Problems to integrate Model Pytorch with Transforms in Deepstreams
• Hardware Platform : Orin AGX
• DeepStream Version 6.3
• JetPack Version : 5.1.2
• TensorRT Version : 8.5
Hey,
I use models for classifying gender and age from Hugging Face (composed with Transformers in PyTorch). I convert these models to ONNX and integrate them into DeepStream applications. When I execute the code, it converts the models to an engine, but it doesn’t show me anything (labels Classifications)
I use the output-blob-names for these models (output):
import onnx
import onnxruntime
# Load the ONNX model
onnx_path='gender_classification_model.onnx'
onnx_model = onnx.load(onnx_path)
# Print all output layers in the ONNX model
output_layers = [node.name for node in onnx_model.graph.output]
print("Output layers:", output_layers)
It Not gives me a warning when I use output-blob-names:
0:00:06.761897556 32790 0x2b23a00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1988> [UID = 3]: deserialized trt engine from :/home/anavid/Desktop/shopanalytics_V2/model_classi_gendre/gender_classification_model.onnx_b2_gpu0_fp16.engine
INFO: [FullDims Engine Info]: layers num: 2
0 INPUT kFLOAT input 3x224x224 min: 1x3x224x224 opt: 2x3x224x224 Max: 2x3x224x224
1 OUTPUT kFLOAT output 2 min: 0 opt: 0 Max: 0
0:00:06.937877182 32790 0x2b23a00 INFO nvinfer gstnvinfer.cpp:682:gst_nvinfer_logger:<secondary2-nvinference-engine> NvDsInferContext[UID 3]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2091> [UID = 3]: Use deserialized engine model: /home/anavid/Desktop/shopanalytics_V2/model_classi_gendre/gender_classification_model.onnx_b2_gpu0_fp16.engine
0:00:06.941190358 32790 0x2b23a00 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<secondary2-nvinference-engine> [UID 3]: Load new model: config_huggings_genre.txt successfully
i use this file configuration :
[property]
gpu-id=0
net-scale-factor=1
onnx-file=model_classi_gendre/gender_classification_model.onnx
model-engine-file=model_classi_gendre/gender_classification_model.onnx_b2_gpu0_fp16.engine
labelfile-path=model_classi_gendre/labels_gendre.txt
batch-size=2
# 0=FP32 and 1=INT8 mode
network-mode=2
network-type=1
num-detected-classes=2
input-object-min-width=14
input-object-min-height=14
process-mode=2
secondary-reinfer-interval=0
model-color-format=0
output-blob-names=output
gie-unique-id=3
operate-on-gie-id=2
is-classifier=1
classifier-async-mode=0
classifier-threshold=0.5
scaling-filter=1
scaling-compute-hw=2
But it doesn’t perform the classifications. I need help integrating these models into my apps.
Could you refer to our FAQ to learn how to use the classifier as pgie?
