Hello everyone,
I am planning to use yolov3 with jetson NX for object detection (one classe for now).
After the training part, I’ve weird results with pruning, here my logs :
2020-09-14 07:59:02.401363: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
Using TensorFlow backend.
2020-09-14 07:59:08.733838: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcuda.so.1
2020-09-14 07:59:08.808197: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:08.809463: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1618] Found device 0 with properties:
name: TITAN RTX major: 7 minor: 5 memoryClockRate(GHz): 1.77
pciBusID: 0000:01:00.0
2020-09-14 07:59:08.809513: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-14 07:59:08.862914: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcublas.so.10.0
2020-09-14 07:59:08.892049: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcufft.so.10.0
2020-09-14 07:59:08.903280: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcurand.so.10.0
2020-09-14 07:59:08.969313: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusolver.so.10.0
2020-09-14 07:59:09.014495: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcusparse.so.10.0
2020-09-14 07:59:09.126092: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudnn.so.7
2020-09-14 07:59:09.126417: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:09.128208: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:09.129815: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1746] Adding visible gpu devices: 0
2020-09-14 07:59:09.130756: I tensorflow/stream_executor/platform/default/dso_loader.cc:44] Successfully opened dynamic library libcudart.so.10.0
2020-09-14 07:59:11.048474: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1159] Device interconnect StreamExecutor with strength 1 edge matrix:
2020-09-14 07:59:11.048544: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1165] 0
2020-09-14 07:59:11.048571: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1178] 0: N
2020-09-14 07:59:11.048980: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:11.051577: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:11.053667: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:983] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2020-09-14 07:59:11.055275: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1304] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 22504 MB memory) → physical GPU (device: 0, name: TITAN RTX, pci bus id: 0000:01:00.0, compute capability: 7.5)
2020-09-14 07:59:12,577 [INFO] modulus.pruning.pruning: Exploring graph for retainable indices
2020-09-14 07:59:15,553 [INFO] modulus.pruning.pruning: Pruning model and appending pruned nodes to new graph
2020-09-14 08:00:31,284 [INFO] iva.common.magnet_prune: Pruning ratio (pruned model / original model): 0.02986864959372703
Is the ratio 0.0298 regular?
After retraining my pruned model, I came to 2.5 it/s (batch 1 image) on a Titan RTX with fp32, and it’s really slow for my computer (Typical tensorflow inférenece was about 10 fps), and is the same if I choose to use fp16.
What have been doing wrong?
