This still happens with nvidia driver 570.172.08
Process 1
2025-09-21T23:32:10.351395000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.351433000Z Info #22 Object "/usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2", at 0xffffffffffffffff, in
2025-09-21T23:32:10.351443000Z Info #21 Object "/opt/ree-drive/lib/ree_teleport/teleport", at 0x57e8ecb24344, in _start
2025-09-21T23:32:10.351452000Z Info #20 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x792d2053b28a, in __libc_start_main
2025-09-21T23:32:10.351462000Z Info #19 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x792d2053b1c9, in
2025-09-21T23:32:10.351484000Z Info #18 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 276, in main
2025-09-21T23:32:10.351494000Z Info #17 Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 22, in tryMain
2025-09-21T23:32:10.351509000Z Info #16 | Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 33, in operator()
2025-09-21T23:32:10.351524000Z Info Source "/usr/bin/../lib/gcc/x86_64-linux-gnu/13/../../../../include/c++/13/bits/std_function.h", line 591, in tryMain
2025-09-21T23:32:10.351536000Z Info 588: {
2025-09-21T23:32:10.351548000Z Info 589: .if (_M_empty())
2025-09-21T23:32:10.351558000Z Info 590: . __throw_bad_function_call();
2025-09-21T23:32:10.351570000Z Info > 591: .return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
2025-09-21T23:32:10.351579000Z Info 592: }
2025-09-21T23:32:10.351589000Z Info 593:
2025-09-21T23:32:10.351598000Z Info 594: #if __cpp_rtti
2025-09-21T23:32:10.351609000Z Info #15 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 203, in signal
2025-09-21T23:32:10.351618000Z Info #14 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 960, in update
2025-09-21T23:32:10.351626000Z Info #13 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 621, in handleGpuInteractions
2025-09-21T23:32:10.351635000Z Info #12 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x792d306de7b5, in bgfx::Context::frame(bool)
2025-09-21T23:32:10.351645000Z Info #11 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x792d306de3f2, in bgfx::Context::swap()
2025-09-21T23:32:10.351654000Z Info #10 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x792d306de0f7, in bgfx::Context::renderFrame(int)
2025-09-21T23:32:10.351659000Z Info #9 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x792d306dceb6, in bgfx::Context::flushTextureUpdateBatch(bgfx::CommandBuffer&)
2025-09-21T23:32:10.351683000Z Info #8 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x792d306ecfd3, in bgfx::gl::TextureGL::update(unsigned char, unsigned char, bgfx::Rect const&, unsigned short, unsigned short, unsigned short, bgfx::Memory const*)
2025-09-21T23:32:10.351693000Z Info #7 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x792c925e2310, in
2025-09-21T23:32:10.351703000Z Info #6 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x792c9280f090, in
2025-09-21T23:32:10.351712000Z Info #5 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x792cf86a847d, in _nv004glsi
2025-09-21T23:32:10.351728000Z Info #4 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x792cf869c9c4, in
2025-09-21T23:32:10.351738000Z Info #3 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x792d205b1100, in pthread_mutex_lock
2025-09-21T23:32:10.351748000Z Info #2 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x792d205a9f70, in
2025-09-21T23:32:10.351757000Z Info #1 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x792d2055632f, in
2025-09-21T23:32:10.351766000Z Info #0 Source "/ws/src/vdrive_core/ree_framework/src/Node.cpp", line 103, in printBacktraceCb
Process 2
2025-09-21T23:32:10.369058000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.398597000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.455796000Z Info [ INFO] [peplink_api_emulator_1] [2025-09-21T23:32:10.455+0000] New request(device: hd4<8.2.0 build 5312>): /api/info.location
2025-09-21T23:32:10.459983000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.460021000Z Info #21 Object "/usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2", at 0xffffffffffffffff, in
2025-09-21T23:32:10.460031000Z Info #20 Object "/opt/ree-drive/lib/ree_teleport/teleport", at 0x62540063d344, in _start
2025-09-21T23:32:10.460090000Z Info #19 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7a4241de128a, in __libc_start_main
2025-09-21T23:32:10.460106000Z Info #18 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7a4241de11c9, in
2025-09-21T23:32:10.460117000Z Info #17 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 276, in main
2025-09-21T23:32:10.460129000Z Info #16 Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 22, in tryMain
