FROM nvcr.io/nvidia/deepstream:5.1-21.02-devel
• Hardware Platform (GPU)
• DeepStream Version 5.1
• JetPack Version -
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) - 460.91.03
• Issue Type - question
Pytorch 1.9.1
I have used this script to convert model from Pytorch model zoo to onnx:
import torchvision.models as models
import torch.onnx
mobilenet_v3_large = models.mobilenet_v3_large().eval().cuda()
x = torch.randn(8, 3, 224, 224, requires_grad=True).cuda()
torch_out = mobilenet_v3_large(x)
torch.onnx.export(mobilenet_v3_large, # model being run
x, # model input (or a tuple for multiple inputs)
"mobilenet_pytorch.onnx", # where to save the model (can be a file or file-like object)
export_params=True, # store the trained parameter weights inside the model file
opset_version=8, # the ONNX version to export the model to
do_constant_folding=True, # whether to execute constant folding for optimization
input_names = ['input'], # the model's input names
output_names = ['preds'], # the model's output names
dynamic_axes={'input' : {0 : 'batch_size'}, # variable length axes
'preds' : {0 : 'batch_size'}})
When I add this model to deepstream as sgie0 I see that model builds correctly:
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 2
0 INPUT kFLOAT input 3x224x224
1 OUTPUT kFLOAT preds 1000
However when running on video I can see that the model does not predict anything and obj->classifier_meta_list is always NULL. So I am assuming the output is not accepted properly or something like that.
My configs:
config.txt
[primary-gie]
enable=1
gpu-id=0
batch-size=1
gie-unique-id=1
process-mode=1
nvbuf-memory-type=0
config-file=config_infer_yolo.txt
[secondary-gie0]
enable=1
process-mode=2
gpu-id=0
batch-size=1
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_mobilenet.txt
[property]
gpu-id=0
net-scale-factor=1
labelfile-path=../mobilenet/labels.txt
onnx-file=../mobilenet/mobilenet_pytorch.onnx
input-dims=3;224;224;0
model-color-format=0
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
network-type=1
is-classifier=1
num-detected-classes=1000
interval=0
output-blob-names=preds
classifier-threshold=0.2
Something is not correct with my classifier even thought it builds okay, as I mentioned I assume it is the output of the network, but I am not sure how to fix this. Also when I attach different classifier the pipeline works as expected.
