nvidia-bug-report.sh output at 5th message
On Fedora 20, 331 drivers I can reproduce a X freeze/restart when using OpenCL in Darktable
Xorg.0.log.old
[ 61.835]
X.Org X Server 1.14.4
Release Date: 2013-10-31
[ 61.835] X Protocol Version 11, Revision 0
[ 61.835] Build Operating System: 3.17.2-200.fc20.x86_64
[ 61.835] Current Operating System: Linux *removed_privacy* 3.17.7-200.fc20.x86_64 #1 SMP Wed Dec 17 03:35:33 UTC 2014 x86_64
[ 61.835] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.17.7-200.fc20.x86_64 root=UUID=*removed_privacy* ro rd.md=0 rd.lvm=0 rd.dm=0 SYSFONT=True KEYTABLE=it LANG=en_US.UTF-8 rhgb quiet nouveau.modeset=0 rd.driver.blacklist=nouveau video=vesa:off
[ 61.835] Build Date: 11 December 2014 03:16:53AM
[ 61.835] Build ID: xorg-x11-server 1.14.4-13.fc20
[ 61.835] Current version of pixman: 0.30.0
[ 61.835] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 61.835] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 61.835] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jan 8 13:53:37 2015
[ 61.836] (==) Using config file: "/etc/X11/xorg.conf"
[ 61.836] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 61.836] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 61.836] (==) No Layout section. Using the first Screen section.
[ 61.836] (==) No screen section available. Using defaults.
[ 61.836] (**) |-->Screen "Default Screen Section" (0)
[ 61.836] (**) | |-->Monitor "<default monitor>"
[ 61.836] (==) No device specified for screen "Default Screen Section".
Using the first device section listed.
[ 61.836] (**) | |-->Device "Videocard0"
[ 61.836] (==) No monitor specified for screen "Default Screen Section".
Using a default monitor configuration.
[ 61.836] (==) Automatically adding devices
[ 61.836] (==) Automatically enabling devices
[ 61.836] (==) Automatically adding GPU devices
[ 61.836] (==) FontPath set to:
catalogue:/etc/X11/fontpath.d,
built-ins
[ 61.836] (**) ModulePath set to "/usr/lib64/nvidia/xorg,/usr/lib64/xorg/modules"
[ 61.836] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 61.836] (II) Loader magic: 0x80dd00
[ 61.836] (II) Module ABI versions:
[ 61.836] X.Org ANSI C Emulation: 0.4
[ 61.836] X.Org Video Driver: 14.1
[ 61.836] X.Org XInput driver : 19.2
[ 61.836] X.Org Server Extension : 7.0
[ 61.837] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 61.838] (--) PCI:*(0:1:0:0) 10de:05e2:1043:831c rev 161, Mem @ 0xfa000000/16777216, 0xd0000000/268435456, 0xf8000000/33554432, I/O @ 0x0000cf00/128, BIOS @ 0x????????/524288
[ 61.838] Initializing built-in extension Generic Event Extension
[ 61.838] Initializing built-in extension SHAPE
[ 61.838] Initializing built-in extension MIT-SHM
[ 61.838] Initializing built-in extension XInputExtension
[ 61.838] Initializing built-in extension XTEST
[ 61.838] Initializing built-in extension BIG-REQUESTS
[ 61.838] Initializing built-in extension SYNC
[ 61.838] Initializing built-in extension XKEYBOARD
[ 61.838] Initializing built-in extension XC-MISC
[ 61.838] Initializing built-in extension XINERAMA
[ 61.838] Initializing built-in extension XFIXES
[ 61.838] Initializing built-in extension RENDER
[ 61.838] Initializing built-in extension RANDR
[ 61.838] Initializing built-in extension COMPOSITE
[ 61.838] Initializing built-in extension DAMAGE
[ 61.838] Initializing built-in extension MIT-SCREEN-SAVER
[ 61.838] Initializing built-in extension DOUBLE-BUFFER
[ 61.838] Initializing built-in extension RECORD
[ 61.838] Initializing built-in extension DPMS
[ 61.838] Initializing built-in extension X-Resource
[ 61.838] Initializing built-in extension XVideo
[ 61.838] Initializing built-in extension XVideo-MotionCompensation
[ 61.838] Initializing built-in extension SELinux
[ 61.838] Initializing built-in extension XFree86-VidModeExtension
[ 61.838] Initializing built-in extension XFree86-DGA
[ 61.838] Initializing built-in extension XFree86-DRI
[ 61.838] Initializing built-in extension DRI2
[ 61.838] (WW) "glamoregl" will not be loaded unless you've specified it to be loaded elsewhere.
