER_OF_ELEMENT (64*1024)
The following will crash:
#define NUMBER_OF_ELEMENT (128*1024)
I am also attaching the complete code.
I am trying the program on a XPS15 which has 525m 1GB memory. I think it is not limited by the memory size. Also, the example is designed to work with large vector size. So, what is wrong?
Thanks a lot for your time!
VectorSumUnlimited.cu (1.43 KB)
