half-0
July 9, 2025, 10:57pm
1
I have 2 persistent kernels which will run on the SM on the same time. They need to operate together. Now I want to profile both kernels by using ncu. Is there any way for me to profile them in a same launch?
I’ve tried to only profile one kernel, but this operation will prevent the other kernel from launching, I think its weird
veraj
July 10, 2025, 2:01am
2
Hi, @half-0
Do you have a mini-repro for us to try ?
Can you tell which Nsight Compute/driver and the command line you use ?
half-0
July 10, 2025, 2:20pm
3
on A100
function collect_ncu() {
report=$1; shift
kernel_name=$1; shift
target_cmd=( "$@" )
if [[ "${target_cmd[0]}" == "python" || "${target_cmd[0]}" == "python3" ]]; then
target_cmd[0]="$VIRTUAL_ENV/bin/${target_cmd[0]}"
fi
sudo env \
VIRTUAL_ENV="$VIRTUAL_ENV" \
PATH="$VIRTUAL_ENV/bin:$PATH" \
LD_LIBRARY_PATH="$LD_LIBRARY_PATH" \
/usr/local/cuda-12.8/bin/ncu \
--set full \
--force-overwrite \
--target-processes all \
--replay-mode application \
--kernel-name "$kernel_name" \
--kernel-name-base function \
--launch-skip 0 \
--launch-skip-before-match 0 \
--launch-count 1 \
--kill no \
--filter-mode global \
--warp-sampling-interval auto \
--warp-sampling-max-passes 5 \
--warp-sampling-buffer-size 33554432 \
--profile-from-start 1 \
--cache-control all \
--clock-control base \
--apply-rules yes \
--import-source no \
--check-exit-code yes \
--section MemoryWorkloadAnalysis_Chart \
--section MemoryWorkloadAnalysis_Tables \
--metrics group:memory__chart,group:memory__shared_table,group:memory__first_level_cache_table,group:memory__l2_cache_table,group:memory__l2_cache_evict_policy_table,group:memory__dram_table \
--export "$report" \
-- "${target_cmd[@]}"
collect_ncu "$1" "$2" "${@:3}"
I use this bash to profile a single kernel. However, as I need to launch 2 kernels at the same time:
kernel_0<<<dim3(54, 1, 1), dim3(128, 1, 1), 98304 /*smem*/, 0>>>(
runtime_config);
kernel_1<<<dim3(54, 1, 1), dim3(128, 1, 1), 98304 /*smem*/, 1>>>(
runtime_config);
only kernel_0 was launched no matter which kernel I profile.
if I swap the launch order, then only kernel_1 will be launched.
As I need 2 kernels to coorporate, the program is stucked
half-0
July 14, 2025, 5:03pm
5
Can anyone help me? I still can’t profile it though I’ve used all methods I can use
veraj
July 15, 2025, 5:17am
6
Please define ranges in your code and then profile with range replay. 2. Profiling Guide — NsightCompute 12.9 documentation