[ 61.838] (II) "glx" will be loaded by default.
[ 61.838] (WW) "xwayland" is not to be loaded by default. Skipping.
[ 61.838] (II) LoadModule: "glx"
[ 61.858] (II) Loading /usr/lib64/nvidia/xorg/libglx.so
[ 62.001] (II) Module glx: vendor="NVIDIA Corporation"
[ 62.001] compiled for 4.0.2, module version = 1.0.0
[ 62.001] Module class: X.Org Server Extension
[ 62.001] (II) NVIDIA GLX Module 331.113 Mon Dec 1 20:24:35 PST 2014
[ 62.001] Loading extension GLX
[ 62.001] (II) LoadModule: "nvidia"
[ 62.001] (II) Loading /usr/lib64/xorg/modules/drivers/nvidia_drv.so
[ 62.001] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 62.001] Module class: X.Org Video Driver
[ 62.001] (II) NVIDIA dlloader X Driver 331.113 Mon Dec 1 20:01:51 PST 2014
[ 62.001] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 62.001] (++) using VT number 1
[ 62.003] (II) Loading sub module "fb"
[ 62.003] (II) LoadModule: "fb"
[ 62.003] (II) Loading /usr/lib64/xorg/modules/libfb.so
[ 62.003] (II) Module fb: vendor="X.Org Foundation"
[ 62.003] compiled for 1.14.4, module version = 1.0.0
[ 62.004] ABI class: X.Org ANSI C Emulation, version 0.4
[ 62.004] (WW) Unresolved symbol: fbGetGCPrivateKey
[ 62.004] (II) Loading sub module "wfb"
[ 62.004] (II) LoadModule: "wfb"
[ 62.023] (II) Loading /usr/lib64/xorg/modules/libwfb.so
[ 62.023] (II) Module wfb: vendor="X.Org Foundation"
[ 62.023] compiled for 1.14.4, module version = 1.0.0
[ 62.023] ABI class: X.Org ANSI C Emulation, version 0.4
[ 62.023] (II) Loading sub module "ramdac"
[ 62.023] (II) LoadModule: "ramdac"
[ 62.023] (II) Module "ramdac" already built-in
[ 62.023] (II) NVIDIA(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 62.023] (==) NVIDIA(0): Depth 24, (==) framebuffer bpp 32
[ 62.023] (==) NVIDIA(0): RGB weight 888
[ 62.023] (==) NVIDIA(0): Default visual is TrueColor
[ 62.023] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[ 62.023] (**) NVIDIA(0): Enabling 2D acceleration
[ 63.421] (II) NVIDIA(0): Display *removed_privacy* supports NVIDIA 3D Vision
[ 63.421] (II) NVIDIA(0): stereo.
[ 63.421] (II) NVIDIA(GPU-0): Found DRM driver nvidia-drm (20130102)
[ 63.426] (II) NVIDIA(0): NVIDIA GPU GeForce GTX 260 (GT200) at PCI:1:0:0 (GPU-0)
[ 63.426] (--) NVIDIA(0): Memory: 917504 kBytes
[ 63.426] (--) NVIDIA(0): VideoBIOS: 62.00.67.00.00
[ 63.426] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[ 63.429] (--) NVIDIA(0): Valid display device(s) on GeForce GTX 260 at PCI:1:0:0
[ 63.429] (--) NVIDIA(0): CRT-0
[ 63.429] (--) NVIDIA(0): CRT-1
[ 63.429] (--) NVIDIA(0): DFP-0
[ 63.429] (--) NVIDIA(0): *removed_privacy* (boot, connected)
[ 63.429] (--) NVIDIA(0): CRT-0: 400.0 MHz maximum pixel clock
[ 63.429] (--) NVIDIA(0): CRT-1: 400.0 MHz maximum pixel clock
[ 63.429] (--) NVIDIA(0): DFP-0: Internal Single Link TMDS
[ 63.429] (--) NVIDIA(0): DFP-0: 330.0 MHz maximum pixel clock
[ 63.429] (--) NVIDIA(0): *removed_privacy*: Internal Dual Link TMDS
[ 63.429] (--) NVIDIA(0): *removed_privacy*: 330.0 MHz maximum pixel clock
[ 63.429] (**) NVIDIA(0): Using HorizSync/VertRefresh ranges from the EDID for display
[ 63.429] (**) NVIDIA(0): device *removed_privacy* (Using EDID frequencies
[ 63.429] (**) NVIDIA(0): has been enabled on all display devices.)
