My code, which has real*16 in it, does not compile with pgfortran. Is there a workaround?
I made a small code for test:
program testKind
real*16 :: a, b
a=1.d0; b=2.d0
write(*,*) a+b
end
The compiler says:
PGI$ pgf90 -o testKind testKind.f90
PGF90-W-0031-Illegal data type length specifier for real (testKind.f90: 2)
PGF90-W-0031-Illegal data type length specifier for a (testKind.f90: 2)
PGF90-W-0031-Illegal data type length specifier for b (testKind.f90: 2)
We don’t support REAL*16 types. The reason being 128-bit floating point calculations are not supported by hardware, assuming you’re using an x86 processor.
There are software libraries out there that will emulate quad precision at the cost of performance. There are a few existing threads on this topic that go into more detail:
