Problems with linking
I am trying to complile a simple CUDA code with pgfortran.
attributes(global) subroutine S
end subroutine S
program P
call S<<1, 1>>
end program P
As a result, I have this:
# pgfortran test.cuf
In function 'p`: /..././test.cuf: undefined reference to 's_`
I am using PGI workstation 10.3
CentOS 5.2
# pgaccelinfo
CUDA Driver Version 3020
Device name: Tesla C2050
pgfortran -c test.cuf compiled without any errors
Is there incompatibility between libraries? I have no idea.
Hi Tez,
CUDA Fortran device kernels require interfaces in order to be called from host code. Hence, you either write an explicit interface for S in your main program or put S in a module where an implicit interface is generated.
module foo
contains
end subroutine S
end module foo
program P
use foo
call S<<<1, 1>>>()
end program P
Hope this helps,
Mat
Yes, it helped, thanks.
Until then, I only programmed in CUDA C and didn’t know about this feature in fortran.