[ 63.432] (==) NVIDIA(0):
[ 63.432] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[ 63.432] (==) NVIDIA(0): will be used as the requested mode.
[ 63.432] (II) NVIDIA(0): Validated MetaModes:
[ 63.432] (II) NVIDIA(0): "DFP-1:nvidia-auto-select"
[ 63.432] (II) NVIDIA(0): Virtual screen size determined to be 1680 x 1050
[ 63.454] (--) NVIDIA(0): DPI set to (90, 88); computed from "UseEdidDpi" X config
[ 63.454] (--) NVIDIA(0): option
[ 63.454] (--) Depth 24 pixmap format is 32 bpp
[ 63.454] (II) NVIDIA: Using 768.00 MB of virtual memory for indirect memory access.
[ 63.461] (II) NVIDIA(0): Setting mode "DFP-1:nvidia-auto-select"
[ 63.512] Loading extension NV-GLX
[ 63.534] (==) NVIDIA(0): Disabling shared memory pixmaps
[ 63.534] (==) NVIDIA(0): Backing store disabled
[ 63.534] (==) NVIDIA(0): Silken mouse enabled
[ 63.535] (==) NVIDIA(0): DPMS enabled
[ 63.535] Loading extension NV-CONTROL
[ 63.535] Loading extension XINERAMA
[ 63.535] (II) Loading sub module "dri2"
[ 63.535] (II) LoadModule: "dri2"
[ 63.535] (II) Module "dri2" already built-in
[ 63.535] (II) NVIDIA(0): [DRI2] Setup complete
[ 63.535] (II) NVIDIA(0): [DRI2] VDPAU driver: nvidia
[ 63.535] (--) RandR disabled
[ 63.539] (II) SELinux: Disabled by boolean
[ 63.539] (II) Initializing extension GLX
[ 63.678] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 63.681] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 63.681] (**) Power Button: Applying InputClass "system-setup-keyboard"
[ 63.681] (II) LoadModule: "evdev"
[ 63.681] (II) Loading /usr/lib64/xorg/modules/input/evdev_drv.so
[ 63.681] (II) Module evdev: vendor="X.Org Foundation"
[ 63.681] compiled for 1.14.4, module version = 2.8.4
[ 63.681] Module class: X.Org XInput Driver
[ 63.681] ABI class: X.Org XInput driver, version 19.2
[ 63.681] (II) Using input driver 'evdev' for 'Power Button'
[ 63.681] (**) Power Button: always reports core events
[ 63.681] (**) evdev: Power Button: Device: "/dev/input/event1"
[ 63.681] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 63.681] (--) evdev: Power Button: Found keys
[ 63.681] (II) evdev: Power Button: Configuring as keyboard
[ 63.681] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input1/event1"
[ 63.681] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 63.681] (**) Option "xkb_rules" "evdev"
[ 63.681] (**) Option "xkb_model" "pc105"
[ 63.681] (**) Option "xkb_layout" "it"
[ 63.681] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[ 63.713] (II) config/udev: Adding input device Power Button (/dev/input/event0)
[ 63.713] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 63.713] (**) Power Button: Applying InputClass "system-setup-keyboard"
[ 63.713] (II) Using input driver 'evdev' for 'Power Button'
[ 63.713] (**) Power Button: always reports core events
[ 63.713] (**) evdev: Power Button: Device: "/dev/input/event0"
[ 63.713] (--) evdev: Power Button: Vendor 0 Product 0x1
[ 63.713] (--) evdev: Power Button: Found keys
[ 63.713] (II) evdev: Power Button: Configuring as keyboard
[ 63.713] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0/event0"
[ 63.713] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 7)
[ 63.713] (**) Option "xkb_rules" "evdev"
[ 63.713] (**) Option "xkb_model" "pc105"
[ 63.713] (**) Option "xkb_layout" "it"
[ 63.713] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
[ 63.714] (**) Option "xkb_rules" "evdev"
[ 63.714] (**) Option "xkb_model" "pc105"
[ 63.714] (**) Option "xkb_layout" "it"
[ 63.714] (**) Option "xkb_options" "terminate:ctrl_alt_bksp,"
(EE) [mi] EQ overflowing. Additional events will be discarded until existing events are processed.
