Problems installing nccl on Ubuntu 22.04
Ubuntu 22.04, nvcc successfully installed
Copyright (c) 2005-2021 NVIDIA Corporation
Built on Thu_Nov_18_09:45:30_PST_2021
Cuda compilation tools, release 11.5, V11.5.119
Build cuda_11.5.r11.5/compiler.30672275_0
I’m trying to install nccl, without success. I registered on the nvidia site and answered the questions, then
I followed the insructions and finally the result is
ldconfig -p | grep libnccl
libnccl.so.2 (libc6,x86-64) => /lib/x86_64-linux-gnu/libnccl.so.2
libnccl.so (libc6,x86-64) => /lib/x86_64-linux-gnu/libnccl.so
I don’t know if something is missing, because then if I try nccl -version it gives me command not found
nccl -version
Comando «nccl» non trovato, si intendeva forse:
  comando «nxcl» da deb libnxcl-bin (0.9-3.1ubuntu4)
  comando «ncl» da deb ncl-ncarg (6.6.2-10build2)
  comando «ccl» da deb cclive (0.9.3-0.2build1)
  comando «ncal» da deb ncal (12.1.7+nmu3ubuntu2)
Thanks! E
nccl is not an executable but a library which got installed.
