My laptop has an external monitor attached: ViewSonic VX2439 as DFP-1
The screens both go black simultaneously. Often this seems to be triggered
by the use of the scroll button on the mouse. I am not able to reproduce the
issue at will. Unlike other reports, I do not see the mouse cursor after the
problem occurs. The system does not respond to Ctrl-Alt-Fnum, so I am unable
to debug from a console vTTY. I am able to SSH into the system afterward.
When I upgraded to Ubuntu 12.04, I was using the “current” drivers from Canonical,
ie. 295.40. However, those did not support my external monitor well. So I switched
to the 310.32 linux drivers from Nvidia. That is when I first encountered this
issue with both screens going blank. At that point, I decided to drop back to the
“experimental” nvidia drivers from Canonical, 310.14, where it stands today. Still
seeing the problem on 310.14.
The Xorg log file shows:
[ 60.812] (EE) NVIDIA(GPU-0): Failed detecting connected display devices
[ 68.880] [mi] EQ overflowing. Additional events will be discarded until existing events are processed.
[ 68.880]
Backtrace:
[ 68.968] 0: /usr/bin/X (xorg_backtrace+0x26) [0x7ff5441a59e6]
[ 68.968] 1: /usr/bin/X (mieqEnqueue+0x263) [0x7ff5441860c3]
[ 68.968] 2: /usr/bin/X (0x7ff54401d000+0x62a34) [0x7ff54407fa34]
[ 68.968] 3: /usr/lib/xorg/modules/input/evdev_drv.so (0x7ff53c576000+0x5d88) [0x7ff53c57bd88]
[ 68.968] 4: /usr/bin/X (0x7ff54401d000+0x8af37) [0x7ff5440a7f37]
[ 68.968] 5: /usr/bin/X (0x7ff54401d000+0xb0d3a) [0x7ff5440cdd3a]
[ 68.968] 6: /lib/x86_64-linux-gnu/libpthread.so.0 (0x7ff543343000+0xfcb0) [0x7ff543352cb0]
[ 68.968] 7: (vdso) (0x7fff4af8f000+0x7dc) [0x7fff4af8f7dc]
[ 68.968] 8: (vdso) (__vdso_gettimeofday+0x2b) [0x7fff4af8fa1b]
[ 68.968] 9: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0xed1fe) [0x7ff53cf281fe]
[ 68.968] 10: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x7c1ae) [0x7ff53ceb71ae]
[ 68.968] 11: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0xf3ce6) [0x7ff53cf2ece6]
[ 68.968] 12: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x4a0952) [0x7ff53d2db952]
[ 68.968] 13: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x4a0bcb) [0x7ff53d2dbbcb]
[ 68.968] 14: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x49d03a) [0x7ff53d2d803a]
[ 68.968] 15: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x49c584) [0x7ff53d2d7584]
[ 68.968] 16: /usr/bin/X (0x7ff54401d000+0xcd011) [0x7ff5440ea011]
[ 68.968] 17: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0x476b07) [0x7ff53d2b1b07]
[ 68.968] 18: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0xb6800) [0x7ff53cef1800]
[ 68.968] 19: /usr/lib/x86_64-linux-gnu/xorg/extra-modules/nvidia_drv.so (0x7ff53ce3b000+0xb6d95) [0x7ff53cef1d95]
[ 68.968] 20: /usr/bin/X (xf86Wakeup+0x192) [0x7ff5440a86f2]
[ 68.968] 21: /usr/bin/X (WakeupHandler+0x6b) [0x7ff54406f7eb]
[ 68.968] 22: /usr/bin/X (WaitForSomething+0x1b6) [0x7ff5441a2de6]
[ 68.968] 23: /usr/bin/X (0x7ff54401d000+0x4e5f2) [0x7ff54406b5f2]
[ 68.968] 24: /usr/bin/X (0x7ff54401d000+0x3d7ba) [0x7ff54405a7ba]
[ 68.968] 25: /lib/x86_64-linux-gnu/libc.so.6 (__libc_start_main+0xed) [0x7ff5421d476d]
[ 68.968] 26: /usr/bin/X (0x7ff54401d000+0x3daad) [0x7ff54405aaad]
[ 68.968] [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
[ 68.968] [mi] mieq is NOT the cause. It is a victim.
[This file was removed because it was flagged as potentially malicious] (69.5 KB)
nvidia-installer.log (2.46 KB)