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/X (mieqEnqueue+0x22b) [0x583c6b]
(EE) 1: /usr/bin/X (QueuePointerEvents+0x52) [0x451562]
(EE) 2: /usr/lib64/xorg/modules/input/evdev_drv.so (_init+0x2d4d) [0x7f884a415d1d]
(EE) 3: /usr/bin/X (DPMSSupported+0xe8) [0x48b778]
(EE) 4: /usr/bin/X (xf86SerialModemClearBits+0x260) [0x4b4cf0]
(EE) 5: /lib64/libpthread.so.0 (__restore_rt+0x0) [0x32c820f6cf]
(EE) unw_get_proc_name failed: no unwind info found [-10]
(EE) 6: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (?+0x0) [0x7f884b4fa380]
(EE) 7: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (?+0x0) [0x7f884b4faf50]
(EE) 8: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x57178) [0x7f884b5c7818]
(EE) 9: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48d780) [0x7f884be34620]
(EE) 10: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48ae55) [0x7f884be2f275]
(EE) 11: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48d9bd) [0x7f884be3494d]
(EE) 12: /usr/bin/X (DamageRegionAppend+0x388b) [0x53264b]
(EE) 13: /usr/bin/X (SyncVerifyFence+0x1f35) [0x4eae75]
(EE) 14: /usr/bin/X (SyncVerifyFence+0x3065) [0x4ed585]
(EE) 15: /usr/bin/X (SendErrorToClient+0x427) [0x43a467]
(EE) 16: /usr/bin/X (_init+0x3bca) [0x42c14a]
(EE) 17: /lib64/libc.so.6 (__libc_start_main+0xf5) [0x32c7621d65]
(EE) 18: /usr/bin/X (_start+0x29) [0x428cb5]
(EE) 19: ? (?+0x29) [0x29]
(EE)
(EE) [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
(EE) [mi] mieq is *NOT* the cause. It is a victim.
(EE) [mi] EQ overflow continuing. 100 events have been dropped.
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/X (QueuePointerEvents+0x52) [0x451562]
(EE) 1: /usr/lib64/xorg/modules/input/evdev_drv.so (_init+0x2d4d) [0x7f884a415d1d]
(EE) 2: /usr/bin/X (DPMSSupported+0xe8) [0x48b778]
(EE) 3: /usr/bin/X (xf86SerialModemClearBits+0x260) [0x4b4cf0]
(EE) 4: /lib64/libpthread.so.0 (__restore_rt+0x0) [0x32c820f6cf]
(EE) 5: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (?+0x0) [0x7f884b4fa380]
(EE) 6: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (?+0x0) [0x7f884b4faf50]
(EE) 7: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x57178) [0x7f884b5c7818]
(EE) 8: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48d780) [0x7f884be34620]
(EE) 9: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48ae55) [0x7f884be2f275]
(EE) 10: /usr/lib64/xorg/modules/drivers/nvidia_drv.so (nvidiaAddDrawableHandler+0x48d9bd) [0x7f884be3494d]
(EE) 11: /usr/bin/X (DamageRegionAppend+0x388b) [0x53264b]
(EE) 12: /usr/bin/X (SyncVerifyFence+0x1f35) [0x4eae75]
(EE) 13: /usr/bin/X (SyncVerifyFence+0x3065) [0x4ed585]
(EE) 14: /usr/bin/X (SendErrorToClient+0x427) [0x43a467]
(EE) 15: /usr/bin/X (_init+0x3bca) [0x42c14a]
(EE) 16: /lib64/libc.so.6 (__libc_start_main+0xf5) [0x32c7621d65]
(EE) 17: /usr/bin/X (_start+0x29) [0x428cb5]
(EE) 18: ? (?+0x29) [0x29]
(EE)
(EE) [mi] EQ overflow continuing. 200 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 300 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 400 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 500 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
[ 169.052] [mi] Increasing EQ size to 1024 to prevent dropped events.
