Hi all,
I am implementing some basic functions for sparse matrices. In order to have one memory transfer for a CSR formatted matrix I use a struct of pointers.
After getting strange results I narrowed the problem down to copying double data.
The following test case works for me in emulation mode (single and double precision) in single precision on the device but not as it is presented here on the device.
#include <stdio.h>
#define dim 7
typedef struct { //[int,int,int,dim*double,dim*int]
void* memory;
int* Int1;
int* Int2;
int* Int3;
double* dblVector;
int* intVector;
} myStruct;
__host__ void setPointers(myStruct* A)
(*A).Int1 = (int*)(*A).memory;
(*A).Int2 = (*A).Int1+1;
(*A).Int3 = (*A).Int2+1;
(*A).dblVector = (double*) ((*A).Int3+1);
(*A).intVector = (int*) ((*A).dblVector+dim);
__global__ void spmv_gpu(int* intVector, double* dblVector, double* dblResult, int* intResult)
dblResult[threadIdx.x] = dblVector[threadIdx.x];
intResult[threadIdx.x] = intVector[threadIdx.x];
int main(int argc,char* argv[])
cudaSetDevice(0);
int i;
//Create a struct on the device
myStruct A_d;
cudaMalloc((void**)&(A_d.memory), sizeof(double)*dim+sizeof(int)*(3+dim));
setPointers(&A_d);
//Create a struct on the host
myStruct A_h;
cudaMallocHost((void**)&(A_h.memory), sizeof(double)*dim+sizeof(int)*(3+dim));
setPointers(&A_h);
//...fill it with dummy data
*A_h.Int1=11; *A_h.Int2=21; *A_h.Int3=31;
for (i=0; i<dim;i++) A_h.dblVector[i]=sqrt(i);
for ( i=0; i<dim;i++) A_h.intVector[i]=(i+4)*10+1;
//print this data
for(i = 0;i < dim; i++){
printf("%d: %e\n",A_h.intVector[i], A_h.dblVector[i]);
printf("\n");
//copy data to device
cudaMemcpy(A_d.memory, A_h.memory, sizeof(double)*dim+sizeof(int)*(3+dim), cudaMemcpyHostToDevice);
//copy contents of dummy vectors to other areas of memory
double* dblResult_d;
int* intResult_d;
cudaMalloc((void**)&dblResult_d, sizeof(double)*dim);
cudaMalloc((void**)&intResult_d, sizeof(int)*dim);
spmv_gpu<<<1,dim>>>(A_d.intVector, A_d.dblVector, dblResult_d, intResult_d);
//read the results back
double dblResult[dim]={0.0};
int intResult[dim]={0};
cudaMemcpy(dblResult, dblResult_d, sizeof(double)*dim, cudaMemcpyDeviceToHost);
cudaMemcpy(intResult, intResult_d, sizeof(int)*dim, cudaMemcpyDeviceToHost);
//print the results
printf("%d: %e\n", intResult[i], dblResult[i]);
cudaFreeHost(A_h.memory);
cudaFree(A_d.memory);
cudaFree(dblResult_d);
cudaFree(intResult_d);
The result on both my ASUS ENGTX280 is
41: 0.000000e+00
51: 1.000000e+00
61: 1.414214e+00
71: 1.732051e+00
81: 2.000000e+00
91: 2.236068e+00
101: 2.449490e+00
41: 1.531604e-322
51: 0.000000e+00
61: 5.308593e+185
71: -4.434596e+194
81: 5.303601e-315
91: -9.458696e-176
101: 3.732320e-212
So the integer data is copied correctly, double is not. Am I doing something wrong?
I’m using driver version 177.73 on OpenSuse 10.2 (kernel 2.6.26.5) and am compiling with -arch sm_13 and -m64.
Thanks in advance for any help.
–Tobias
Edits:
PTX looks fine, it loads f64 from the correct address and stores it also to f64.
It works if I leave out one of the three integers, let’s say Int2, set the pointer to Int3 new and transfer 4 bytes less to and from the device. Strange?!