2025-09-21T23:32:10.460155000Z Info #15 | Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 33, in operator()
2025-09-21T23:32:10.460165000Z Info Source "/usr/bin/../lib/gcc/x86_64-linux-gnu/13/../../../../include/c++/13/bits/std_function.h", line 591, in tryMain
2025-09-21T23:32:10.460174000Z Info 588: {
2025-09-21T23:32:10.460182000Z Info 589: .if (_M_empty())
2025-09-21T23:32:10.460193000Z Info 590: . __throw_bad_function_call();
2025-09-21T23:32:10.460203000Z Info > 591: .return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
2025-09-21T23:32:10.460212000Z Info 592: }
2025-09-21T23:32:10.460224000Z Info 593:
2025-09-21T23:32:10.460232000Z Info 594: #if __cpp_rtti
2025-09-21T23:32:10.460241000Z Info #14 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 203, in signal
2025-09-21T23:32:10.460250000Z Info #13 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 960, in update
2025-09-21T23:32:10.460258000Z Info #12 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 621, in handleGpuInteractions
2025-09-21T23:32:10.460267000Z Info #11 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7a4251f847b5, in bgfx::Context::frame(bool)
2025-09-21T23:32:10.460276000Z Info #10 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7a4251f843f2, in bgfx::Context::swap()
2025-09-21T23:32:10.460285000Z Info #9 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7a4251f84129, in bgfx::Context::renderFrame(int)
2025-09-21T23:32:10.460294000Z Info #8 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7a4251f9a181, in bgfx::gl::RendererContextGL::submit(bgfx::Frame*, bgfx::ClearQuad&, bgfx::TextVideoMemBlitter&)
2025-09-21T23:32:10.460307000Z Info #7 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x7a422995c93c, in
2025-09-21T23:32:10.460321000Z Info #6 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x7a4229cb1072, in
2025-09-21T23:32:10.460330000Z Info #5 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x7a4229cfc071, in
2025-09-21T23:32:10.460342000Z Info #4 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x7a4238486151, in
2025-09-21T23:32:10.460351000Z Info #3 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x7a42384471dd, in
2025-09-21T23:32:10.460361000Z Info #2 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7a4241ec57db, in __sched_yield
2025-09-21T23:32:10.460370000Z Info #1 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7a4241dfc32f, in
2025-09-21T23:32:10.460379000Z Info #0 Source "/ws/src/vdrive_core/ree_framework/src/Node.cpp", line 103, in printBacktraceCb
Process 3
2025-09-21T23:32:10.466209000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.466233000Z Info #21 Object "/usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2", at 0xffffffffffffffff, in
2025-09-21T23:32:10.466245000Z Info #20 Object "/opt/ree-drive/lib/ree_teleport/teleport", at 0x5aa9ca726344, in _start
2025-09-21T23:32:10.466255000Z Info #19 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x70703283728a, in __libc_start_main
2025-09-21T23:32:10.466275000Z Info #18 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7070328371c9, in
2025-09-21T23:32:10.466287000Z Info #17 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 276, in main
2025-09-21T23:32:10.466296000Z Info #16 Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 22, in tryMain
2025-09-21T23:32:10.466306000Z Info #15 | Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 33, in operator()
2025-09-21T23:32:10.466315000Z Info Source "/usr/bin/../lib/gcc/x86_64-linux-gnu/13/../../../../include/c++/13/bits/std_function.h", line 591, in tryMain
2025-09-21T23:32:10.466324000Z Info 588: {
2025-09-21T23:32:10.466334000Z Info 589: .if (_M_empty())
2025-09-21T23:32:10.466345000Z Info 590: . __throw_bad_function_call();
2025-09-21T23:32:10.466360000Z Info > 591: .return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
2025-09-21T23:32:10.466368000Z Info 592: }
2025-09-21T23:32:10.466377000Z Info 593:
2025-09-21T23:32:10.466387000Z Info 594: #if __cpp_rtti
2025-09-21T23:32:10.466402000Z Info #14 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 203, in signal
2025-09-21T23:32:10.466412000Z Info #13 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 960, in update
2025-09-21T23:32:10.466423000Z Info #12 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 621, in handleGpuInteractions
2025-09-21T23:32:10.466433000Z Info #11 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7070429da7b5, in bgfx::Context::frame(bool)
2025-09-21T23:32:10.466445000Z Info #10 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7070429da3f2, in bgfx::Context::swap()
2025-09-21T23:32:10.466454000Z Info #9 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7070429da129, in bgfx::Context::renderFrame(int)
2025-09-21T23:32:10.466467000Z Info #8 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7070429f0181, in bgfx::gl::RendererContextGL::submit(bgfx::Frame*, bgfx::ClearQuad&, bgfx::TextVideoMemBlitter&)
2025-09-21T23:32:10.466477000Z Info #7 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x70701a55c93c, in
2025-09-21T23:32:10.466489000Z Info #6 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x70701a8b1072, in
2025-09-21T23:32:10.466504000Z Info #5 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x70701a8fc071, in
2025-09-21T23:32:10.466514000Z Info #4 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x7070286db151, in
2025-09-21T23:32:10.466522000Z Info #3 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x70702869c1dd, in
2025-09-21T23:32:10.466531000Z Info #2 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x70703291b7db, in __sched_yield
2025-09-21T23:32:10.466540000Z Info #1 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x70703285232f, in
2025-09-21T23:32:10.466549000Z Info #0 Source "/ws/src/vdrive_core/ree_framework/src/Node.cpp", line 103, in printBacktraceCb
Process 4
2025-09-21T23:32:10.562850000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.698652000Z Info Stack trace (most recent call last):
2025-09-21T23:32:10.698693000Z Info #21 Object "/usr/lib/x86_64-linux-gnu/ld-linux-x86-64.so.2", at 0xffffffffffffffff, in
2025-09-21T23:32:10.698708000Z Info #20 Object "/opt/ree-drive/lib/ree_teleport/teleport", at 0x555f5cdc8344, in _start
2025-09-21T23:32:10.698719000Z Info #19 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7517d71fd28a, in __libc_start_main
2025-09-21T23:32:10.698733000Z Info #18 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7517d71fd1c9, in
2025-09-21T23:32:10.698743000Z Info #17 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 276, in main
2025-09-21T23:32:10.698753000Z Info #16 Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 22, in tryMain
2025-09-21T23:32:10.698766000Z Info #15 | Source "/ws/src/vdrive_core/ree/src/try_main.cpp", line 33, in operator()
2025-09-21T23:32:10.698776000Z Info Source "/usr/bin/../lib/gcc/x86_64-linux-gnu/13/../../../../include/c++/13/bits/std_function.h", line 591, in tryMain
2025-09-21T23:32:10.698786000Z Info 588: {
2025-09-21T23:32:10.698796000Z Info 589: .if (_M_empty())
2025-09-21T23:32:10.698805000Z Info 590: . __throw_bad_function_call();
2025-09-21T23:32:10.698833000Z Info > 591: .return _M_invoker(_M_functor, std::forward<_ArgTypes>(__args)...);
2025-09-21T23:32:10.698847000Z Info 592: }
2025-09-21T23:32:10.698856000Z Info 593:
2025-09-21T23:32:10.698865000Z Info 594: #if __cpp_rtti
2025-09-21T23:32:10.698875000Z Info #14 Source "/ws/src/vdrive_core/ree_teleport/src/main.cpp", line 203, in signal
2025-09-21T23:32:10.698887000Z Info #13 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 960, in update
2025-09-21T23:32:10.698896000Z Info #12 Source "/ws/src/vdrive_core/ree_teleport/src/Teleport.cpp", line 621, in handleGpuInteractions
2025-09-21T23:32:10.699322000Z Info #11 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7517e73a07b5, in bgfx::Context::frame(bool)
2025-09-21T23:32:10.699342000Z Info #10 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7517e73a03f2, in bgfx::Context::swap()
2025-09-21T23:32:10.699351000Z Info #9 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7517e73a0129, in bgfx::Context::renderFrame(int)
2025-09-21T23:32:10.699360000Z Info #8 Object "/opt/ree-drive/lib/libree_virtual_3d.so", at 0x7517e73b6181, in bgfx::gl::RendererContextGL::submit(bgfx::Frame*, bgfx::ClearQuad&, bgfx::TextVideoMemBlitter&)
2025-09-21T23:32:10.699372000Z Info #7 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x75174155c93c, in
2025-09-21T23:32:10.699380000Z Info #6 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x7517418b1072, in
2025-09-21T23:32:10.699390000Z Info #5 Object "/usr/lib/x86_64-linux-gnu/libnvidia-eglcore.so.570.172.08", at 0x7517418fc071, in
2025-09-21T23:32:10.699402000Z Info #4 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x7517bc3ab151, in
2025-09-21T23:32:10.699416000Z Info #3 Object "/usr/lib/x86_64-linux-gnu/libnvidia-glsi.so.570.172.08", at 0x7517bc36c1dd, in
2025-09-21T23:32:10.699425000Z Info #2 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7517d72e17db, in __sched_yield
2025-09-21T23:32:10.699433000Z Info #1 Object "/usr/lib/x86_64-linux-gnu/libc.so.6", at 0x7517d721832f, in
2025-09-21T23:32:10.699442000Z Info #0 Source "/ws/src/vdrive_core/ree_framework/src/Node.cpp", line 103, in printBacktraceCb