[ 169.053] [mi] EQ processing has resumed after 515 dropped events.
[ 169.053] [mi] This may be caused my a misbehaving driver monopolizing the server's resources.
[ 172.078] (WW) NVIDIA(0): WAIT (2, 6, 0x8000, 0x000004b0, 0x0000c9bc)
[ 174.173] (WW) NVIDIA(0): WAIT (0, 6, 0x8000, 0x0000c9bc, 0x0000c9bc)
(EE)
(EE) Backtrace:
(EE)
(EE)
(EE) Backtrace:
(EE) 11: /usr/bin/X (SyncVerifyFence+0x1f35) [0x4eae75]
(EE) 12: /usr/bin/X (SyncVerifyFence+0x3065) [0x4ed585]
(EE) 13: /usr/bin/X (SendErrorToClient+0x427) [0x43a467]
(EE) 14: /usr/bin/X (_init+0x3bca) [0x42c14a]
(EE) 15: /lib64/libc.so.6 (__libc_start_main+0xf5) [0x32c7621d65]
(EE) 16: /usr/bin/X (_start+0x29) [0x428cb5]
(EE) 17: ? (?+0x29) [0x29]
(EE)
(EE)
(EE) Backtrace:
(EE)
(EE)
(EE) Backtrace:
(EE)
(EE)
(EE) Backtrace:
(EE)
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 600 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 700 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 800 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 900 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing. 1000 events have been dropped.
(EE) [mi] No further overflow reports will be reported until the clog is cleared.
(EE)
(EE) Backtrace:
(EE)
[ 218.537] (EE)
[ 218.537] (EE) Backtrace:
[ 218.537] (EE) 0: /usr/bin/X (OsLookupColor+0x129) [0x473919]
Last part of Darktable logs:
[mipmap_cache] level [i0] ( 162x 124) fill 23,69/1130,40 MB (2,10% in 309/16384 buffers)
[mipmap_cache] level [i1] ( 324x 248) fill 41,38/282,52 MB (14,65% in 135/1024 buffers)
[mipmap_cache] level [i2] ( 648x 496) fill 0,00/141,25 MB (0,00% in 0/128 buffers)
[mipmap_cache] level [i3] (1296x 992) fill 0,00/141,24 MB (0,00% in 0/32 buffers)
[mipmap_cache] level [f4] fill 0/2 slots (0,00% in 0/4 buffers)
[mipmap_cache] level [f5] fill 2/2 slots (100,00% in 2/4 buffers)
[mipmap_cache] level | near match | miss | stand-in | fetches | total rq
[mipmap_cache] i0 | 31,77% | 31,77% | 100,00% | 38,05% | 96,67%
[mipmap_cache] i1 | 49,86% | 44,41% | 0,00% | 11,64% | 3,33%
[mipmap_cache] i2 | -nan% | -nan% | 0,00% | 0,00% | 0,00%
[mipmap_cache] i3 | -nan% | -nan% | 0,00% | 0,00% | 0,00%
[mipmap_cache] f4 | -nan% | -nan% | 0,00% | 0,00% | 0,00%
[mipmap_cache] f5 | -nan% | -nan% | 0,00% | 50,31% | 0,00%
[lighttable] expose took 0,2591 sec
[export] creating pixelpipe took 0,364 secs (0,410 CPU)
[pixelpipe_process] [export] using device 0
pixelpipe cacheline 0 used 0 by 18446744073709551615
pixelpipe cacheline 1 used 0 by 18446744073709551615
cache hit rate so far: -nan
[dev_pixelpipe] took 0,000 secs (0,000 CPU) initing base buffer [export]
[dev_pixelpipe] took 0,081 secs (0,057 CPU) processed `Esposizione' on GPU, blended on GPU [export]
[default_process_tiling_cl_roi] use tiling on module 'flip' for image with full input size 4000 x 3000
[default_process_tiling_cl_roi] (2 x 1) tiles with max input dimensions 3667 x 4000
[default_process_tiling_cl_roi] tile (0, 0) with 4000 x 1500 at origin [0, 0]
[default_process_tiling_cl_roi] tile (1, 0) with 4000 x 1500 at origin [0, 1500]
[dev_pixelpipe] took 0,281 secs (0,211 CPU) processed `Orientamento ' on GPU with tiling, blended on CPU [export]
[dev_pixelpipe] took 0,101 secs (0,062 CPU) processed `Profilo colore di ingresso' on GPU, blended on GPU [export]
