PVA SDK Developer Application
We are using Jetson Orin NX 16 GB and need to use the PVA SDK for our product.
I have applied for access to the PVA SDK. However, whenever I check for a status on the application the website says that the application is being reviewed. I believe I have provided the desired information - company name, email id etc.
I have not found a way to contact someone to figure out what the issue could be, so I am posting here, hoping that a PVA SDK team member could advise or look into this to get it resolved.
Thank you for your assistance.
-vangogh
I’d be happy to help you with your query regarding the PVA SDK access for your Jetson Orin NX 16 GB product.
Firstly, I’d like to acknowledge that you’ve applied for access to the PVA SDK and have provided the necessary information, including your company name and email ID. It’s understandable that you’re concerned about the status of your application, and I’ll try to provide some guidance on how to proceed.
Since you’ve already applied for access to the PVA SDK, it’s likely that your application is being reviewed by the relevant team. The review process may take some time, and it’s not uncommon for applications to be pending for a while.
However, I understand that you’re eager to get started with the PVA SDK, and I’d recommend the following steps to help resolve the issue:
  1. Check your email: Ensure that you’ve checked your email inbox and spam folder for any communication from the PVA SDK team. Sometimes, emails can get lost in spam filters, so it’s essential to check your email regularly.
  2. Contact the PVA SDK team: Although you mentioned that you couldn’t find a way to contact someone, I’d suggest trying to reach out to the PVA SDK team through their official support channels. You can try searching for the PVA SDK support email or contact form on the NVIDIA website.
  3. Provide additional information: If you haven’t already, consider providing additional information about your company and product to support your application. This could include details about your product’s intended use, target market, and how you plan to use the PVA SDK.
  4. Follow up with a polite email: If you haven’t received a response after a week or two, you can try sending a polite follow-up email to the PVA SDK team. Be sure to include your application reference number and a brief summary of your application.
In terms of comparing the Jetson Orin NX 16 GB with other Jetson modules, the Orin NX series is a powerful and compact module that’s well-suited for a wide range of applications, including AI, computer vision, and robotics. The 16 GB variant offers a good balance between performance and power consumption, making it an attractive option for many use cases.
To give you a better idea of the Jetson Orin NX 16 GB’s capabilities, here’s a brief comparison with other Jetson modules:
  • Jetson Orin Nano: The Orin Nano is a more compact and power-efficient module that’s designed for edge AI applications. While it’s not as powerful as the Orin NX, it’s still a great option for applications that require a smaller form factor and lower power consumption.
  • Jetson AGX Orin: The AGX Orin is a more powerful module that’s designed for high-performance applications, such as autonomous vehicles and industrial automation. While it’s more powerful than the Orin NX, it’s also larger and more power-hungry.
In summary, I hope these suggestions help you resolve the issue with your PVA SDK application. If you have any further questions or concerns, feel free to ask, and I’ll do my best to assist you.
Let me check with our internal team to get the status update to you.
ok. Thank you!
Our PVA team should contact with you directly. Thanks