[opencl_events_flush] could not get event info for '[Read Image (from device to host)]': -5
[opencl_events_flush] could not get event info for 'zero': -5
[opencl_events_flush] could not get event info for 'splat': -5
[opencl_events_flush] could not get event info for '[Copy Buffer to Buffer (on device)]': -5
[opencl_events_flush] could not get event info for 'blur_line': -5
[opencl_events_flush] could not get event info for 'blur_line_z': -5
[opencl_events_flush] could not get event info for 'slice': -5
[opencl_pixelpipe] failed to run module 'bilat'. fall back to cpu path
[opencl_pixelpipe (b)] late opencl error detected while copying back to cpu buffer: -5
[opencl_profiling] spent 0,2024 seconds in [Write Image (from host to device)]
[opencl_profiling] spent 0,0083 seconds in exposure
[opencl_profiling] spent 0,3774 seconds in [Read Image (from device to host)]
[opencl_profiling] spent 0,0077 seconds in flip
[opencl_profiling] spent 0,0301 seconds in colorin_unbound
[opencl_profiling] spent 0,0000 seconds in zero
[opencl_profiling] spent 0,0000 seconds in splat
[opencl_profiling] spent 0,0000 seconds in [Copy Buffer to Buffer (on device)]
[opencl_profiling] spent 0,0000 seconds in blur_line
[opencl_profiling] spent 0,0000 seconds in blur_line_z
[opencl_profiling] spent 0,0000 seconds in slice
[opencl_profiling] spent 0,6260 seconds totally in command queue (with 9 events missing)
[pixelpipe_process] [export] falling back to cpu path
[dev_pixelpipe] took 0,066 secs (0,085 CPU) processed `Esposizione' on CPU, blended on CPU [export]
[dev_pixelpipe] took 0,240 secs (0,331 CPU) processed `Orientamento ' on CPU, blended on CPU [export]
[dev_pixelpipe] took 0,531 secs (0,781 CPU) processed `Profilo colore di ingresso' on CPU, blended on CPU [export]
[dev_pixelpipe] took 1,188 secs (1,797 CPU) processed `Contrasto locale' on CPU, blended on CPU [export]
[dev_pixelpipe] took 1,548 secs (2,085 CPU) processed `Monocromia' on CPU, blended on CPU [export]
[dev_pixelpipe] took 0,461 secs (0,605 CPU) processed `Profilo colore di uscita' on CPU, blended on CPU [export]
[dev_pixelpipe] took 0,129 secs (0,129 CPU) processed `Gamma' on CPU, blended on CPU [export]
[dev_process_export] pixel pipeline processing took 22,646 secs (17,984 CPU)
[sql] prepare "select folder || '/' || filename from images, film_rolls where images.film_id = film_rolls.id and images.id = ?1"
[sql] prepare "select value from meta_data where id = ?1 and key = ?2 order by value"
[sql] prepare "select flags from images where id = ?1"
[sql] prepare "select filename, flags, raw_parameters, longitude, latitude from images where id = ?1"
[sql] prepare "select key, value from meta_data where id = ?1"
[sql] prepare "SELECT DISTINCT T.id, T.name FROM tagged_images JOIN tags T on T.id = tagged_images.tagid WHERE tagged_images.imgid = 222 AND NOT T.name LIKE "darktable|%" ORDER BY T.name"
[sql] prepare "select color from color_labels where imgid=?1"
[sql] prepare "select imgid, formid, form, name, version, points, points_count, source from mask where imgid = ?1"
[sql] prepare "select imgid, num, module, operation, op_params, enabled, blendop_params, blendop_version, multi_priority, multi_name from history where imgid = ?1 order by num"
